[PATCH] bsps: Improve interrupt vector enable/disable API
Mon Jun 19 14:34:00 UTC 2017
On Mon, Jun 19, 2017 at 9:19 AM, Sebastian Huber
> Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
> to not return a status code.  Add bsp_interrupt_assert() and use it to
> validate the vector number in the vector enable/disable implementations.
>  c/src/lib/libbsp/arm/beagle/irq.c                  | 12 +++---
>  c/src/lib/libbsp/arm/edb7312/irq/irq.c             | 12 +++---
>  c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c           |  8 ++--
>  c/src/lib/libbsp/arm/lpc24xx/irq/irq.c             | 10 ++---
>  c/src/lib/libbsp/arm/lpc32xx/irq/irq.c             | 49 +++++++++-------------
>  c/src/lib/libbsp/arm/raspberrypi/irq/irq.c         | 16 ++-----
>  c/src/lib/libbsp/arm/shared/arm-gic-irq.c          | 28 ++++---------
>  .../lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c  | 18 +++-----
>  c/src/lib/libbsp/arm/tms570/irq/irq.c              | 40 +++---------------
>  c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c   |  8 ++--
>  c/src/lib/libbsp/i386/pc386/timer/timer.c          |  7 +---
>  c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c |  6 ---
>  c/src/lib/libbsp/i386/shared/irq/irq.c             | 14 +++----
>  c/src/lib/libbsp/lm32/shared/irq/irq.c             |  8 ++--
>  c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c         | 44 +++++++------------
>  c/src/lib/libbsp/mips/shared/irq/irq.c             |  8 ++--
>  c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c       |  8 ++--
>  c/src/lib/libbsp/powerpc/gen5200/irq/irq.c         | 32 +++++++-------
>  c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c         | 16 +++----
>  c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c      | 12 +++---
>  c/src/lib/libbsp/powerpc/psim/irq/irq_init.c       |  8 ++--
>  c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c    |  8 ++--
>  c/src/lib/libbsp/powerpc/qoriq/irq/irq.c           | 24 +++++------
>  c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c         |  8 ++--
>  c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c          | 32 +++++++-------
>  c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c     | 32 +++++---------
>  c/src/lib/libbsp/shared/include/irq-generic.h      | 30 +++++++------
>  c/src/lib/libbsp/shared/src/irq-generic.c          | 16 +------
>  c/src/lib/libbsp/shared/src/irq-server.c           |  8 +++-
>  c/src/lib/libbsp/sparc/shared/irq/irq-shared.c     | 10 ++---
>  c/src/lib/libcpu/arm/at91rm9200/irq/irq.c          | 10 ++---
>  c/src/lib/libcpu/arm/lpc22xx/irq/irq.c             | 10 ++---
>  c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c           | 20 ++++-----
>  c/src/lib/libcpu/arm/pxa255/irq/irq.c              | 10 ++---
>  c/src/lib/libcpu/arm/s3c24xx/irq/irq.c             |  8 ++--
>  c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c         | 18 +++-----
>  36 files changed, 238 insertions(+), 370 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
> index d080a5e851..2fa1a5b0f0 100644
> --- a/c/src/lib/libbsp/arm/beagle/irq.c
> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
> @@ -95,28 +95,28 @@ static uint32_t omap_get_mir_reg(rtems_vector_number vector, uint32_t *const mas
>    return mir_reg;
> -rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
> +void bsp_interrupt_vector_enable(rtems_vector_number vector)
>    uint32_t mask, cur;
>    uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
> +  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
>    cur = mmio_read(omap_intr.base + mir_reg);
>    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
>    flush_data_cache();
> -  return RTEMS_SUCCESSFUL;
> -rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
> +void bsp_interrupt_vector_disable(rtems_vector_number vector)
>    uint32_t mask, cur;
>    mmio_write(omap_intr.base + mir_reg, cur | mask);
