RTEMS Tier Allocations.
Mon Nov 6 22:03:15 UTC 2017
On 06/11/2017 21:20, Sebastian Huber wrote:
> On 27/10/17 07:13, Chris Johns wrote:
>> On 26/10/2017 18:50, Sebastian Huber wrote:
>>> with the change to the INI format files, the
>>> target_pretest_command
>>> target_exe_filter_command
>>> disappeared.
>> Oh I changed some names as part of a clean up.
>>> I am not sure how I can invoke the tester for a board using U-Boot
>>> connected via TTY or telnet. Do you have an example command line?
>> Of course, with the removal of my local set up there is nothing left in the
>> BSP configurations as examples.
>> A command line is:
>>    $ sudo rtems-test --rtems-tools=/opt/work/rtems/4.12 \
>>                      --rtems-bsp=xilinx_zynq_zedboard \
>>                      --timeout=60 --log=t.txt \
>>                      --user-config=$HOME/.rtemstesterrc \
>>                      --mail .
> How did you setup your mail configuration?
$ cat ~/.mailrc | grep chrisj
set from=chrisj at rtems.org
> A
> sudo /opt/rtems-4.12/bin/rtems-test --rtems-bsp=imx7
> --rtems-tools=/opt/rtems-4.12
> /build/git-build/b-imx7/arm-rtems4.12/c/imx7/testsuites/samples/ticker/
> --timeout=180 --user-config=$HOME/.rtemstesterrc --debug-trace=output
> --log=l.txt --mail-from="sebastian.huber at embedded-brains.de" --mail
> yields
> error: no valid from address for mail
This is a bug. I will fix this.
