[PATCH 04/10] Add support for ordering the initialization of Nexus devices. This can be used to make sure a device is initialized before a dependant device.
Kevin Kirspel
kevin-kirspel at idexx.com
Mon Jan 30 16:58:18 UTC 2017
freebsd/sys/sys/linker_set.h | 6 +++++-
rtemsbsd/include/rtems/bsd/bsd.h | 6 ++++++
2 files changed, 11 insertions(+), 1 deletion(-)
mode change 100644 => 100755 freebsd/sys/sys/linker_set.h
mode change 100644 => 100755 rtemsbsd/include/rtems/bsd/bsd.h
diff --git a/freebsd/sys/sys/linker_set.h b/freebsd/sys/sys/linker_set.h
old mode 100644
new mode 100755
index 918d724..a310b06
--- a/freebsd/sys/sys/linker_set.h
+++ b/freebsd/sys/sys/linker_set.h
@@ -77,7 +77,11 @@
#define RTEMS_BSD_DEFINE_SET_ITEM(set, sym, type) \
static type const __set_##set##_sym_##sym \
- __section(".rtemsroset.bsd." __STRING(set) ".content") __used
+ __section(".rtemsroset.bsd." __STRING(set) ".content.1") __used
+#define RTEMS_BSD_DEFINE_SET_ITEM_ORDERED(set, sym, order, type) \
+ static type const __set_##set##_sym_##sym \
+ __section(".rtemsroset.bsd." __STRING(set) ".content.0." RTEMS_XSTRING( order )) __used
#define __MAKE_SET(set, sym) \
RTEMS_BSD_DEFINE_SET_ITEM(set, sym, const void *) = &sym
diff --git a/rtemsbsd/include/rtems/bsd/bsd.h b/rtemsbsd/include/rtems/bsd/bsd.h
old mode 100644
new mode 100755
index 0968062..2e89dce
--- a/rtemsbsd/include/rtems/bsd/bsd.h
+++ b/rtemsbsd/include/rtems/bsd/bsd.h
@@ -83,6 +83,12 @@ typedef struct {
{ #name, unit, (resource_count), (resources), \
&SYSINIT_ENTRY_NAME(name##_nexusmodule) }
+#define RTEMS_BSD_DEFINE_NEXUS_DEVICE_ORDERED(name, unit, order, resource_count, resources) \
+ extern struct sysinit SYSINIT_ENTRY_NAME(name##_nexusmodule); \
+ RTEMS_BSD_DEFINE_SET_ITEM_ORDERED(nexus, name##unit, order, rtems_bsd_device) = \
+ { #name, unit, (resource_count), (resources), \
+ &SYSINIT_ENTRY_NAME(name##_nexusmodule) }
rtems_status_code rtems_bsd_initialize(void);
1.9.1
