[PATCH] bsps: Improve interrupt vector enable/disable API
Mon Jun 19 23:25:24 UTC 2017
On Mon, Jun 19, 2017 at 2:45 PM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> ----- Ursprüngliche Mail -----
>> Von: "Gedare Bloom" <gedare at rtems.org>
>> An: "Sebastian Huber" <sebastian.huber at embedded-brains.de>
>> CC: "RTEMS Devel" <rtems-devel at rtems.org>
>> Gesendet: Montag, 19. Juni 2017 16:34:00
>> Betreff: Re: [PATCH] bsps: Improve interrupt vector enable/disable API
>> On Mon, Jun 19, 2017 at 9:19 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
>>> to not return a status code.  Add bsp_interrupt_assert() and use it to
>>> validate the vector number in the vector enable/disable implementations.
>>>  c/src/lib/libbsp/arm/beagle/irq.c                  | 12 +++---
>>>  c/src/lib/libbsp/arm/edb7312/irq/irq.c             | 12 +++---
>>>  c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c           |  8 ++--
>>>  c/src/lib/libbsp/arm/lpc24xx/irq/irq.c             | 10 ++---
>>>  c/src/lib/libbsp/arm/lpc32xx/irq/irq.c             | 49 +++++++++-------------
>>>  c/src/lib/libbsp/arm/raspberrypi/irq/irq.c         | 16 ++-----
>>>  c/src/lib/libbsp/arm/shared/arm-gic-irq.c          | 28 ++++---------
>>>  .../lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c  | 18 +++-----
>>>  c/src/lib/libbsp/arm/tms570/irq/irq.c              | 40 +++---------------
>>>  c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c   |  8 ++--
>>>  c/src/lib/libbsp/i386/pc386/timer/timer.c          |  7 +---
>>>  c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c |  6 ---
>>>  c/src/lib/libbsp/i386/shared/irq/irq.c             | 14 +++----
>>>  c/src/lib/libbsp/lm32/shared/irq/irq.c             |  8 ++--
>>>  c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c         | 44 +++++++------------
>>>  c/src/lib/libbsp/mips/shared/irq/irq.c             |  8 ++--
>>>  c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c       |  8 ++--
>>>  c/src/lib/libbsp/powerpc/gen5200/irq/irq.c         | 32 +++++++-------
>>>  c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c         | 16 +++----
>>>  c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c      | 12 +++---
>>>  c/src/lib/libbsp/powerpc/psim/irq/irq_init.c       |  8 ++--
>>>  c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c    |  8 ++--
>>>  c/src/lib/libbsp/powerpc/qoriq/irq/irq.c           | 24 +++++------
>>>  c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c         |  8 ++--
>>>  c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c          | 32 +++++++-------
>>>  c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c     | 32 +++++---------
>>>  c/src/lib/libbsp/shared/include/irq-generic.h      | 30 +++++++------
>>>  c/src/lib/libbsp/shared/src/irq-generic.c          | 16 +------
>>>  c/src/lib/libbsp/shared/src/irq-server.c           |  8 +++-
>>>  c/src/lib/libbsp/sparc/shared/irq/irq-shared.c     | 10 ++---
>>>  c/src/lib/libcpu/arm/at91rm9200/irq/irq.c          | 10 ++---
>>>  c/src/lib/libcpu/arm/lpc22xx/irq/irq.c             | 10 ++---
>>>  c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c           | 20 ++++-----
>>>  c/src/lib/libcpu/arm/pxa255/irq/irq.c              | 10 ++---
>>>  c/src/lib/libcpu/arm/s3c24xx/irq/irq.c             |  8 ++--
>>>  c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c         | 18 +++-----
>>>  36 files changed, 238 insertions(+), 370 deletions(-)
>>> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c
>>> b/c/src/lib/libbsp/arm/beagle/irq.c
>>> index d080a5e851..2fa1a5b0f0 100644
>>> --- a/c/src/lib/libbsp/arm/beagle/irq.c
>>> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
>>> @@ -95,28 +95,28 @@ static uint32_t omap_get_mir_reg(rtems_vector_number vector,
>>> uint32_t *const mas
>>>    return mir_reg;
>>> -rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>>> +void bsp_interrupt_vector_enable(rtems_vector_number vector)
>>>    uint32_t mask, cur;
>>>    uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
>>> +  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
>>>    cur = mmio_read(omap_intr.base + mir_reg);
>>>    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
>>>    flush_data_cache();
>>> -  return RTEMS_SUCCESSFUL;
