QT 5.8 Port
Kirspel, Kevin Kevin-Kirspel at idexx.com
Fri Dec 9 13:17:24 UTC 2016
LIBBSD has the poll() functionality.  In order for the pipe to be polled then it needs functionality that is only found in LIBBSD.  I started off using the pipe in the RTEMS tree.  I even added the poll handler to return the correct revents.  The problem was that the RTEMS pipe poll handler needs to call a function in LIBBSD (selrecord) so that it can work with poll().
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian Huber
Sent: Friday, December 09, 2016 3:44 AM
To: devel at rtems.org
Subject: Re: QT 5.8 Port
Hello Kevin,
we already have a (broken) pipe support in RTEMS
https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems_tree_cpukit_libcsupport_src_pipe.c&d=DgIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=JsBiBqByZuuh7FFKuLujX-9gC7BaNG4-3Xa1ytmRgcA&s=kS0AINMLfVS4Eoot_vf4iYhQwj3ENj3xMIyrqerJfIc&e=
What is the befit of using the FreeBSD pipe implementation?
On 07/12/16 19:49, Kirspel, Kevin wrote:
> I'm porting QT 5.8 to RTEMS 4.12 and rtems-libbsd.  I had to add pipe
> support to rtems-libbsd.  I would like to submit the pipe patch but
> the "git diff" is long due to the fact that the diff includes the
> entire file contents of the modified sys_pipe.c and pipe.h files.  How
> do you usually submit patches for review for rtems-libbsd?
> Kevin Kirspel
> Idexx Roswell
> Roswell GA 30076
> Fax: (770)-510-4445
> devel mailing list
> devel at rtems.org
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_ma
> ilman_listinfo_devel&d=DgIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBf
> tmRgcA&s=DmB5g2XWSfm8YAS-McegW2BaDcYR_4LLkQkY5liYzKI&e=
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DgIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=JsBiBqByZuuh7FFKuLujX-9gC7BaNG4-3Xa1ytmRgcA&s=DmB5g2XWSfm8YAS-McegW2BaDcYR_4LLkQkY5liYzKI&e=