>    flush_data_cache();
>  rtems_status_code bsp_interrupt_facility_initialize(void)
> diff --git a/c/src/lib/libbsp/arm/edb7312/irq/irq.c b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
> index 8c18ea7abd..1d9151a1bd 100644
> --- a/c/src/lib/libbsp/arm/edb7312/irq/irq.c
> +++ b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
> @@ -27,8 +27,10 @@ void edb7312_interrupt_dispatch(rtems_vector_number vector)
>    bsp_interrupt_handler_dispatch(vector);
>      if(vector >= BSP_EXTFIQ && vector <= BSP_SSEOTI)
>          /* interrupt managed by INTMR1 and INTSR1 */
> @@ -49,12 +51,12 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>          /* interrupt managed by INTMR3 and INTSR3 */
>          *EP7312_INTMR3 |= (1 << (vector - 21));
> @@ -75,8 +77,6 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>          *EP7312_INTMR3 &= ~(1 << (vector - 21));
> diff --git a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
> index 79665b46fd..886f928d2d 100644
> --- a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
> +++ b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
> @@ -50,14 +50,14 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number vector)
>  #ifdef ARM_MULTILIB_ARCH_V4
> diff --git a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
> index 408f20db4f..7801c37843 100644
> --- a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
> +++ b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
> @@ -64,18 +64,16 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number vector)
>    VICIntEnable = 1U << vector;
>    VICIntEnClear = 1U << vector;
> diff --git a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
> index 37080f4de2..eac320000b 100755
> --- a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
> +++ b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
> @@ -50,11 +50,6 @@ static lpc32xx_irq_fields lpc32xx_irq_priority_masks [LPC32XX_IRQ_PRIORITY_COUNT
>  static lpc32xx_irq_fields lpc32xx_irq_enable;
> -static inline bool lpc32xx_irq_is_valid(rtems_vector_number vector)
> -  return vector <= BSP_INTERRUPT_VECTOR_MAX;
>  static inline bool lpc32xx_irq_priority_is_valid(unsigned priority)
>    return priority <= LPC32XX_IRQ_PRIORITY_LOWEST;
> @@ -130,7 +125,7 @@ static inline unsigned lpc32xx_irq_get_index(uint32_t val)
>  void lpc32xx_irq_set_priority(rtems_vector_number vector, unsigned priority)
> -  if (lpc32xx_irq_is_valid(vector)) {
> +  if (bsp_interrupt_is_valid_vector(vector)) {
>      rtems_interrupt_level level;
>      unsigned i = 0;
> @@ -156,7 +151,7 @@ void lpc32xx_irq_set_priority(rtems_vector_number vector, unsigned priority)
>  unsigned lpc32xx_irq_get_priority(rtems_vector_number vector)
>      return lpc32xx_irq_priority_table [vector];
>    } else {
>      return LPC32XX_IRQ_PRIORITY_LOWEST;
> @@ -165,7 +160,7 @@ unsigned lpc32xx_irq_get_priority(rtems_vector_number vector)
>  void lpc32xx_irq_set_activation_polarity(rtems_vector_number vector, lpc32xx_irq_activation_polarity activation_polarity)
>      rtems_interrupt_disable(level);
> @@ -180,7 +175,7 @@ void lpc32xx_irq_set_activation_polarity(rtems_vector_number vector, lpc32xx_irq
>  lpc32xx_irq_activation_polarity lpc32xx_irq_get_activation_polarity(rtems_vector_number vector)
>      if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_APR)) {
>        return LPC32XX_IRQ_ACTIVE_HIGH_OR_RISING_EDGE;
>      } else {
> @@ -193,7 +188,7 @@ lpc32xx_irq_activation_polarity lpc32xx_irq_get_activation_polarity(rtems_vector
>  void lpc32xx_irq_set_activation_type(rtems_vector_number vector, lpc32xx_irq_activation_type activation_type)
> @@ -208,7 +203,7 @@ void lpc32xx_irq_set_activation_type(rtems_vector_number vector, lpc32xx_irq_act
>  lpc32xx_irq_activation_type lpc32xx_irq_get_activation_type(rtems_vector_number vector)
>      if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_ATR)) {
>        return LPC32XX_IRQ_EDGE_SENSITIVE;
>      } else {
