Updates and Problems on "Raspberry Pi USB and Ethernet Support" Project
Alan Cudmore
alan.cudmore at gmail.com
Tue Jul 12 01:35:28 UTC 2016
Hi Deval,
What code do I need to add to try your test?
I am using the items git head kernel, and your rtems-libbsd RaspberryPi_USB branch.
When I run init01 on my Pi Zero, I get the output below.
Alan
*** LIBBSD INIT 1 TEST ***
nexus0: <RTEMS Nexus device>
bcm283x_dwcotg0: <DWC OTG 2.0 integrated USB controller (bcm283x)> on nexus0
usbus0 on bcm283x_dwcotg0
usbus0: 480Mbps High Speed USB v2.0
uhub0: <DWCOTG OTG Root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
Sleeping to see what happens
uhub0: 1 port with 1 removable, self powered
> On Jul 11, 2016, at 10:37 AM, Deval Shah <deval.maker at gmail.com> wrote:
> Hello all,
> I am trying to add usb_ethernet (smsc) driver for raspberry pi for both USB and Ethernet support.
> Now I have added the required files. But the USB device is not getting power. To get the compilation error-less, I have applied a hack.
> if_smsc.c is using the function “usbd_m_copy_in” which is present in the file sys/dev/usb/usb_busdma.c. But due to this macro #if USB_HAVE_MBUF the function was not getting compiled. So I have commented out the macro and let the function compile.
> Now ideally I should have used the DMA controller. Here I don't know the status of DMA's functions and their usage. Any pointers on that ?
> I believe the problem is secondary for the USB to function. Anyhow the USB devices should get the power if the code is added. I suspect there is no proper linking between the drivers. (i.e. dwcotg, bcm283x_dwcotg, ushub, smsc, uhub, usb.) I would like some insights on how these interact.
> I have added following lines in the nexus-devices.h file under Raspberry-pi-BSP.
> SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
> SYSINIT_DRIVER_REFERENCE(smsc, uhub);
> SYSINIT_DRIVER_REFERENCE(smsc, uether);
> SYSINIT_DRIVER_REFERENCE(smsc, usb);
> SYSINIT_DRIVER_REFERENCE(smsc, ether);
> SYSINIT_DRIVER_REFERENCE(smsc, miibus);
> I am also attaching the log of INIT01 Test.
> I need help at this point. I am kind of stuck here.
> Thank you in advance.
> Deval Shah
> <libbsd-init01-test.log>_______________________________________________
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160711/963dbef5/attachment.html>