>>> -rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>>> +void bsp_interrupt_vector_disable(rtems_vector_number vector)
>>>    uint32_t mask, cur;
>>>    mmio_write(omap_intr.base + mir_reg, cur | mask);
>>>    flush_data_cache();
>>>  rtems_status_code bsp_interrupt_facility_initialize(void)
>>> diff --git a/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>>> b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>>> index 8c18ea7abd..1d9151a1bd 100644
>>> --- a/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>>> +++ b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>>> @@ -27,8 +27,10 @@ void edb7312_interrupt_dispatch(rtems_vector_number vector)
>>>    bsp_interrupt_handler_dispatch(vector);
>>>      if(vector >= BSP_EXTFIQ && vector <= BSP_SSEOTI)
>>>          /* interrupt managed by INTMR1 and INTSR1 */
>>> @@ -49,12 +51,12 @@ rtems_status_code
>>>          /* interrupt managed by INTMR3 and INTSR3 */
>>>          *EP7312_INTMR3 |= (1 << (vector - 21));
>>> @@ -75,8 +77,6 @@ rtems_status_code
>>>          *EP7312_INTMR3 &= ~(1 << (vector - 21));
>>> diff --git a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>>> b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>>> index 79665b46fd..886f928d2d 100644
>>> --- a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>>> +++ b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>>> @@ -50,14 +50,14 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number
>>> vector)
>>>  #ifdef ARM_MULTILIB_ARCH_V4
>>> diff --git a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>>> b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>>> index 408f20db4f..7801c37843 100644
>>> --- a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>>> +++ b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>>> @@ -64,18 +64,16 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number
>>> vector)
>>>    VICIntEnable = 1U << vector;
>>>    VICIntEnClear = 1U << vector;
>>> diff --git a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>>> b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>>> index 37080f4de2..eac320000b 100755
>>> --- a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>>> +++ b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>>> @@ -50,11 +50,6 @@ static lpc32xx_irq_fields lpc32xx_irq_priority_masks
>>> [LPC32XX_IRQ_PRIORITY_COUNT
>>>  static lpc32xx_irq_fields lpc32xx_irq_enable;
>>> -static inline bool lpc32xx_irq_is_valid(rtems_vector_number vector)
>>> -  return vector <= BSP_INTERRUPT_VECTOR_MAX;
>>>  static inline bool lpc32xx_irq_priority_is_valid(unsigned priority)
>>>    return priority <= LPC32XX_IRQ_PRIORITY_LOWEST;
>>> @@ -130,7 +125,7 @@ static inline unsigned lpc32xx_irq_get_index(uint32_t val)
>>>  void lpc32xx_irq_set_priority(rtems_vector_number vector, unsigned priority)
>>> -  if (lpc32xx_irq_is_valid(vector)) {
>>> +  if (bsp_interrupt_is_valid_vector(vector)) {
>>>      rtems_interrupt_level level;
>>>      unsigned i = 0;
>>> @@ -156,7 +151,7 @@ void lpc32xx_irq_set_priority(rtems_vector_number vector,
>>> unsigned priority)
>>>  unsigned lpc32xx_irq_get_priority(rtems_vector_number vector)
>>>      return lpc32xx_irq_priority_table [vector];
>>>    } else {
>>>      return LPC32XX_IRQ_PRIORITY_LOWEST;
>>> @@ -165,7 +160,7 @@ unsigned lpc32xx_irq_get_priority(rtems_vector_number
>>> vector)
>>>  void lpc32xx_irq_set_activation_polarity(rtems_vector_number vector,
>>>  lpc32xx_irq_activation_polarity activation_polarity)
>>>      rtems_interrupt_disable(level);
>>> @@ -180,7 +175,7 @@ void lpc32xx_irq_set_activation_polarity(rtems_vector_number
>>> vector, lpc32xx_irq
>>>  lpc32xx_irq_get_activation_polarity(rtems_vector_number vector)
>>>      if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_APR)) {
>>>        return LPC32XX_IRQ_ACTIVE_HIGH_OR_RISING_EDGE;
>>>      } else {
>>> @@ -193,7 +188,7 @@ lpc32xx_irq_activation_polarity
>>>  void lpc32xx_irq_set_activation_type(rtems_vector_number vector,
>>>  lpc32xx_irq_activation_type activation_type)
>>> @@ -208,7 +203,7 @@ void lpc32xx_irq_set_activation_type(rtems_vector_number
>>> vector, lpc32xx_irq_act
>>>  lpc32xx_irq_activation_type lpc32xx_irq_get_activation_type(rtems_vector_number
>>>  vector)
>>>      if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_ATR)) {