> @@ -265,32 +260,28 @@ void bsp_interrupt_dispatch(void)
>    lpc32xx.sic_2.er = er_sic_2 & lpc32xx_irq_enable.field.sic_2;
> -    rtems_interrupt_level level;
> +  rtems_interrupt_level level;
> -    rtems_interrupt_disable(level);
> -    lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
> -    lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
> -    rtems_interrupt_enable(level);
> +  rtems_interrupt_disable(level);
> +  lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
> +  lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
> +  rtems_interrupt_enable(level);
> -    lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
> -    lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
> +  lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
> +  lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>  void lpc32xx_set_exception_handler(
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
> index 48f781075b..5b10385bfe 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
> +++ b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
> @@ -139,26 +139,18 @@ void bsp_interrupt_dispatch(void)
> -  if ( vector > BSP_INTERRUPT_VECTOR_MAX )
> -    return RTEMS_INVALID_ID;
>    BCM2835_REG(bsp_vector_to_reg(vector)->enable_reg_addr) =
>                bsp_vector_to_mask(vector);
>    BCM2835_REG(bsp_vector_to_reg(vector)->disable_reg_addr) =
>  void bsp_interrupt_handler_default(rtems_vector_number vector)
> diff --git a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> index 487ee16f72..5a4a998bfb 100644
> --- a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> +++ b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> @@ -44,34 +44,22 @@ void bsp_interrupt_dispatch(void)
> -  rtems_status_code sc = RTEMS_SUCCESSFUL;
> +  volatile gic_dist *dist = ARM_GIC_DIST;
> -  if (bsp_interrupt_is_valid_vector(vector)) {
> -    volatile gic_dist *dist = ARM_GIC_DIST;
> -    gic_id_enable(dist, vector);
> -  } else {
> -    sc = RTEMS_INVALID_ID;
> -  return sc;
> +  gic_id_enable(dist, vector);
> -    gic_id_disable(dist, vector);
> -  } else {
> -  return sc;
> +  gic_id_disable(dist, vector);
>  static inline uint32_t get_id_count(volatile gic_dist *dist)
> diff --git a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
> index df17c26cdd..1d930a4591 100644
> --- a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
> +++ b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
> @@ -22,22 +22,16 @@
>  #ifdef ARM_MULTILIB_ARCH_V7M
> -    _ARMV7M_NVIC_Set_enable((int) vector);
> +  _ARMV7M_NVIC_Set_enable((int) vector);
> -    _ARMV7M_NVIC_Clear_enable((int) vector);
> +  _ARMV7M_NVIC_Clear_enable((int) vector);
> diff --git a/c/src/lib/libbsp/arm/tms570/irq/irq.c b/c/src/lib/libbsp/arm/tms570/irq/irq.c
> index 7a2a55fff5..579c11ed2a 100644
> --- a/c/src/lib/libbsp/arm/tms570/irq/irq.c
> +++ b/c/src/lib/libbsp/arm/tms570/irq/irq.c
> @@ -28,24 +28,6 @@
>  #include <bsp/irq.h>
>  #include <rtems/score/armv4.h>
> - * @brief Check if isr vector is valid
> - * Check if isr vector is valid by using BSP_INTERRUPT_VECTOR_MAX and
> - * BSP_INTERRUPT_VECTOR_MIN defined in irq.h
> - * @param[in] vector interrupt vector to be checked.
> - * @retval TRUE vector is valid.
> - * @retval FALSE vector is invalid
> -static inline bool tms570_irq_is_valid(
> -  rtems_vector_number vector
> -  return (vector <= BSP_INTERRUPT_VECTOR_MAX) &&
> -         (vector > BSP_INTERRUPT_VECTOR_MIN);
>  unsigned int priorityTable[BSP_INTERRUPT_VECTOR_MAX+1];
> @@ -64,7 +46,7 @@ void tms570_irq_set_priority(
>    unsigned priority
> -  if ( tms570_irq_is_valid(vector) ) {
> +  if ( bsp_interrupt_is_valid_vector(vector) ) {
>      priorityTable[vector] = priority;
> @@ -84,7 +66,7 @@ unsigned tms570_irq_get_priority(
>     return priorityTable[vector];
>   return 0;
> @@ -114,17 +96,12 @@ void bsp_interrupt_dispatch(void)
>   * @retval RTEMS_INVALID_ID vector is invalid.
