[rtems commit] tests: Use <tmacros.h> in all tests
Tue Nov 7 07:15:38 UTC 2017
On 07/11/2017 17:09, Sebastian Huber wrote:
> Commit:    7b00c2fac57740963d3c4d8bf1cf5eab3a31f22e
> -  rtems_test_begin();
> +  TEST_BEGIN();
> -  rtems_test_end();
> +  TEST_END();
I am now confused ....
$ arm-rtems4.12-nm `find . -name \*.exe` | grep rtems_test_begin
001118dc T rtems_test_begin
0011907c T rtems_test_begin
and these are in libtests/math and libtests/capture01 which I suspect have been
missed with this change.
I think the macros TEST_BEGIN and TEST_END should go and the test strings in the
libmisc/testsupport/test.h should be moved out of the header file and into
testbeginend.c. I did point this out in ...
https://lists.rtems.org/pipermail/devel/2017-November/019366.html
Just to be clear what I am going to do:
1. Strip out as much of buffer_test_io.h as I can and rename it test_io.h.
2. Remove all TEST_BEGIN and TEST_END macro usage and move all test into
testbeginend.c.
3. Add the banners for version, build and tools.
Sebastian, how does this look to you?