>>>        return LPC32XX_IRQ_EDGE_SENSITIVE;
>>>      } else {
>>> @@ -265,32 +260,28 @@ void bsp_interrupt_dispatch(void)
>>>    lpc32xx.sic_2.er = er_sic_2 & lpc32xx_irq_enable.field.sic_2;
>>> -    rtems_interrupt_level level;
>>> +  rtems_interrupt_level level;
>>> -    rtems_interrupt_disable(level);
>>> -    lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>>> -    lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
>>> -    rtems_interrupt_enable(level);
>>> +  rtems_interrupt_disable(level);
>>> +  lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>>> +  lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
>>> +  rtems_interrupt_enable(level);
>>> -    lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
>>> -    lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>>> +  lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
>>> +  lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>>>  void lpc32xx_set_exception_handler(
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>>> b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>>> index 48f781075b..5b10385bfe 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>>> @@ -139,26 +139,18 @@ void bsp_interrupt_dispatch(void)
>>> -  if ( vector > BSP_INTERRUPT_VECTOR_MAX )
>>> -    return RTEMS_INVALID_ID;
>>>    BCM2835_REG(bsp_vector_to_reg(vector)->enable_reg_addr) =
>>>                bsp_vector_to_mask(vector);
>>>    BCM2835_REG(bsp_vector_to_reg(vector)->disable_reg_addr) =
>>>  void bsp_interrupt_handler_default(rtems_vector_number vector)
>>> diff --git a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>>> b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>>> index 487ee16f72..5a4a998bfb 100644
>>> --- a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>>> +++ b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>>> @@ -44,34 +44,22 @@ void bsp_interrupt_dispatch(void)
>>> -  rtems_status_code sc = RTEMS_SUCCESSFUL;
>>> +  volatile gic_dist *dist = ARM_GIC_DIST;
>>> -  if (bsp_interrupt_is_valid_vector(vector)) {
>>> -    volatile gic_dist *dist = ARM_GIC_DIST;
>>> -    gic_id_enable(dist, vector);
>>> -  } else {
>>> -    sc = RTEMS_INVALID_ID;
>>> -  return sc;
>>> +  gic_id_enable(dist, vector);
>>> -    gic_id_disable(dist, vector);
>>> -  } else {
>>> -  return sc;
>>> +  gic_id_disable(dist, vector);
>>>  static inline uint32_t get_id_count(volatile gic_dist *dist)
>>> diff --git a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>>> b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>>> index df17c26cdd..1d930a4591 100644
>>> --- a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>>> +++ b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>>> @@ -22,22 +22,16 @@
>>>  #ifdef ARM_MULTILIB_ARCH_V7M
>>> -    _ARMV7M_NVIC_Set_enable((int) vector);
>>> +  _ARMV7M_NVIC_Set_enable((int) vector);
>>> -    _ARMV7M_NVIC_Clear_enable((int) vector);
>>> +  _ARMV7M_NVIC_Clear_enable((int) vector);
>>> diff --git a/c/src/lib/libbsp/arm/tms570/irq/irq.c
>>> b/c/src/lib/libbsp/arm/tms570/irq/irq.c
>>> index 7a2a55fff5..579c11ed2a 100644
>>> --- a/c/src/lib/libbsp/arm/tms570/irq/irq.c
>>> +++ b/c/src/lib/libbsp/arm/tms570/irq/irq.c
>>> @@ -28,24 +28,6 @@
>>>  #include <bsp/irq.h>
>>>  #include <rtems/score/armv4.h>
>>> - * @brief Check if isr vector is valid
>>> - * Check if isr vector is valid by using BSP_INTERRUPT_VECTOR_MAX and
>>> - * BSP_INTERRUPT_VECTOR_MIN defined in irq.h
>>> - * @param[in] vector interrupt vector to be checked.
>>> - * @retval TRUE vector is valid.
>>> - * @retval FALSE vector is invalid
>>> -static inline bool tms570_irq_is_valid(
>>> -  rtems_vector_number vector
>>> -  return (vector <= BSP_INTERRUPT_VECTOR_MAX) &&
>>> -         (vector > BSP_INTERRUPT_VECTOR_MIN);
>>>  unsigned int priorityTable[BSP_INTERRUPT_VECTOR_MAX+1];
>>> @@ -64,7 +46,7 @@ void tms570_irq_set_priority(
>>>    unsigned priority
>>> -  if ( tms570_irq_is_valid(vector) ) {
>>> +  if ( bsp_interrupt_is_valid_vector(vector) ) {
>>>      priorityTable[vector] = priority;
>>> @@ -84,7 +66,7 @@ unsigned tms570_irq_get_priority(
>>>     return priorityTable[vector];
>>>   return 0;
>>> @@ -114,17 +96,12 @@ void bsp_interrupt_dispatch(void)
>>>   * @retval RTEMS_INVALID_ID vector is invalid.