>   * @retval RTEMS_SUCCESSFUL interrupt source enabled.
> -  if( !tms570_irq_is_valid(vector) ) {
>    TMS570_VIM.REQENASET[vector >> 5] = 1 << (vector & 0x1f);
> @@ -136,17 +113,12 @@ rtems_status_code bsp_interrupt_vector_enable(
>   * @retval RTEMS_SUCCESSFUL interrupt source disabled.
>    TMS570_VIM.REQENACLR[vector >> 5] = 1 << (vector & 0x1f);
> diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
> index 057a0f7e81..994e25bf0e 100644
> --- a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
> +++ b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
> @@ -53,12 +53,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
>    return 0;
> -  return 0;
> -  return 0;
> diff --git a/c/src/lib/libbsp/i386/pc386/timer/timer.c b/c/src/lib/libbsp/i386/pc386/timer/timer.c
> index 5bef139d38..16d3d66176 100644
> --- a/c/src/lib/libbsp/i386/pc386/timer/timer.c
> +++ b/c/src/lib/libbsp/i386/pc386/timer/timer.c
> @@ -153,17 +153,12 @@ static void timerOn(const rtems_raw_irq_connect_data* used)
>    bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
> -static int timerIsOn(const rtems_raw_irq_connect_data *used)
> -  return bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
>  static rtems_raw_irq_connect_data timer_raw_irq_data = {
>    BSP_PERIODIC_TIMER + BSP_IRQ_VECTOR_BASE,
>    timerisr,
>    timerOn,
>    timerOff,
> -  timerIsOn
> +  NULL
> diff --git a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
> index 7802270140..d47d057860 100644
> --- a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
> +++ b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
> @@ -173,11 +173,6 @@ static void BSP_uart_off(const rtems_raw_irq_connect_data* used)
>    bsp_interrupt_vector_disable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
> -static int BSP_uart_isOn(const rtems_raw_irq_connect_data* used)
>   * In order to have a possibility to break into
>   * running program, one has to call this function
> @@ -210,7 +205,6 @@ void i386_stub_glue_init_breakin(void)
>      uart_raw_irq_data.on  = BSP_uart_on;
>      uart_raw_irq_data.off = BSP_uart_off;
> -    uart_raw_irq_data.isOn= BSP_uart_isOn;
>      /* Install ISR  */
>      uart_raw_irq_data.idtIndex = port_current->ulIntVector + BSP_IRQ_VECTOR_BASE;
> diff --git a/c/src/lib/libbsp/i386/shared/irq/irq.c b/c/src/lib/libbsp/i386/shared/irq/irq.c
> index f4ffd8c0e4..ac08f1f7be 100644
> --- a/c/src/lib/libbsp/i386/shared/irq/irq.c
> +++ b/c/src/lib/libbsp/i386/shared/irq/irq.c
> @@ -270,18 +270,16 @@ static inline bool bsp_interrupt_vector_is_valid(rtems_vector_number vector)
>    return BSP_i8259a_irq_valid((const rtems_irq_number) vector);
> -  if (bsp_interrupt_vector_is_valid(vector))
> -    BSP_irq_enable_at_i8259a(vector);
> +  BSP_irq_enable_at_i8259a(vector);
> -    BSP_irq_disable_at_i8259a(vector);
> +  BSP_irq_disable_at_i8259a(vector);
> diff --git a/c/src/lib/libbsp/lm32/shared/irq/irq.c b/c/src/lib/libbsp/lm32/shared/irq/irq.c
> index 8f9bfaf1ac..79626ee449 100644
> --- a/c/src/lib/libbsp/lm32/shared/irq/irq.c
> +++ b/c/src/lib/libbsp/lm32/shared/irq/irq.c
> @@ -17,14 +17,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>    lm32_interrupt_unmask(1 << vector);
>    lm32_interrupt_mask(1 << vector);
> diff --git a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
> index 58e904426a..f02231b67c 100644
> --- a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
> +++ b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
> @@ -59,42 +59,30 @@ static rtems_vector_number vector_to_exception_vector(
>    return vector + 64U;
> +  volatile uint32_t *imr = vector_to_imr(vector);
> +  uint32_t bit = vector_to_bit(vector);
> -    volatile uint32_t *imr = vector_to_imr(vector);
> -    uint32_t bit = vector_to_bit(vector);
> -    *imr &= ~bit;
> -  } else {
> -  return sc;
> +  *imr &= ~bit;
> -    *imr |= bit;
> -  } else {
> -  return sc;
> +  *imr |= bit;
>  static void_func get_exception_handler(rtems_vector_number vector)
> diff --git a/c/src/lib/libbsp/mips/shared/irq/irq.c b/c/src/lib/libbsp/mips/shared/irq/irq.c
