RTEMS Software Engineering Handbook
Gedare Bloom
gedare at rtems.org
Tue Dec 18 15:03:36 UTC 2018
I think it is OK to merge this and fix in the main docs repo. It looks to
be a great start to compiling the SwE handbook.
On Mon, Dec 17, 2018 at 8:03 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> NOTE: Patch set attached as tarball because multiple patches contain
> lines which are long enough that "git send-mail" refuses to send them.
> In general, the patch set should be accepted in entirety or work continue
> in my personal repository -- which would be tragic.
> This patch set adds an initial draft of the RTEMS Software Engineering
> Handbook as proposed by Scott Zemerick of NASA IV&V at the 2017 edition
> of the Workshop on Spacecraft Flight Software. He proposed an outline
> that collected information we had in the Wiki into a format that would
> be recognizable to an IV&V reviewer. This will assist those performing
> safety and flight reviews.
> At this point, the document reflects a first pass conversion from
> the Wiki to Sphinx Rest. In each section is a TBD showing the URL
> that the section needs to be reviewed against. There needs to be:
> * a review for accuracy of the conversion
> * deletion of the wiki pages and references changed to this document
> * updates to this document for correctness of content
> For convenience in reviewing, I have placed the formatted output at
> https://ftp.rtems.org/pub/rtems/people/joel/sw_eng_hb/eng/index.html
> The conversion was done by GCI 2018 students with setup and clean up by me.
> I have cc'ed those who helped with this conversion as a thank you to them
> and
> so they know how important this is to the RTEMS Project.
> I would like to get this merged AS IS so we can get to improving it
> ASAP. Having artifacts and technical data owned by the project which
> reflect the needs of the users with the most intense applications
> is important and reflects the use of RTEMS in critical system.
> Please help with the review for accuracy and obsoleting the corresponding
> Wiki pages.
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181218/01523063/attachment-0002.html>