>>>   * @retval RTEMS_SUCCESSFUL interrupt source enabled.
>>> -  if( !tms570_irq_is_valid(vector) ) {
>>>    TMS570_VIM.REQENASET[vector >> 5] = 1 << (vector & 0x1f);
>>> @@ -136,17 +113,12 @@ rtems_status_code bsp_interrupt_vector_enable(
>>>   * @retval RTEMS_SUCCESSFUL interrupt source disabled.
>>>    TMS570_VIM.REQENACLR[vector >> 5] = 1 << (vector & 0x1f);
>>> diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>>> b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>>> index 057a0f7e81..994e25bf0e 100644
>>> --- a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>>> +++ b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>>> @@ -53,12 +53,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
>>>    return 0;
>>> -  return 0;
>>> -  return 0;
>>> diff --git a/c/src/lib/libbsp/i386/pc386/timer/timer.c
>>> b/c/src/lib/libbsp/i386/pc386/timer/timer.c
>>> index 5bef139d38..16d3d66176 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/timer/timer.c
>>> +++ b/c/src/lib/libbsp/i386/pc386/timer/timer.c
>>> @@ -153,17 +153,12 @@ static void timerOn(const rtems_raw_irq_connect_data*
>>> used)
>>>    bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
>>> -static int timerIsOn(const rtems_raw_irq_connect_data *used)
>>> -  return bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
>>>  static rtems_raw_irq_connect_data timer_raw_irq_data = {
>>>    BSP_PERIODIC_TIMER + BSP_IRQ_VECTOR_BASE,
>>>    timerisr,
>>>    timerOn,
>>>    timerOff,
>>> -  timerIsOn
>>> +  NULL
>>> diff --git a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>>> b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>>> index 7802270140..d47d057860 100644
>>> --- a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>>> +++ b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>>> @@ -173,11 +173,6 @@ static void BSP_uart_off(const rtems_raw_irq_connect_data*
>>> used)
>>>    bsp_interrupt_vector_disable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
>>> -static int BSP_uart_isOn(const rtems_raw_irq_connect_data* used)
>>>   * In order to have a possibility to break into
>>>   * running program, one has to call this function
>>> @@ -210,7 +205,6 @@ void i386_stub_glue_init_breakin(void)
>>>      uart_raw_irq_data.on  = BSP_uart_on;
>>>      uart_raw_irq_data.off = BSP_uart_off;
>>> -    uart_raw_irq_data.isOn= BSP_uart_isOn;
>>>      /* Install ISR  */
>>>      uart_raw_irq_data.idtIndex = port_current->ulIntVector + BSP_IRQ_VECTOR_BASE;
>>> diff --git a/c/src/lib/libbsp/i386/shared/irq/irq.c
>>> b/c/src/lib/libbsp/i386/shared/irq/irq.c
>>> index f4ffd8c0e4..ac08f1f7be 100644
>>> --- a/c/src/lib/libbsp/i386/shared/irq/irq.c
>>> +++ b/c/src/lib/libbsp/i386/shared/irq/irq.c
>>> @@ -270,18 +270,16 @@ static inline bool
>>> bsp_interrupt_vector_is_valid(rtems_vector_number vector)
>>>    return BSP_i8259a_irq_valid((const rtems_irq_number) vector);
>>> -  if (bsp_interrupt_vector_is_valid(vector))
>>> -    BSP_irq_enable_at_i8259a(vector);
>>> +  BSP_irq_enable_at_i8259a(vector);
>>> -    BSP_irq_disable_at_i8259a(vector);
>>> +  BSP_irq_disable_at_i8259a(vector);
>>> diff --git a/c/src/lib/libbsp/lm32/shared/irq/irq.c
>>> b/c/src/lib/libbsp/lm32/shared/irq/irq.c
>>> index 8f9bfaf1ac..79626ee449 100644
>>> --- a/c/src/lib/libbsp/lm32/shared/irq/irq.c
>>> +++ b/c/src/lib/libbsp/lm32/shared/irq/irq.c
>>> @@ -17,14 +17,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>>>    lm32_interrupt_unmask(1 << vector);
>>>    lm32_interrupt_mask(1 << vector);
>>> diff --git a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>>> b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>>> index 58e904426a..f02231b67c 100644
>>> --- a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>>> +++ b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>>> @@ -59,42 +59,30 @@ static rtems_vector_number vector_to_exception_vector(
>>>    return vector + 64U;
>>> +  volatile uint32_t *imr = vector_to_imr(vector);
>>> +  uint32_t bit = vector_to_bit(vector);
>>> -    volatile uint32_t *imr = vector_to_imr(vector);
>>> -    uint32_t bit = vector_to_bit(vector);
>>> -    *imr &= ~bit;
>>> -  } else {
>>> -  return sc;
>>> +  *imr &= ~bit;
>>> -    *imr |= bit;
>>> -  } else {
>>> -  return sc;
>>> +  *imr |= bit;
>>>  static void_func get_exception_handler(rtems_vector_number vector)
>>> diff --git a/c/src/lib/libbsp/mips/shared/irq/irq.c
>>> b/c/src/lib/libbsp/mips/shared/irq/irq.c
>>> index d4941763bc..1c2d3b8c5b 100644