> index d4941763bc..1c2d3b8c5b 100644
> --- a/c/src/lib/libbsp/mips/shared/irq/irq.c
> +++ b/c/src/lib/libbsp/mips/shared/irq/irq.c
> @@ -67,14 +67,14 @@ static inline bool bsp_irq_is_valid(rtems_vector_number vector)
> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
> index 00d53d7409..f9a7b6426d 100644
> --- a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
> +++ b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
> @@ -32,12 +32,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
>    return 0;
> -  return 0;
> -  return 0;
> diff --git a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
> index 029ed3182e..58e2f2a987 100644
> --- a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
> +++ b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
> @@ -359,24 +359,26 @@ static inline void BSP_disable_crit_irq_at_siu( rtems_vector_number
>   * This function enables a given siu interrupt
> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqLine)
> +void bsp_interrupt_vector_enable( rtems_vector_number vector)
> -  int base_index = get_siu_irq_base_index( irqLine);
> +  int base_index = get_siu_irq_base_index( vector);
> -  if (is_siu_irq( irqLine)) {
> +  if (is_siu_irq( vector)) {
>      rtems_interrupt_disable( level);
>      switch (base_index) {
>        case BSP_PER_IRQ_LOWEST_OFFSET:
> -        BSP_enable_per_irq_at_siu( irqLine);
> +        BSP_enable_per_irq_at_siu( vector);
>          break;
>        case BSP_MAIN_IRQ_LOWEST_OFFSET:
> -        BSP_enable_main_irq_at_siu( irqLine);
> +        BSP_enable_main_irq_at_siu( vector);
>          break;
>        case BSP_CRIT_IRQ_LOWEST_OFFSET:
> -        BSP_enable_crit_irq_at_siu( irqLine);
> +        BSP_enable_crit_irq_at_siu( vector);
>          break;
>        default:
>          rtems_interrupt_enable( level);
> @@ -386,31 +388,31 @@ rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqLine)
>   * This function disables a given siu interrupt
> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqLine)
> +void bsp_interrupt_vector_disable( rtems_vector_number vector)
> -        BSP_disable_per_irq_at_siu( irqLine);
> +        BSP_disable_per_irq_at_siu( vector);
>          break;
> -        BSP_disable_main_irq_at_siu( irqLine);
> +        BSP_disable_main_irq_at_siu( vector);
>          break;
> -        BSP_disable_crit_irq_at_siu( irqLine);
> +        BSP_disable_crit_irq_at_siu( vector);
>          break;
>        default:
> @@ -420,8 +422,6 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqLine)
>  #if (BENCHMARK_IRQ_PROCESSING == 0)
> diff --git a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
> index 2d89cfa137..7a8ce3cc0b 100644
> --- a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
> +++ b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
> @@ -376,11 +376,13 @@ rtems_status_code mpc83xx_ipic_set_highest_priority_interrupt(
>   * functions to enable/disable a source at the ipic
> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
> -  rtems_vector_number vecnum = irqnum - BSP_IPIC_IRQ_LOWEST_OFFSET;
> +  rtems_vector_number vecnum = vector - BSP_IPIC_IRQ_LOWEST_OFFSET;
>    const BSP_isrc_rsc_t *rsc_ptr;
>    if (MPC83XX_IPIC_IS_VALID_VECTOR( vecnum)) {
>      rsc_ptr = &mpc83xx_ipic_isrc_rsc [vecnum];
>      if (rsc_ptr->mask_reg != NULL) {
> @@ -392,15 +394,15 @@ rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
> @@ -412,8 +414,6 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
> diff --git a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
> index 52465ec2a7..c145186a52 100644
> --- a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
> +++ b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
> @@ -328,28 +328,28 @@ BSP_CPM_irq_init(void)
> +void bsp_interrupt_vector_enable( rtems_vector_number irqnum)
>    if (is_cpm_irq(irqnum)) {
>       * Enable interrupt at PIC level
>      BSP_irq_enable_at_cpm (irqnum);
> +void bsp_interrupt_vector_disable( rtems_vector_number irqnum)
>       * disable interrupt at PIC level
>      BSP_irq_disable_at_cpm (irqnum);
