[PATCH 2/2] bsp/atsam: Add SDRAM IS42S16320F-7BL.
    Christian Mauderer
    christian.mauderer at embedded-brains.de
    Tue Sep  6 09:32:44 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 c/src/lib/libbsp/arm/atsam/configure.ac         | 12 +++++++-
 c/src/lib/libbsp/arm/atsam/startup/ram-config.c | 41 +++++++++++++++++++++++++
 2 files changed, 52 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/atsam/configure.ac b/c/src/lib/libbsp/arm/atsam/configure.ac
index 1297367..83c64b4 100644
--- a/c/src/lib/libbsp/arm/atsam/configure.ac
+++ b/c/src/lib/libbsp/arm/atsam/configure.ac
@@ -50,6 +50,16 @@ AC_ARG_ENABLE(
 esac],
 [AC_DEFINE([__SAMV71Q21__],[1],[chip variant]) INTFLASH=0x00200000 ; INTSRAM=0x00060000])
+AC_ARG_ENABLE(
+[sdram],
+[AS_HELP_STRING([--enable-sdram],[select a SDRAM variant (default is42s16100e-7bli)])],
+[case "${enableval}" in
+  is42s16100e-7bli) AC_DEFINE([__SDRAM_IS42S16100E_7BLI__],[1],[SDRAM variant]) EXTSDRAM=0x00200000 ;;
+  is42s16320f-7bl) AC_DEFINE([__SDRAM_IS42S16320F_7BL__],[1],[SDRAM variant]) EXTSDRAM=0x04000000 ;;
+  *) AC_MSG_ERROR([bad value ${enableval} for SDRAM variant]) ;;
+esac],
+[AC_DEFINE([__SDRAM_IS42S16100E_7BLI__],[1],[SDRAM variant]) EXTSDRAM=0x00200000])
 RTEMS_BSPOPTS_SET([BOARD_MAINOSC],[*],[12000000])
 RTEMS_BSPOPTS_HELP([BOARD_MAINOSC],[Main oscillator frequency in Hz (default 12MHz)])
@@ -76,7 +86,7 @@ AC_ARG_VAR([$1],[$2])dnl
 ATSAM_LINKCMD([ATSAM_MEMORY_TCM_SIZE],[size of tightly coupled memories (TCM) in bytes],[0x00000000])
 ATSAM_LINKCMD([ATSAM_MEMORY_INTFLASH_SIZE],[size of internal flash in bytes],[${INTFLASH}])
 ATSAM_LINKCMD([ATSAM_MEMORY_INTSRAM_SIZE],[size of internal SRAM in bytes],[${INTSRAM}])
-ATSAM_LINKCMD([ATSAM_MEMORY_SDRAM_SIZE],[size of external SDRAM in bytes],[0x00200000])
+ATSAM_LINKCMD([ATSAM_MEMORY_SDRAM_SIZE],[size of external SDRAM in bytes],[${EXTSDRAM}])
 ATSAM_LINKCMD([ATSAM_MEMORY_QSPIFLASH_SIZE],[size of QSPI flash in bytes],[0x00200000])
 AC_CONFIG_FILES([
diff --git a/c/src/lib/libbsp/arm/atsam/startup/ram-config.c b/c/src/lib/libbsp/arm/atsam/startup/ram-config.c
index 65060a7..e957107 100644
--- a/c/src/lib/libbsp/arm/atsam/startup/ram-config.c
+++ b/c/src/lib/libbsp/arm/atsam/startup/ram-config.c
@@ -12,10 +12,13 @@
  * http://www.rtems.org/license/LICENSE.
+#include <bspopts.h>
 #include <chip.h>
 #include <include/board_memories.h>
+#if defined __SDRAM_IS42S16100E_7BLI__
 const struct BOARD_Sdram_Config BOARD_Sdram_Config = {
+  /* FIXME: a lot of these values should be calculated using CPU frequency */
   .sdramc_tr = 1562,
   .sdramc_cr =
       SDRAMC_CR_NC_COL8      /* 8 column bits */
@@ -32,3 +35,41 @@ const struct BOARD_Sdram_Config BOARD_Sdram_Config = {
   .sdramc_mdr = SDRAMC_MDR_MD_SDRAM,
   .sdramc_cfr1 = SDRAMC_CFR1_UNAL_SUPPORTED | SDRAMC_CFR1_TMRD(2)
+#elif defined __SDRAM_IS42S16320F_7BL__
+#define CLOCK_CYCLES_FROM_NS_MAX(ns) \
+    (((ns) * (BOARD_MCK / 1000ul / 1000ul)) / 1000ul)
+#define CLOCK_CYCLES_FROM_NS_MIN(ns) (CLOCK_CYCLES_FROM_NS_MAX(ns) + 1)
+const struct BOARD_Sdram_Config BOARD_Sdram_Config = {
+  /* 8k refresh cycles every 64ms => 7.8125us */
+  .sdramc_tr = CLOCK_CYCLES_FROM_NS_MAX(7812ul),
+  .sdramc_cr =
+      SDRAMC_CR_NC_COL10
+    | SDRAMC_CR_NR_ROW13
+    | SDRAMC_CR_CAS_LATENCY3
+    | SDRAMC_CR_NB_BANK4
+    | SDRAMC_CR_DBW
+    /* t_WR = 30ns min (t_RC - t_RP - t_RCD;
+     * see data sheet November 2015 page 55);
+     * add some security margin */
+    | SDRAMC_CR_TWR(CLOCK_CYCLES_FROM_NS_MIN(40))
+    | SDRAMC_CR_TRC_TRFC(CLOCK_CYCLES_FROM_NS_MIN(60))
+    | SDRAMC_CR_TRP(CLOCK_CYCLES_FROM_NS_MIN(15))
+    | SDRAMC_CR_TRCD(CLOCK_CYCLES_FROM_NS_MIN(15))
+    | SDRAMC_CR_TRAS(CLOCK_CYCLES_FROM_NS_MIN(37))
+    | SDRAMC_CR_TXSR(CLOCK_CYCLES_FROM_NS_MIN(67)),
+  .sdramc_mdr = SDRAMC_MDR_MD_SDRAM,
+  .sdramc_cfr1 = SDRAMC_CFR1_UNAL_SUPPORTED |
+      SDRAMC_CFR1_TMRD(CLOCK_CYCLES_FROM_NS_MIN(14))
+#if CLOCK_CYCLES_FROM_NS_MIN(67) > 0xF
+  /* Prevent the fields to be out of range by checking the one with the biggest
+   * value. */
+  #error SDRAM calculation does not work for the selected clock frequency
+#endif
+#else
+  #error SDRAM not supported.
+#endif
2.9.3
