GSoC Mentors / Projects of Interest
Wed Feb 1 16:53:37 UTC 2017
On Tue, Jan 31, 2017 at 10:55 PM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
>> * You removed the "Introduction" section. Any reason or just an oversight?
>> * The 'status' field is gone too. But, I think the status is not
>> needed in the ticket format.
> I removed the "Introduction" section by mistake. I'll include it.
>> Did you face any difficulties in making the transition? It would be
>> good to document your workflow on the Open Projects page.
> I wikiformatted the text myself. But it would have been better if I
> had just copied the already formatted text that pops up when we try to
> edit the project page
> (https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP?action=edit).
> No difficulties as such. I'll document the workflow on the open
> projects page.
>> We should convert all of the open projects to tickets eventually. And
>> then generate a report in the Open Projects page based on the tickets.
>> I have done this for the BSP ones and found the following changes
>> should be made in the workflow:
> Could you please direct me to the tickets you created? I couldn't find
> them on Trac.
I mean that I generated the text for their description on
https://devel.rtems.org/wiki/Developer/OpenProjects#BoardSupportPackageBSP
I have not created any new tickets.
>> I knew I had bought at least one so went to Amazon to see what we
>> have here at OAR.
>> https://www.amazon.com/GearMo-Header-TTL-232R-3V3-Windows-Support/dp/B004LBXO2A
>> Other folks in the community may have alternatives. It is a pretty generic
>> piece of hardware. But there was that issue with the FTDI driver refusing
>> to work with cloned FTDI chips. So I would bet there are some out there
>> you don't want.
> I'll include the above hyperlink.
> Thanks,
> Tanu Hari Dixit.
> On Wed, Feb 1, 2017 at 4:33 AM, Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Jan 31, 2017 at 12:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Tue, Jan 31, 2017 at 12:21 PM, Tanu Hari Dixit <tokencolour at gmail.com>
>>> wrote:
>>> > Hello,
>>> > I created (https://devel.rtems.org/ticket/2891#ticket) on the lines of
>>> > Gedare's advice for this open project
>>> > (https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP).
>>> Looks nice, a few minor things:
>>> > The link to buy USB-TTL FTDI Cable 3.3V on the open project page is
>>> > probably broken. What should I replace it with? Please tell if some
>>> See if you can find something appropriate on Google?
>> have here at OAR.
>> you don't want.
>>> > edit is needed and whether I should follow this pattern. Furthermore,
>>> > please indicate whether this project is of interest. Also which other
>>> > open projects should be converted to tickets?
>>> * Use only one keyword. I prefer "SoC" so it is generic to other
>>> 'summer of code' style projects.
>>> * Use the components field to further categorize. We have some obvious
>>> ones for the subheadings now, such as 'bsps', 'libbsd', 'testing'.
>>> Others should be identified or else we can create new components if
>>> necessary. I'd like to stick with the current subheadings for this
>>> year's GSoC, but we can revise later.
>>> > Probably the community is interested in the idea to create simple
>>> > examples or sanity tests for all RTEMS directives so that they can be
>>> > included in the documentation (something that is user friendly). Also,
>>> > there was a thread titled 'Desirable Application Stacks (Add-On
>>> > Library Collections)' . Which ideas can be derived from there?
>>> > Regards,
>>> > Tanu Hari Dixit.
>>> > On Tue, Jan 31, 2017 at 4:52 AM, Joel Sherrill <joel at rtems.org> wrote:
>>> >> On Mon, Jan 30, 2017 at 5:13 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> >>> On Mon, Jan 30, 2017 at 12:25 PM, Tanu Hari Dixit
>>> >>> wrote:
>>> >>> > I'll be glad to do it. Please guide me as to how to proceed.
>>> >>> We will need to import each existing Open Project description into a
>>> >>> new ticket. It would be best to start with one to "try it out". The
>>> >>> project title should be the Summary of the ticket, the text of the
>>> >>> project page should be converted into the Description of the ticket,
>>> >>> type should be Enhancement, Milestone "Indefinite", and put GSoC into
>>> >>> the keywords, and we might want to use some other keywords e.g. to
>>> >>> define the project type (e.g. one of: testing, ecosystem, kernel,
>>> >>> statistics, BSP, API, libbsd, languages, libraries). The owner should
>>> >>> be assigned to one of the mentors if indicated, with others in CC if
>>> >>> any, or else set blank.
>>> >> I agree it would be nice to get all the Open Project ideas as tickets
>>> >> and
>>> >> off the Wiki. Some of the ideas are likely no longer interesting/valid
>>> >> at
>>> >> this point and could just be deleted.
>>> >> FWIW I also want to move some of the Wiki content into Sphinx
>>> >> documents.
>>> >> I think being able to release them with RTEMS branches and use git
>>> >> for revision control.
>>> >> --joel
>>> >>> > On Mon, Jan 30, 2017 at 9:38 PM, Gedare Bloom <gedare at rtems.org>
>>> >>> > wrote:
>>> >>> >> Yes that would be much nicer. Maybe we can get potential GSoC
>>> >>> >> Students
>>> >>> >> to do the work ;)
>>> >>> >> On Mon, Jan 30, 2017 at 1:40 AM, Sebastian Huber
>>> >>> >> <sebastian.huber at embedded-brains.de> wrote:
>>> >>> >> > Maybe we should move all this open projects wiki stuff into
>>> >>> >> > tickets
>>> >>> >> > with
>>> >>> >> > some sort of "GSoC" tag.
>>> >>> >> > Sebastian Huber, embedded brains GmbH
>>> >>> >> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> >>> >> > Phone   : +49 89 189 47 41-16
>>> >>> >> > Fax     : +49 89 189 47 41-09
>>> >>> >> > E-Mail  : sebastian.huber at embedded-brains.de
>>> >>> >> > PGP     : Public key available on request.
>>> >>> >> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>>> >>> >> > EHUG.
>>> >>> >> _______________________________________________
>>> >>> >> devel mailing list
>>> >>> >> devel at rtems.org
>>> >>> >> http://lists.rtems.org/mailman/listinfo/devel
>>> >>> devel mailing list
>>> >>> devel at rtems.org