> diff --git a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
> index 59f0e1dcea..61600a9d62 100644
> --- a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
> +++ b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
> @@ -102,16 +102,16 @@ static int psim_exception_handler(
>    /* FIXME: do something */
> diff --git a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
> index f4592a375f..b5533e0872 100644
> --- a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
> +++ b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
> @@ -38,16 +38,16 @@ static int qemuppc_exception_handler(
> diff --git a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
> index da7def3913..ea086215fc 100644
> --- a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
> +++ b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
> @@ -175,28 +175,24 @@ rtems_status_code qoriq_pic_set_affinity(
>  static rtems_status_code pic_vector_enable(rtems_vector_number vector, uint32_t msk)
> -               volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
> -               rtems_interrupt_lock_context lock_context;
> +       volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
> +       rtems_interrupt_lock_context lock_context;
> -               rtems_interrupt_lock_acquire(&lock, &lock_context);
> -               src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
> -               rtems_interrupt_lock_release(&lock, &lock_context);
> -       return sc;
> +       rtems_interrupt_lock_acquire(&lock, &lock_context);
> +       src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
> +       rtems_interrupt_lock_release(&lock, &lock_context);
> -       return pic_vector_enable(vector, 0);
> +       pic_vector_enable(vector, 0);
> -       return pic_vector_enable(vector, VPR_MSK);
> +       pic_vector_enable(vector, VPR_MSK);
>  static void qoriq_interrupt_dispatch(void)
> diff --git a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
> index 3cabcdef35..0c98c3a27d 100644
> --- a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
> +++ b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
> @@ -14,14 +14,14 @@
>  #include <bsp/irq-generic.h>
> diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
> index 8066a7f43b..2a94c27d1b 100644
> --- a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
> +++ b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
> @@ -63,30 +63,26 @@ static rtems_status_code bsp_irq_enable_at_CPM(rtems_vector_number irqnum)
> -  if (BSP_IS_CPM_IRQ(irqnum)) {
> -    bsp_irq_enable_at_CPM(irqnum);
> -  else if (BSP_IS_SIU_IRQ(irqnum)) {
> -    bsp_irq_enable_at_SIU(irqnum);
> +  if (BSP_IS_CPM_IRQ(vector)) {
> +    bsp_irq_enable_at_CPM(vector);
> +  } else if (BSP_IS_SIU_IRQ(vector)) {
> +    bsp_irq_enable_at_SIU(vector);
> -    bsp_irq_disable_at_CPM(irqnum);
> -    bsp_irq_disable_at_SIU(irqnum);
> +    bsp_irq_disable_at_CPM(vector);
> +    bsp_irq_disable_at_SIU(vector);
> diff --git a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
> index a9fe7066bc..55194cb1e6 100644
> --- a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
> +++ b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
> @@ -132,34 +132,22 @@ static void opb_intc_init(void)
>      (OPB_INTC_MER_HIE | OPB_INTC_MER_ME);
> -    if (BSP_IS_OPBINTC_IRQ(vector)) {
> -      BSP_irq_enable_at_opbintc(vector);
> -  } else {
> -  return sc;
> +  if (BSP_IS_OPBINTC_IRQ(vector)) {
> +    BSP_irq_enable_at_opbintc(vector);
> -      BSP_irq_disable_at_opbintc(vector);
> -  } else {
> -  return sc;
> +    BSP_irq_disable_at_opbintc(vector);
>  static int C_dispatch_irq_handler(BSP_Exception_frame *frame, unsigned int excNum)
> diff --git a/c/src/lib/libbsp/shared/include/irq-generic.h b/c/src/lib/libbsp/shared/include/irq-generic.h
> index 4e89d74ab3..187aea84d1 100644
> --- a/c/src/lib/libbsp/shared/include/irq-generic.h
> +++ b/c/src/lib/libbsp/shared/include/irq-generic.h
> @@ -9,7 +9,7 @@
>   * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
> - * Copyright (c) 2008-2014 embedded brains GmbH.
