[PATCH] [RSB] use updated newlib revision for or1k
Hesham Almatary
heshamelmatary at gmail.com
Tue Mar 29 23:08:33 UTC 2016
Building RTEMS without this patch will fail with some nfs and rpc libs
since newlib version is outdated (March 2015).
On Wed, Mar 30, 2016 at 10:03 AM Joel Sherrill <joel at rtems.org> wrote:
> I am OK with this if you want to push it.
> I guess you saw that I plan/hope to bump the newlib and gcc versions
> on all targets I can when the next newlib snapshot comes out.
> --joel
> On Tue, Mar 29, 2016 at 5:23 PM, Hesham Almatary <heshamelmatary at gmail.com
> > wrote:
>> rtems/config/4.12/rtems-or1k.bset | 2 +-
>> rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg | 13 +++++++++++++
>> 2 files changed, 14 insertions(+), 1 deletion(-)
>> create mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>> diff --git a/rtems/config/4.12/rtems-or1k.bset
>> b/rtems/config/4.12/rtems-or1k.bset
>> index 7d8baba..fe6a23d 100644
>> --- a/rtems/config/4.12/rtems-or1k.bset
>> +++ b/rtems/config/4.12/rtems-or1k.bset
>> @@ -38,7 +38,7 @@
>> 4.12/rtems-autotools
>> devel/expat-2.1.0-1
>> tools/rtems-binutils-2.26-1
>> -tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
>> +tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>> tools/rtems-tools-4.12-1
>> tools/rtems-gdb-7.11-1
>> diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>> b/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>> new file mode 100644
>> index 0000000..ad95302
>> --- /dev/null
>> +++ b/rtems/config/tools/rtems-gcc-4.9.3-newlib-git-1.cfg
>> @@ -0,0 +1,13 @@
>> +# GCC 4.9.3., Newlib GIT
>> +%define gcc_version 4.9.3
>> +%define newlib_version 8b1ede3ce11d53292036aadfcfb6043df0235f9c
>> +%hash md5 gcc-%{gcc_version}.tar.bz2 6f831b4d251872736e8e9cc09746f327
>> +# The gcc/newlib build instructions.
>> +%include tools/rtems-gcc-4.9-newlib-git-1.cfg
>> 2.8.0.rc3
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160329/10791e11/attachment.html>
