Jetson TK1 BSP
Andreas Kölbl andreas.koelbl at st.oth-regensburg.de
Tue Apr 11 19:15:23 UTC 2017
Am 11.04.2017 um 14:28 schrieb Joel Sherrill:
> Awesome!
> Can you separate out the Jailhouse changes, BSP changes and any other
> changes?
Not everything, the Interrupt Controller parses a static list where the
information which interrupts are mapped is located.
This should be fixed using the interrupts provided in the flat device
tree. Is this working already?
> IMO the Jailhouse support is a definite thing we would want to merge.
> If you did any clean up or enhancements that are not TK1 specific,
> then we would likely want to merge those. The TK1 BSP is the specific
> piece that needs discussion.
> Can I still but a TK1? How similar is it to followup models?
Yes, Nvidia has a list of vendors on their website [1]. Follow up models
are completely different as they use the ARMv8 architecture which is 64
bit and currently not supported by RTEMS.
> Do you know of a simulator or is real hw the only testing option?
I guess QEMU will work but I haven't make it working yet.
> I am certainly pro merging it if you will be the point person for
> maintaining​ and testing it. :)
Sure :)
--Andreas
> We just need to digest the pieces.
> --joel
> On Apr 11, 2017 4:22 AM, "Andreas Kölbl"
> <andreas.koelbl at st.oth-regensburg.de
> <mailto:andreas.koelbl at st.oth-regensburg.de>> wrote:
>     I successfully ported RTEMS on the Jetson TK1 board for my
>     Bachelorthesis. It
>     includes a GPIO, timercounter clock, a benchmark timer (yes, I
>     wanted to
>     run the
>     old tmtests) and a console driver which basically is a national
>     semiconductor
>     8250 implementation. Additionally RTEMS can be build to run inside the
>     jailhouse
>     hypervisor. Is there any interest from the RTEMS community side to
>     integrate
>     this BSP or parts of it?
>     I ask this because the hardware is kind of old and replaced by the new
>     ARMv8
>     Jetson TX2. The BSP is not published yet, but will be published on
>     GitHub in a few
>     weeks.
>     -- Andreas
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