> + * Copyright (c) 2008, 2017 embedded brains GmbH.
>   *  embedded brains GmbH
>   *  Dornierstr. 4
> @@ -30,6 +30,7 @@
>  #include <stdbool.h>
>  #include <rtems/irq-extension.h>
> +#include <rtems/score/assert.h>
>  #ifdef RTEMS_SMP
>    #include <rtems/score/atomic.h>
> @@ -71,6 +72,8 @@ extern "C" {
>    #define bsp_interrupt_fence(order) do { } while (0)
>  #endif
> +#define bsp_interrupt_assert(e) _Assert(e)
doxygen?
I don't quite see how using an assert fixes the problem being faced by
the use of the pseudo-isr, since this vector number would trip the
assert? Maybe I missed something.
>  struct bsp_interrupt_handler_entry {
>    rtems_interrupt_handler handler;
>    void *arg;
> @@ -215,32 +218,33 @@ rtems_status_code bsp_interrupt_facility_initialize(void);
>   * This function shall enable the vector at the corresponding facility (in most
>   * cases the interrupt controller).  It will be called then the first handler
s/then/when
> - * is installed for the vector in bsp_interrupt_handler_install().  It is
> - * guaranteed that the vector number is within the BSP_INTERRUPT_VECTOR_MIN and
> - * BSP_INTERRUPT_VECTOR_MAX range.
> + * is installed for the vector in bsp_interrupt_handler_install() for example.
> + * @note The implementation should use
> + * bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector)) to valdiate the
typo: validate
> + * vector number.
>   * @note You must not install or remove an interrupt handler in this function.
>   * This may result in a deadlock.
> - * @return On success RTEMS_SUCCESSFUL shall be returned.
> -rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector);
> +void bsp_interrupt_vector_enable(rtems_vector_number vector);
>   * @brief Disables the interrupt vector with number @a vector.
>   * This function shall disable the vector at the corresponding facility (in
>   * most cases the interrupt controller).  It will be called then the last
> - * handler is removed for the vector in bsp_interrupt_handler_remove().  It is
> + * handler is removed for the vector in bsp_interrupt_handler_remove() for
> + * example.
ditto
> + * vector number.
> -rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector);
> +void bsp_interrupt_vector_disable(rtems_vector_number vector);
>   * @brief Sequencially calls all interrupt handlers for the vector number @a
> diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c b/c/src/lib/libbsp/shared/src/irq-generic.c
> index b2a7ced64c..7f943d96cb 100755
> --- a/c/src/lib/libbsp/shared/src/irq-generic.c
> +++ b/c/src/lib/libbsp/shared/src/irq-generic.c
> @@ -207,7 +207,6 @@ static rtems_status_code bsp_interrupt_handler_install(
>    void *arg
>    rtems_vector_number index = 0;
>    bsp_interrupt_handler_entry *head = NULL;
> @@ -346,11 +345,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>    /* Enable the vector if necessary */
>    if (enable_vector) {
> -    sc = bsp_interrupt_vector_enable(vector);
> -    if (sc != RTEMS_SUCCESSFUL) {
> -      bsp_interrupt_unlock();
> -      return sc;
> +    bsp_interrupt_vector_enable(vector);
>    /* Unlock */
> @@ -375,7 +370,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
>    void *arg
> @@ -446,7 +440,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
>        /* Disable the vector */
> -      sc = bsp_interrupt_vector_disable(vector);
> +      bsp_interrupt_vector_disable(vector);
>        /* Clear entry */
>        bsp_interrupt_disable(level);
> @@ -458,12 +452,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
>        /* Allow shared handlers */
>        bsp_interrupt_set_handler_unique(index, false);
> -      /* Check status code */
> -        return sc;
>      } else {
>         * The match is the list tail and has a predecessor.
