RTEMS Tier Allocations.
Tue Nov 7 07:01:38 UTC 2017
On 06/11/17 23:03, Chris Johns wrote:
> On 06/11/2017 21:20, Sebastian Huber wrote:
>> On 27/10/17 07:13, Chris Johns wrote:
>>> On 26/10/2017 18:50, Sebastian Huber wrote:
>>>> with the change to the INI format files, the
>>>> target_pretest_command
>>>> target_exe_filter_command
>>>> disappeared.
>>> Oh I changed some names as part of a clean up.
>>>> I am not sure how I can invoke the tester for a board using U-Boot
>>>> connected via TTY or telnet. Do you have an example command line?
>>> Of course, with the removal of my local set up there is nothing left in the
>>> BSP configurations as examples.
>>> A command line is:
>>>     $ sudo rtems-test --rtems-tools=/opt/work/rtems/4.12 \
>>>                       --rtems-bsp=xilinx_zynq_zedboard \
>>>                       --timeout=60 --log=t.txt \
>>>                       --user-config=$HOME/.rtemstesterrc \
>>>                       --mail .
>> How did you setup your mail configuration?
> $ cat ~/.mailrc | grep chrisj
> setfrom=chrisj at rtems.org
With the sudo, I have to add this file to the root user. Would it be
possible to simply generate a raw mail file which can be sent later via
an e-mail client? Some test machines may be not connected to the
internet for example.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
