Help required with RTEMS Capture Engine.
Wed Jul 20 22:32:27 UTC 2016
On 19/07/2016 18:30, vivek kukreja wrote:
> Hello all,
> I'm Vivek Kukreja and i'm working on Capture Engine for GSoC this year. I'm running rtems 4.12 and I came across an error on running the capture.exe example to trace user extensions.
> The 'ctrace' command is giving an error RTEMS_UNSATISFIED.
> I think this error is due to a faulty if condition in cpukit/libmisc/capture.c
> I think the following exit condition is inconsistent:
> if ( (capture_flags_global & RTEMS_CAPTURE_ON) != 0 )
> And it should be:
> if ( (capture_flags_global & RTEMS_CAPTURE_ON) == 0 )
> I've been asked to open a ticket for this bug but i wanted to confirm beforehand if anyone else faced this issue, since the capture engine code was commited 16months back.
There is something wrong with this code and I am not sure what it is.
Joel is going to have to sort this out.
For example, this comment says this function returns a number of record
slots back to the capture engine which implies to me this can be called
with the capture engine is running:
https://git.rtems.org/rtems/tree/cpukit/libmisc/capture/capture.c#n1244
and yet the type of code you point out:
https://git.rtems.org/rtems/tree/cpukit/libmisc/capture/capture.c#n1269
says you cannot do this operation while the capture is on. One of these
things is wrong and I do not know which.
I suspect the test is wrong but I am not sure if it is ok to change or
if the test is actually valid.
Joel?
