LM3S69xx BSP Qemu Error
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Fri May 27 15:01:34 UTC 2016
Hi Martin,
I am able to run HelloWorld with what you provided. I also noticed that the
process does not terminate by itself and I have to manually kill it. I
noticed that for the HelloWorld and ticker. Does it behave like that when
you run it?
Below the output of my arm-rtems4.12-gcc --version.
Thanks.
Using built-in specs.
COLLECT_GCC=arm-rtems4.12-gcc
COLLECT_LTO_WRAPPER=/home/dipupo/development/rtems/4.12/
libexec/gcc/arm-rtems4.12/6.0.1/lto-wrapper
Target: arm-rtems4.12
Configured with: ../gcc-6.0.1-RC-20160415/configure
--prefix=/home/dipupo/development/rtems/4.12
--bindir=/home/dipupo/development/rtems/4.12/bin
--exec_prefix=/home/dipupo/development/rtems/4.12
--includedir=/home/dipupo/development/rtems/4.12/include
--libdir=/home/dipupo/development/rtems/4.12/lib
--libexecdir=/home/dipupo/development/rtems/4.12/libexec
--mandir=/home/dipupo/development/rtems/4.12/share/man
--infodir=/home/dipupo/development/rtems/4.12/share/info
--datadir=/home/dipupo/development/rtems/4.12/share --build=i686-linux-gnu
--host=i686-linux-gnu --target=arm-rtems4.12 --disable-libstdcxx-pch
--with-gnu-as --with-gnu-ld --verbose --with-newlib --with-system-zlib
--disable-nls --without-included-gettext --disable-win32-registry
--enable-version-specific-runtime-libs --disable-lto
--enable-newlib-io-c99-formats --enable-newlib-iconv --enable-newlib-iconv-
encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_
kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,
iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,
iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,
iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_
internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_
4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_
1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
--enable-threads --disable-plugin --enable-libgomp --enable-languages=c,c++
Thread model: rtems
gcc version 6.0.1 20160415 (RTEMS 4.12, RSB
8bcc58b249fbf1f6e7bbd4151d9cf9b04c94b87e,
Newlib 2.4.0) (GCC)
On Fri, May 27, 2016 at 10:18 AM, Martin Galvan <
martin.galvan at tallertechnologies.com> wrote:
> On Fri, May 27, 2016 at 11:15 AM, Olufowobi, Habeeb
> <habeeb.olufowobi at bison.howard.edu> wrote:
> > Can you please also specify the command line argument used to run
> hello.exe.
> > Let me try that to see if I have some parameters in my command line that
> was
> > not supposed to be there.
> Certainly. I'm running the following:
> ./bin/qemu-system-arm -nographic -M lm3s6965evb -kernel
> /home/martin/rtems/build/arm-rtems4.12/c/lm3s6965/testsuites/samples/hello/hello.exe
> I'm assuming you're using the latest RTEMS master, and a (fairly
> recent) toolchain. Just in case, could you please show the output of
> arm-rtems4.12-gcc --version?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160527/10307cd9/attachment.html>