>>> --- a/c/src/lib/libbsp/mips/shared/irq/irq.c
>>> +++ b/c/src/lib/libbsp/mips/shared/irq/irq.c
>>> @@ -67,14 +67,14 @@ static inline bool bsp_irq_is_valid(rtems_vector_number
>>> vector)
>>> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>>> b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>>> index 00d53d7409..f9a7b6426d 100644
>>> --- a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>>> +++ b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>>> @@ -32,12 +32,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
>>>    return 0;
>>> -  return 0;
>>> -  return 0;
>>> diff --git a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>>> b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>>> index 029ed3182e..58e2f2a987 100644
>>> --- a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>>> +++ b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>>> @@ -359,24 +359,26 @@ static inline void BSP_disable_crit_irq_at_siu(
>>> rtems_vector_number
>>>   * This function enables a given siu interrupt
>>> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqLine)
>>> +void bsp_interrupt_vector_enable( rtems_vector_number vector)
>>> -  int base_index = get_siu_irq_base_index( irqLine);
>>> +  int base_index = get_siu_irq_base_index( vector);
>>> -  if (is_siu_irq( irqLine)) {
>>> +  if (is_siu_irq( vector)) {
>>>      rtems_interrupt_disable( level);
>>>      switch (base_index) {
>>>        case BSP_PER_IRQ_LOWEST_OFFSET:
>>> -        BSP_enable_per_irq_at_siu( irqLine);
>>> +        BSP_enable_per_irq_at_siu( vector);
>>>          break;
>>>        case BSP_MAIN_IRQ_LOWEST_OFFSET:
>>> -        BSP_enable_main_irq_at_siu( irqLine);
>>> +        BSP_enable_main_irq_at_siu( vector);
>>>          break;
>>>        case BSP_CRIT_IRQ_LOWEST_OFFSET:
>>> -        BSP_enable_crit_irq_at_siu( irqLine);
>>> +        BSP_enable_crit_irq_at_siu( vector);
>>>          break;
>>>        default:
>>>          rtems_interrupt_enable( level);
>>> @@ -386,31 +388,31 @@ rtems_status_code bsp_interrupt_vector_enable(
>>>   * This function disables a given siu interrupt
>>> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqLine)
>>> +void bsp_interrupt_vector_disable( rtems_vector_number vector)
>>> -        BSP_disable_per_irq_at_siu( irqLine);
>>> +        BSP_disable_per_irq_at_siu( vector);
>>>          break;
>>> -        BSP_disable_main_irq_at_siu( irqLine);
>>> +        BSP_disable_main_irq_at_siu( vector);
>>>          break;
>>> -        BSP_disable_crit_irq_at_siu( irqLine);
>>> +        BSP_disable_crit_irq_at_siu( vector);
>>>          break;
>>>        default:
>>> @@ -420,8 +422,6 @@ rtems_status_code bsp_interrupt_vector_disable(
>>>  #if (BENCHMARK_IRQ_PROCESSING == 0)
>>> diff --git a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>>> b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>>> index 2d89cfa137..7a8ce3cc0b 100644
>>> --- a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>>> +++ b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>>> @@ -376,11 +376,13 @@ rtems_status_code
>>> mpc83xx_ipic_set_highest_priority_interrupt(
>>>   * functions to enable/disable a source at the ipic
>>> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
>>> -  rtems_vector_number vecnum = irqnum - BSP_IPIC_IRQ_LOWEST_OFFSET;
>>> +  rtems_vector_number vecnum = vector - BSP_IPIC_IRQ_LOWEST_OFFSET;
>>>    const BSP_isrc_rsc_t *rsc_ptr;
>>>    if (MPC83XX_IPIC_IS_VALID_VECTOR( vecnum)) {
>>>      rsc_ptr = &mpc83xx_ipic_isrc_rsc [vecnum];
>>>      if (rsc_ptr->mask_reg != NULL) {
>>> @@ -392,15 +394,15 @@ rtems_status_code bsp_interrupt_vector_enable(
>>> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
>>> @@ -412,8 +414,6 @@ rtems_status_code bsp_interrupt_vector_disable(
>>> diff --git a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>>> b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>>> index 52465ec2a7..c145186a52 100644
>>> --- a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>>> +++ b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>>> @@ -328,28 +328,28 @@ BSP_CPM_irq_init(void)
>>> +void bsp_interrupt_vector_enable( rtems_vector_number irqnum)
>>>    if (is_cpm_irq(irqnum)) {
>>>       * Enable interrupt at PIC level
>>>      BSP_irq_enable_at_cpm (irqnum);
>>> +void bsp_interrupt_vector_disable( rtems_vector_number irqnum)
>>>       * disable interrupt at PIC level
>>>      BSP_irq_disable_at_cpm (irqnum);
