[PATCH] testsuits: Fixed typo in fileio.doc
    Gedare Bloom
    gedare at rtems.org
    Fri Mar 25 13:23:46 UTC 2016
This looks good to commit if anyone can get to it.
On Sat, Feb 20, 2016 at 2:26 PM, punitvara <punitvara at gmail.com> wrote:
>         This patch basically fixes some typo in document file.
>  testsuites/samples/fileio/fileio.doc | 6 +++---
>  1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/testsuites/samples/fileio/fileio.doc b/testsuites/samples/fileio/fileio.doc
> index 0a43601..95d50b1 100644
> --- a/testsuites/samples/fileio/fileio.doc
> +++ b/testsuites/samples/fileio/fileio.doc
> @@ -22,17 +22,17 @@ A sample session might look like this:
>  - start this system
>  - select "p" (part_table_initialize) to read in the partition table of
> -first harddisk, enter the device name "/dev/hda", when prompted
> +first hard disk, enter the device name "/dev/hda", when prompted
>  - select "f" (fsmount) to try to mount the partitions
> -  /dev/hda1../dev/hdc4 to corresponding mount points. Non-existant
> +  /dev/hda1../dev/hdc4 to corresponding mount points. Non-existent
>    partitions will report an error, but will not abort the tests
>  - select "w" (write file) to create a new file on the mounted disk (or
>    in the IMFS). Enter the file name (e.g. "/mnt/hda1/test_1M.txt"),
>    the file size (e.g. 64K or 2M) and the buffer size to use for the
>    write calls (e.g. 32 or 4K). Then the sample will try to write the
> -  corresponding file and print the time consumed and data rate achived.
> +  corresponding file and print the time consumed and data rate achieved.
>  - select "r" (read file) to read a file (without displaying the
>    contents). It has similar parameters as "write file", but does not
> 2.7.1
> devel mailing list
> devel at rtems.org
