Errors while building USB DWC OTG driver
Deval Shah
deval.maker at gmail.com
Sun May 29 06:30:33 UTC 2016
I reverted back to the latest commit of RTEMS. I am getting the same
errors.
On Sun, May 29, 2016 at 11:23 AM, Deval Shah <deval.maker at gmail.com> wrote:
> I followed the libbsd.txt and added bcm 283x driver from freebsd source.
> Now I am getting new errors. This time drivers got compiled which was
> verified using this command.
> > nm `find build -name '*bcm283x_dwc_fdt*.o'`
> The error log is as follows.
> In file included from ../../rtemsbsd/rtems/rtems-kernel-muteximpl.c:41:0:
> /home/gadgetman/development/rtems/rtems-libbsd/rtemsbsd/include/machine/rtems-bsd-muteximpl.h:69:5:
> error: unknown type name 'Thread_queue_Context'
> Thread_queue_Context *queue_context);
> In function 'rtems_bsd_mutex_lock':
> /home/gadgetman/development/rtems/rtems-libbsd/rtemsbsd/include/machine/rtems-bsd-muteximpl.h:74:2:
> Thread_queue_Context queue_context;
> /home/gadgetman/development/rtems/rtems-libbsd/rtemsbsd/include/machine/rtems-bsd-muteximpl.h:79:49:
> error: request for member 'Lock_context' in something not a structure or
> union
> _Thread_queue_Acquire(&m->queue, &queue_context.Lock_context);
> /home/gadgetman/development/rtems/rtems-libbsd/rtemsbsd/include/machine/rtems-bsd-muteximpl.h:88:50:
> union
> _Thread_queue_Release(&m->queue, &queue_context.Lock_context);
> The log is very big and it is showing that many structures are missing. I
> am unable to figure out why this happened. Because I didn't edit any file
> related to rtems-bsd. Any pointers ?
> Commit for above code changes.
> https://github.com/deval-maker/rtems-libbsd/commit/d90e11ec8e775eed9580e17a6ecaff11fac39931
> Thanks,
> Deval Shah
> On Wed, May 25, 2016 7:24 PM, Deval Shah deval.maker at gmail.com wrote:
>> On Wed, May 25, 2016 at 7:12 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>> On 25/05/16 14:59, Deval Shah wrote:
>> On Wed, May 25, 2016 at 3:07 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de <mailto:
>> sebastian.huber at embedded-brains.de>> wrote:
>> If you get
>> On 25/05/16 10:19, Deval Shah wrote:
>> I got the following result.
>> nm: 'a.out': No such file
>> from
>> nm `find build -name '*bcm283x_dwc_fdt*.o`
>> the this is the first issue you have to resolve. Read the man
>> pages of nm and find to figure out what these commands do.
>> You must have object files for all your driver modules.
>> I understood the problem. Driver for bcm283x is no getting built. Is
>> there any documentation availible for porting a driver to rtems-libbsd ? So
>> that I can verify necessary steps for the code I cherry-picked or if
>> required do the process from scratch.
>> See "How to import code from FreeBSD" in libbsd.txt.
>> Great ! Thanks a lot.
>> Please improve the documentation while you work on this.
>> Surely I will.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160529/d53b80fc/attachment-0001.html>