>>> diff --git a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>>> b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>>> index 59f0e1dcea..61600a9d62 100644
>>> --- a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>>> +++ b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>>> @@ -102,16 +102,16 @@ static int psim_exception_handler(
>>>    /* FIXME: do something */
>>> diff --git a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>>> b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>>> index f4592a375f..b5533e0872 100644
>>> --- a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>>> +++ b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>>> @@ -38,16 +38,16 @@ static int qemuppc_exception_handler(
>>> diff --git a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>>> b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>>> index da7def3913..ea086215fc 100644
>>> --- a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>>> +++ b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>>> @@ -175,28 +175,24 @@ rtems_status_code qoriq_pic_set_affinity(
>>>  static rtems_status_code pic_vector_enable(rtems_vector_number vector, uint32_t
>>>  msk)
>>> -               volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
>>> -               rtems_interrupt_lock_context lock_context;
>>> +       volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
>>> +       rtems_interrupt_lock_context lock_context;
>>> -               rtems_interrupt_lock_acquire(&lock, &lock_context);
>>> -               src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
>>> -               rtems_interrupt_lock_release(&lock, &lock_context);
>>> -       return sc;
>>> +       rtems_interrupt_lock_acquire(&lock, &lock_context);
>>> +       src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
>>> +       rtems_interrupt_lock_release(&lock, &lock_context);
>>> -       return pic_vector_enable(vector, 0);
>>> +       pic_vector_enable(vector, 0);
>>> -       return pic_vector_enable(vector, VPR_MSK);
>>> +       pic_vector_enable(vector, VPR_MSK);
>>>  static void qoriq_interrupt_dispatch(void)
>>> diff --git a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>>> b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>>> index 3cabcdef35..0c98c3a27d 100644
>>> --- a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>>> +++ b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>>> @@ -14,14 +14,14 @@
>>>  #include <bsp/irq-generic.h>
>>> diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>>> b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>>> index 8066a7f43b..2a94c27d1b 100644
>>> --- a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>>> +++ b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>>> @@ -63,30 +63,26 @@ static rtems_status_code
>>> bsp_irq_enable_at_CPM(rtems_vector_number irqnum)
>>> -  if (BSP_IS_CPM_IRQ(irqnum)) {
>>> -    bsp_irq_enable_at_CPM(irqnum);
>>> -  else if (BSP_IS_SIU_IRQ(irqnum)) {
>>> -    bsp_irq_enable_at_SIU(irqnum);
>>> +  if (BSP_IS_CPM_IRQ(vector)) {
>>> +    bsp_irq_enable_at_CPM(vector);
>>> +  } else if (BSP_IS_SIU_IRQ(vector)) {
>>> +    bsp_irq_enable_at_SIU(vector);
>>> -    bsp_irq_disable_at_CPM(irqnum);
>>> -    bsp_irq_disable_at_SIU(irqnum);
>>> +    bsp_irq_disable_at_CPM(vector);
>>> +    bsp_irq_disable_at_SIU(vector);
>>> diff --git a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>>> b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>>> index a9fe7066bc..55194cb1e6 100644
>>> --- a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>>> +++ b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>>> @@ -132,34 +132,22 @@ static void opb_intc_init(void)
>>>      (OPB_INTC_MER_HIE | OPB_INTC_MER_ME);
>>> -    if (BSP_IS_OPBINTC_IRQ(vector)) {
>>> -      BSP_irq_enable_at_opbintc(vector);
>>> -  } else {
>>> -  return sc;
>>> +  if (BSP_IS_OPBINTC_IRQ(vector)) {
>>> +    BSP_irq_enable_at_opbintc(vector);
>>> -      BSP_irq_disable_at_opbintc(vector);
>>> -  } else {
>>> -  return sc;
>>> +    BSP_irq_disable_at_opbintc(vector);
>>>  static int C_dispatch_irq_handler(BSP_Exception_frame *frame, unsigned int
>>>  excNum)
>>> diff --git a/c/src/lib/libbsp/shared/include/irq-generic.h
>>> b/c/src/lib/libbsp/shared/include/irq-generic.h
>>> index 4e89d74ab3..187aea84d1 100644
>>> --- a/c/src/lib/libbsp/shared/include/irq-generic.h
>>> +++ b/c/src/lib/libbsp/shared/include/irq-generic.h
>>> @@ -9,7 +9,7 @@
>>>   * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
>>> - * Copyright (c) 2008-2014 embedded brains GmbH.
