Jetson TK1 BSP
Joel Sherrill
joel at rtems.org
Tue Apr 11 12:28:54 UTC 2017
Awesome!
Can you separate out the Jailhouse changes, BSP changes and any other
changes?
IMO the Jailhouse support is a definite thing we would want to merge. If
you did any clean up or enhancements that are not TK1 specific, then we
would likely want to merge those. The TK1 BSP is the specific piece that
needs discussion.
Can I still but a TK1? How similar is it to followup models?
Do you know of a simulator or is real hw the only testing option?
I am certainly pro merging it if you will be the point person for
maintaining and testing it. :)
We just need to digest the pieces.
--joel
On Apr 11, 2017 4:22 AM, "Andreas Kölbl" <
andreas.koelbl at st.oth-regensburg.de> wrote:
> I successfully ported RTEMS on the Jetson TK1 board for my
> Bachelorthesis. It
> includes a GPIO, timercounter clock, a benchmark timer (yes, I wanted to
> run the
> old tmtests) and a console driver which basically is a national
> semiconductor
> 8250 implementation. Additionally RTEMS can be build to run inside the
> jailhouse
> hypervisor. Is there any interest from the RTEMS community side to
> integrate
> this BSP or parts of it?
> I ask this because the hardware is kind of old and replaced by the new
> ARMv8
> Jetson TX2. The BSP is not published yet, but will be published on
> GitHub in a few
> weeks.
> -- Andreas
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170411/6f4ab2df/attachment-0002.html>
