Fwd: [rtems commit] Merge branch 'master' of ssh://dispatch.rtems.org/data/git/ rtems
Joel Sherrill
joel at rtems.org
Mon Jan 18 20:42:33 UTC 2016
Thanks.
Since I tend to do commits from others on the same
branch name, this should be easy to avoid 99% of the
time in the future.
--joel
On Mon, Jan 18, 2016 at 12:33 AM, Sebastian Huber <
> Looks all right.
> You can avoid this problem in the future if you add something like this to
> your .git/config:
> [branch "abc"]
> rebase = true
> On 16/01/16 21:36, Joel Sherrill wrote:
>> Please check that I did not screw the master up.
>> I was at a library for an authors' day with Michele. I was committing a
>> GCI patch and accidentally did this.
>> Double check and revert if needed.
>> Thanks.
>> ---------- Forwarded message ----------
>> From: "Joel Sherrill" <joel at rtems.org <mailto:joel at rtems.org>>
>> Date: Jan 16, 2016 11:18 AM
>> Subject: [rtems commit] Merge branch 'master' of ssh://
>> dispatch.rtems.org/data/git/ <http://dispatch.rtems.org/data/git/> rtems
>> To: <vc at rtems.org <mailto:vc at rtems.org>>
>> Cc:
>> Module: rtems
>> Branch: master
>> Commit: c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=c40dd4ed703bbaee7e6492cfbb966a1d5cda7341
>> Author: Joel Sherrill <joel at rtems.org <mailto:joel at rtems.org>>
>> Date: Sat Jan 16 11:17:43 2016 -0600
>> Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems <
>> http://dispatch.rtems.org/data/git/rtems>
>> vc mailing list
>> http://lists.rtems.org/mailman/listinfo/vc
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160118/1dbe4c66/attachment.html>
