[PATCH 03/10] Adding LPC32XX Ethernet and USB OHCI files to script
Kevin Kirspel
kevin-kirspel at idexx.com
Mon Jan 30 16:58:17 UTC 2017
libbsd.py | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/libbsd.py b/libbsd.py
index 7264ac4..43107ee 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -148,6 +148,7 @@ def rtems(mm):
'pppd/utils.c',
'sys/dev/usb/controller/ehci_mpc83xx.c',
'sys/dev/usb/controller/ohci_lpc.c',
+ 'sys/dev/usb/controller/ohci_lpc32xx.c',
'sys/dev/usb/controller/dwc_otg_nexus.c',
'sys/dev/usb/controller/usb_otg_transceiver.c',
'sys/dev/usb/controller/usb_otg_transceiver_dump.c',
@@ -1083,6 +1084,9 @@ def dev_net(mm):
'sys/dev/dwc/if_dwc.h',
'sys/dev/dwc/if_dwcvar.h',
'sys/arm/xilinx/zy7_slcr.h',
+ 'sys/arm/lpc/if_lpereg.h',
+ 'sys/arm/lpc/lpcreg.h',
+ 'sys/arm/lpc/lpcvar.h',
mod.addKernelSpaceSourceFiles(
@@ -1101,6 +1105,8 @@ def dev_net(mm):
'sys/dev/cadence/if_cgem.c',
'sys/dev/dwc/if_dwc.c',
'sys/arm/xilinx/zy7_slcr.c',
+ 'sys/arm/lpc/lpc_pwr.c',
+ 'sys/arm/lpc/if_lpe.c',
mm.generator['source']()
1.9.1