>>> + * Copyright (c) 2008, 2017 embedded brains GmbH.
>>>   *  embedded brains GmbH
>>>   *  Dornierstr. 4
>>> @@ -30,6 +30,7 @@
>>>  #include <stdbool.h>
>>>  #include <rtems/irq-extension.h>
>>> +#include <rtems/score/assert.h>
>>>  #ifdef RTEMS_SMP
>>>    #include <rtems/score/atomic.h>
>>> @@ -71,6 +72,8 @@ extern "C" {
>>>    #define bsp_interrupt_fence(order) do { } while (0)
>>>  #endif
>>> +#define bsp_interrupt_assert(e) _Assert(e)
>> doxygen?
>> I don't quite see how using an assert fixes the problem being faced by
>> the use of the pseudo-isr, since this vector number would trip the
>> assert? Maybe I missed something.
> Maybe you missed the change in c/src/lib/libbsp/shared/src/irq-server.c? Sebastian has moved the check for a valid interrupt vector into the interrupt server. So the bsp functions are no longer called with an invalid interrupt vector. I think the assert is based on Chris Johns suggestion from the other thread: "I would suggest the enable/disable calls return 'void' to indicate they can never fail and an invalid vector should be a fatal error with debugging on."
Yes, I did miss the change to the irq-server. Thanks, this looks like
a nice resolution.
>>>  struct bsp_interrupt_handler_entry {
>>>    rtems_interrupt_handler handler;
>>>    void *arg;
>>> @@ -215,32 +218,33 @@ rtems_status_code bsp_interrupt_facility_initialize(void);
>>>   * This function shall enable the vector at the corresponding facility (in most
>>>   * cases the interrupt controller).  It will be called then the first handler
>> s/then/when
>>> - * is installed for the vector in bsp_interrupt_handler_install().  It is
>>> - * guaranteed that the vector number is within the BSP_INTERRUPT_VECTOR_MIN and
>>> - * BSP_INTERRUPT_VECTOR_MAX range.
>>> + * is installed for the vector in bsp_interrupt_handler_install() for example.
>>> + * @note The implementation should use
>>> + * bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector)) to valdiate the
>> typo: validate
>>> + * vector number.
>>>   * @note You must not install or remove an interrupt handler in this function.
>>>   * This may result in a deadlock.
>>> - * @return On success RTEMS_SUCCESSFUL shall be returned.
>>> -rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector);
>>> +void bsp_interrupt_vector_enable(rtems_vector_number vector);
>>>   * @brief Disables the interrupt vector with number @a vector.
>>>   * This function shall disable the vector at the corresponding facility (in
>>>   * most cases the interrupt controller).  It will be called then the last
>>> - * handler is removed for the vector in bsp_interrupt_handler_remove().  It is
>>> + * handler is removed for the vector in bsp_interrupt_handler_remove() for
>>> + * example.
>> ditto
>>> + * vector number.
>>> -rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector);
>>> +void bsp_interrupt_vector_disable(rtems_vector_number vector);
>>>   * @brief Sequencially calls all interrupt handlers for the vector number @a
>>> diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c
>>> b/c/src/lib/libbsp/shared/src/irq-generic.c
>>> index b2a7ced64c..7f943d96cb 100755
>>> --- a/c/src/lib/libbsp/shared/src/irq-generic.c
>>> +++ b/c/src/lib/libbsp/shared/src/irq-generic.c
>>> @@ -207,7 +207,6 @@ static rtems_status_code bsp_interrupt_handler_install(
>>>    void *arg
>>>    rtems_vector_number index = 0;
>>>    bsp_interrupt_handler_entry *head = NULL;
>>> @@ -346,11 +345,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>>>    /* Enable the vector if necessary */
>>>    if (enable_vector) {
>>> -    sc = bsp_interrupt_vector_enable(vector);
>>> -    if (sc != RTEMS_SUCCESSFUL) {
>>> -      bsp_interrupt_unlock();
>>> -      return sc;
>>> +    bsp_interrupt_vector_enable(vector);
>>>    /* Unlock */
>>> @@ -375,7 +370,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
>>>    void *arg
>>> @@ -446,7 +440,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
>>>        /* Disable the vector */
>>> -      sc = bsp_interrupt_vector_disable(vector);
>>> +      bsp_interrupt_vector_disable(vector);
>>>        /* Clear entry */
>>>        bsp_interrupt_disable(level);
>>> @@ -458,12 +452,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
>>>        /* Allow shared handlers */
>>>        bsp_interrupt_set_handler_unique(index, false);
>>> -      /* Check status code */
>>> -        return sc;
>>>      } else {
>>>         * The match is the list tail and has a predecessor.
