the generated coverage report doesn't contain any data
Mon Apr 16 21:49:36 UTC 2018
On Mon, Apr 16, 2018 at 4:47 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On 17 April 2018 at 01:43, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 16 April 2018 at 17:46, Joel Sherrill <joel at rtems.org> wrote:
>>> On Mon, Apr 16, 2018 at 2:33 AM, Vijay Kumar Banerjee <
>>>> current status :
>>>> the coverage is running now with rtems-test and generating the report,
>>>> however, the report doesn't show any data.
>>> I've been lurking as you have been making progress. Now you have crossed
>>> into something you probably need some hints at. Some things to check:
>>> + Obviously, check output for signs that something didn't happen right.
>>> Anything from a path wrong, etc. The configuration has to be right to
>>> point to the source code, object code, executables, etc.
>>> + A lot of source code has moved around since last summer. Check
>>> that it is looking in the right places inside RTEMS.
>>> + Does the mechanism to get debug information actually work? Cillian?
>> The covoar debug option just disables the cleaning of the tempfiles to
>> take a look, so it's not as powerful as it might seem :)... I always used
>> gdb here so that's probably the way to go.
>>> + There is a utility named trace-converter. Make sure your qemu traces
>>> have information in them.
>>> + Cillian probably has guidance on running it just on one test (say
>>> ticker)
>>> so you can see every step.
>>> + Check that the executables have symbolic information. "file" should
>>> show if they are stripped or not.
>>> I recall covoar has a verbose mode which should be of use.
>>> Cillian .. do you have instructions on running covoar in gdb?
>> Alright so run rtems-test with --no-clean option to leave the coverage
>> files lying around
>> $HOME/development/rtems/test/test/rtems-tools/tester/rtems-test
>> --rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
>> --rtems-bsp=leon3_qemu --coverage --no-clean --rtems-builddir=$HOME/development/rtems/leon3
>> sparc-rtems5/c/leon3/testsuites/samples
>> Then run
>> gdb covoar
>> from gdb prompt
>> run -S /home/cpod/coverage_test/leon3/coverage/score.symcfg -O
>> /home/cpod/coverage_test/leon3/test/score -fQEMU -Tsparc-rtems5
>> -E/home/cpod/development/rtems/test/test/vijay/rtems-tools/
>> tester/rtems/testing/coverage/Explanations.txt -c.cov -eexe -pRTEMS-5
>> /home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/test
>> suites/samples/base_sp/base_sp.exe
>> The options there are ( if you're wondering )
>>  -c COVERAGEFILE_EXTENSION EXECUTABLE1 ... EXECUTABLE2
>>  -v                  - verbose output
>>  -T TARGET           - architecture target name
>>  -f FORMAT           - simulator format
>> (RTEMS, QEMU, TSIM or Skyeye)
>>  -E EXPLANATIONS     - file of explanations
>>  -s SYMBOLS_FILE     - symbols of interest
>>  -S SYMBOL_SET_FILE  - path to symbol_sets.cfg
>>  -1 EXECUTABLE       - executable to get symbols from
>>  -e EXE_EXTENSION    - suffix for executables
>>  -c COVERAGEFILE_EXT - coverage file suffix
>>  -g GCNOS_LIST       - list of *.gcno files
>>  -p PROJECT_NAME     - name of the project
>>  -O Output_Directory - output directory default=.
>>  -d debug            - disable cleaning of tempfiles.
> maybe the problem is here . I am getting an error for the -S . Here are
> the list of options that show up , capital S for symbol_set_file is not one
> of them .
> Usage: /home/lunatic/development/rtems/5/bin/covoar [-v] -T TARGET -f
> FORMAT [-E EXPLANATIONS] -e EXE_EXTENSION -c COVERAGEFILE_EXTENSION
>   -v                        - verbose at initialization
>   -T TARGET                 - target name
>   -f FORMAT                 - coverage file format (RTEMS, QEMU, TSIM or
> Skyeye)
>   -E EXPLANATIONS           - name of file with explanations
>   -s SYMBOLS_FILE           - name of file with symbols of interest
>   -1 EXECUTABLE             - name of executable to get symbols from
>   -e EXE_EXTENSION          - extension of the executables to analyze
>   -c COVERAGEFILE_EXTENSION - extension of the coverage files to analyze
>   -g GCNOS_LIST             - name of file with list of *.gcno files
>   -C ConfigurationFileName  - name of configuration file
>   -O Output_Directory       - name of output directory (default=.
Is it processed by the getopts switch statement in main() but not listed in
the usage? That is
an easy mistake to creep in.
>> Just trying it there, it runs into segmentation fault. So trying to
>> access memory it shouldn't.
>> Starting program: /home/cpod/covoar -S /home/cpod/coverage_test/leon3/coverage/score.symcfg
>> -O /home/cpod/coverage_test/leon3/test/score -fQEMU -Tsparc-rtems5
>> Reading configuration symbol set file: /home/cpod/coverage_test/leon3
>> Program received signal SIGSEGV, Segmentation fault.
>> 0x00007ffff7b769bb in std::__cxx11::basic_string<char,
>> std::char_traits<char>, std::allocator<char> >::basic_string(std::__cxx11::basic_string<char,
>> std::char_traits<char>, std::allocator<char> > const&) ()
>>    from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
>> Ahhh feels good to have error messages back.
>> Oh also build covoar with no optimization and you'll have an easier time
>> looking at stuff in gdb
>> cd rtems-tools/tester/covoar
>> vim wscript and change the '-O2' to '-O0' and then build again with waf
>> and use that covoar to with gdb
>>>> -- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180416/90a31a0e/attachment-0002.html>
