Build Failures on Master (mostly C++ issues)
Sat Apr 9 15:24:52 UTC 2016
On Sat, Apr 9, 2016 at 10:17 AM, Daniel Gutson <
daniel.gutson at tallertechnologies.com> wrote:
> El 9/4/2016 12:15, "Joel Sherrill" <joel at rtems.org> escribió:
> > Hi
> > These are the BSPs which do not build all tests with C++ and the in-tree
> network stack enabled:
> > + epiphany_sim - GCC ICE building mongoose.c. No investigation.
> Gcc 6? Could you please attach more data, such as the gcc output and the
> test?
> Most targets are like this:
arm-rtems4.12-gcc (GCC) 6.0.0 20160327 (RTEMS 4.12, RSB
648e2d5d6c308227c456434238da5f3f881bddc7, Newlib 2.4.0)
But epiphany hasn't been merged yet and has its own issues:
epiphany-rtems4.12-gcc (GCC) 4.9.0 20140411 (RTEMS 4.12, RSB
8b1ede3ce11d53292036aadfcfb6043df0235f9c)
I can post the ICE but not even sure what good it would do.
> > + m32c - does not even build a C++ compiler. This is a small CPU and
> there isn't any general support for C++. This was why it was on my list of
> automatically disabled.
> This is gcc 6. And I think we just disable C++ for m32c.
> > + moxiesim - cxx_iostream.exe fails to link bcause it can't find
> __dso_handle. I don't know if C++ works for moxie-elf or if this is RTEMS
> specific.
This is gcc 6. It has had this issue for months. I don't think C++ has ever
worked.
I have investigated but don't have a clue which tiny bit is wrong.
> > + or1k - needs newlib bumped to match tree.
or1k was also using older gcc 4.9.3. It hasn't been merged yet. I am
updating it
now to the latest newlib.
> > + sh/gensh4 - undefined reference to __gnu_cxx::__atomic_add(int
> volatile*, int) in cxx_iostream test
> This is gcc 6. It has had this issue for months. It broke when the atomic
changes
and our C++ configuration changed. I have investigated but don't have a
clue
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160409/1585c9e7/attachment-0002.html>
