[PATCH] posix: Ignore pshared for semaphores
Tue Sep 12 13:58:00 UTC 2017
On Tue, Sep 12, 2017 at 1:10 AM, Sebastian Huber
> On 11/09/17 16:03, Sebastian Huber wrote:
>> ----- Joel Sherrill <joel at rtems.org> schrieb:
>>> On Fri, Sep 8, 2017 at 1:51 PM, Sebastian Huber <
>>>> Ok,  but why do you think that this is an error?  We can share the
>>>> synchronization objects among processes.
>>> We don't have processes. How do you propose to share between
>>> processes when RTEMS is fundamentally a single process system.
>> Yes, its a single process system. So, it is very easy to support sharing
>> between processes. Why should creating a process-shared synchronization
>> object fail only because its impossible to create a second process?
> I would like to remove this process-shared error also from the other POSIX
> synchronization objects:
> https://devel.rtems.org/ticket/3125
> https://devel.rtems.org/ticket/3126
Do these process-shared synch objects work properly when used in a
single process on *nix?
> devel mailing list
> devel at rtems.org