>>> diff --git a/c/src/lib/libbsp/shared/src/irq-server.c
>>> b/c/src/lib/libbsp/shared/src/irq-server.c
>>> index 905c26198b..9a3ca9abf1 100644
>>> --- a/c/src/lib/libbsp/shared/src/irq-server.c
>>> +++ b/c/src/lib/libbsp/shared/src/irq-server.c
>>> @@ -56,7 +56,9 @@ static void bsp_interrupt_server_trigger(void *arg)
>>>    rtems_interrupt_server_entry *e = arg;
>>> -  bsp_interrupt_vector_disable(e->vector);
>>> +  if (bsp_interrupt_is_valid_vector(e->vector)) {
>>> +    bsp_interrupt_vector_disable(e->vector);
>>>    rtems_interrupt_lock_acquire(&bsp_interrupt_server_lock, &lock_context);
>>> @@ -324,7 +326,9 @@ static void bsp_interrupt_server_task(rtems_task_argument
>>> arg)
>>>          (*current->handler)(current->arg);
>>>        } while (action != NULL);
>>> -      bsp_interrupt_vector_enable(vector);
>>> diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>>> b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>>> index f219e49f45..344ed71a34 100644
>>> --- a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>>> +++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>>> @@ -70,20 +70,18 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>>>    int irq = (int)vector;
>>>    BSP_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
>>>    BSP_Cpu_Mask_interrupt(irq, bsp_irq_cpu(irq));
>>>  void BSP_shared_interrupt_mask(int irq)
>>> diff --git a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>>> b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>>> index 9ecdacfbb7..95e93845b9 100644
>>> --- a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>>> +++ b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>>> @@ -27,18 +27,16 @@ void bsp_interrupt_dispatch(void)
>>>    AIC_CTL_REG(AIC_EOICR) = 0;
>>>    AIC_CTL_REG(AIC_IECR) = 1 << vector;
>>>    AIC_CTL_REG(AIC_IDCR) = 1 << vector;
>>> diff --git a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>>> b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>>> index 851705bee2..83e140bd7b 100644
>>> --- a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>>> +++ b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>>> @@ -26,18 +26,16 @@ void bsp_interrupt_dispatch(void)
>>>    VICVectAddr = 0;
>>>    VICIntEnable |= 1 << vector;
>>>    VICIntEnClr = 1 << vector;
>>> diff --git a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>>> b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>>> index 2d6e34d274..e5887b9717 100644
>>> --- a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>>> +++ b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>>> @@ -26,24 +26,20 @@ void bsp_interrupt_dispatch(void)
>>> -  if (vector >= MC9328MXL_NUM_INTS)
>>> -  MC9328MXL_AITC_INTENNUM = vector;
>>> +  if (vector < MC9328MXL_NUM_INTS)
>>> +    MC9328MXL_AITC_INTENNUM = vector;
>>> -  MC9328MXL_AITC_INTDISNUM = vector;
>>> +    MC9328MXL_AITC_INTDISNUM = vector;
>>> diff --git a/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>>> b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>>> index 8b46ce149c..425795b165 100644
>>> --- a/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>>> +++ b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>>> @@ -24,18 +24,16 @@ void bsp_interrupt_dispatch(void)
>>>    XSCALE_INT_ICMR |= 1 << vector;
>>>    XSCALE_INT_ICMR  &= ~(1 << vector);
>>> diff --git a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>>> b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>>> index dce6c383b9..ea8f610353 100644
>>> --- a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>>> +++ b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>>> @@ -27,14 +27,14 @@ void bsp_interrupt_dispatch(void)
>>> diff --git a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>>> b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>>> index 59b2c39c59..789a19a490 100644
>>> --- a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>>> +++ b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>>> @@ -180,20 +180,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>>> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector)
>>> -       if (MPC55XX_IRQ_IS_VALID( vector)) {
>>> -               return mpc55xx_intc_set_priority( vector,
>>> MPC55XX_INTC_DEFAULT_PRIORITY);
>>> -       } else {
>>> +       mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DEFAULT_PRIORITY);
>>> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector)
>>> MPC55XX_INTC_DISABLED_PRIORITY);
>>> -       } else {
>>> +       mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DISABLED_PRIORITY);
>>> 2.12.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
