rtems-docs build failure
Sun Dec 23 22:36:56 UTC 2018
On 24/12/18 9:35 am, Joel Sherrill wrote:
> On Sun, Dec 23, 2018, 4:16 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org> wrote:
>     On 24/12/18 4:11 am, Joel Sherrill wrote:
>     > Chris... xindy
>     > [joel at localhost rtems]$ xindy
>     > xindy      xindy.run
>     > [joel at localhost rtems]$ type xindy
>     > xindy is /usr/local/texlive/2018/bin/x86_64-linux/xindy
>     > [joel at localhost rtems]$ echo $PATH
>     /home/joel/.local/bin:/usr/local/texlive/2018/bin/x86_64-linux:/home/joel/rtems-work/tools/5/bin:/home/joel/rtems-work/rtems-testing/bin:/usr/lib/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/bin:/home/joel/bin
>     Thanks. It looks like a build from source which installs this xindy command.
> I'm not building from source. I am installing the texlive binaries.
Yes, sorry, that I what I meant, you are using a specific install. The important
point is texlive expects there to be a xindy command.
