[PATCH v2 1/6] Imported files for driver: bcm283x_dwcotg
    Christian Mauderer
    christian.mauderer at embedded-brains.de
    Mon Aug 29 06:56:41 UTC 2016
Am 27.08.2016 um 13:16 schrieb Deval Shah:
> On Tue, Aug 23, 2016 at 7:08 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     I updated the MMC support to use the FreeBSD trunk, 2016-08-23,
>     9fe7c416e6abb28b1398fd3e5687099846800cfd. It would be great if you
>     can use this version as well as a baseline for your work.
> Is it okay if I provide a new patch (not resend in the previous ones)
> updating the code ?
>     On 22/08/16 10:37, Deval Shah wrote:
>         On Mon, Aug 22, 2016 at 11:25 AM, Sebastian Huber
>         <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>             If you think the guidelines could be more clear, need an
>             explanation or examples, then we should address this first.
>         I could use some examples on the last rule " Do not disable
>         option header includes via guards.  Instead, add an empty option
>         header, e.g. `rtemsbsd/include/rtems/bsd/local/opt_xyz.h`.  In
>         general, provide empty header files and do not guard includes. "
>     Ok, I updated the libbsd.txt.
> I have a small doubt
> here. https://git.rtems.org/rtems-libbsd/tree/libbsd.txt#n654
> Do I have to provide all the headers which I want to ignore, with an
> empty file as mentioned or only the ones which are transformed by the
> import script ?
> For example includes like these.  "#include <dev/ofw/ofw_bus_subr.h>"
Hello Deval,
Sebastian is currently on vacation so he might need some time to answer.
I'll try to give some hints but I'm far from being as familiar with
libbsd as Sebastian is, so he (or some others) might have another opinion.
Regarding the header: Currently mainly the option headers are empty. If
you do a
   find -size 0 -name "*.h"
(or some other search for empty files) in the libbsd directory, the
empty headers are option headers and some machine dependent files.
So if you ask me, it should be OK to disable the mentioned
ofw_bus_subr.h especially because you disabled ofw in the whole file.
On the other hand an option header that you should add as an empty file
would be opt_platform.h in your patch 5/6.
Kind regards
Christian
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