> diff --git a/c/src/lib/libbsp/shared/src/irq-server.c b/c/src/lib/libbsp/shared/src/irq-server.c
> index 905c26198b..9a3ca9abf1 100644
> --- a/c/src/lib/libbsp/shared/src/irq-server.c
> +++ b/c/src/lib/libbsp/shared/src/irq-server.c
> @@ -56,7 +56,9 @@ static void bsp_interrupt_server_trigger(void *arg)
>    rtems_interrupt_server_entry *e = arg;
> -  bsp_interrupt_vector_disable(e->vector);
> +  if (bsp_interrupt_is_valid_vector(e->vector)) {
> +    bsp_interrupt_vector_disable(e->vector);
>    rtems_interrupt_lock_acquire(&bsp_interrupt_server_lock, &lock_context);
> @@ -324,7 +326,9 @@ static void bsp_interrupt_server_task(rtems_task_argument arg)
>          (*current->handler)(current->arg);
>        } while (action != NULL);
> -      bsp_interrupt_vector_enable(vector);
> diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> index f219e49f45..344ed71a34 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> +++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> @@ -70,20 +70,18 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>    int irq = (int)vector;
>    BSP_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
>    BSP_Cpu_Mask_interrupt(irq, bsp_irq_cpu(irq));
>  void BSP_shared_interrupt_mask(int irq)
> diff --git a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
> index 9ecdacfbb7..95e93845b9 100644
> --- a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
> +++ b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
> @@ -27,18 +27,16 @@ void bsp_interrupt_dispatch(void)
>    AIC_CTL_REG(AIC_EOICR) = 0;
>    AIC_CTL_REG(AIC_IECR) = 1 << vector;
>    AIC_CTL_REG(AIC_IDCR) = 1 << vector;
> diff --git a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
> index 851705bee2..83e140bd7b 100644
> --- a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
> +++ b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
> @@ -26,18 +26,16 @@ void bsp_interrupt_dispatch(void)
>    VICVectAddr = 0;
>    VICIntEnable |= 1 << vector;
>    VICIntEnClr = 1 << vector;
> diff --git a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
> index 2d6e34d274..e5887b9717 100644
> --- a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
> +++ b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
> @@ -26,24 +26,20 @@ void bsp_interrupt_dispatch(void)
> -  if (vector >= MC9328MXL_NUM_INTS)
> -  MC9328MXL_AITC_INTENNUM = vector;
> +  if (vector < MC9328MXL_NUM_INTS)
> +    MC9328MXL_AITC_INTENNUM = vector;
> -  MC9328MXL_AITC_INTDISNUM = vector;
> +    MC9328MXL_AITC_INTDISNUM = vector;
> diff --git a/c/src/lib/libcpu/arm/pxa255/irq/irq.c b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
> index 8b46ce149c..425795b165 100644
> --- a/c/src/lib/libcpu/arm/pxa255/irq/irq.c
> +++ b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
> @@ -24,18 +24,16 @@ void bsp_interrupt_dispatch(void)
>    XSCALE_INT_ICMR |= 1 << vector;
>    XSCALE_INT_ICMR  &= ~(1 << vector);
> diff --git a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
> index dce6c383b9..ea8f610353 100644
> --- a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
> +++ b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
> @@ -27,14 +27,14 @@ void bsp_interrupt_dispatch(void)
> diff --git a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
> index 59b2c39c59..789a19a490 100644
> --- a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
> +++ b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
> @@ -180,20 +180,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector)
> -       if (MPC55XX_IRQ_IS_VALID( vector)) {
> -               return mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DEFAULT_PRIORITY);
> -       } else {
> +       mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DEFAULT_PRIORITY);
> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector)
> -               return mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DISABLED_PRIORITY);
> -       } else {
> +       mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DISABLED_PRIORITY);
> 2.12.3
> devel mailing list
> devel at rtems.org
