QT 5.8 Port
Fri Dec 9 14:17:39 UTC 2016
On 09/12/16 14:17, Kirspel, Kevin wrote:
> LIBBSD has the poll() functionality.  In order for the pipe to be polled then it needs functionality that is only found in LIBBSD.  I started off using the pipe in the RTEMS tree.  I even added the poll handler to return the correct revents.  The problem was that the RTEMS pipe poll handler needs to call a function in LIBBSD (selrecord) so that it can work with poll().
Ok, this makes sense.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
