no-preinstall: Ready for final review
Thu Jan 18 16:33:08 UTC 2018
Is this after installation or during the BSP build?
----- Am 18. Jan 2018 um 17:19 schrieb Gedare Bloom gedare at rtems.org:
> On Thu, Jan 18, 2018 at 10:34 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Jan 18, 2018 at 10:20 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> I fixed the cpuopts.h problem two minutes ago.
>> Thanks.
>> I just noticed that actually when I run tester on the installed tree I
>> get a lot of timeouts. I'm not sure if this is my host problem.
> I have a new problem:
> build/config.log:err:
> /home/gedare/development/rtems/5/lib/gcc/sparc-rtems5/7.2.0/../../../../sparc-rtems5/bin/ld:
> cannot open linker script file linkcmds.base: No such file or
> directory
> That file does not appear to leave the source tree.
> gedare:~/work/rtems/builds/b-erc32-5$ find . -name linkcmds.base
> gedare::~/work/rtems/builds/b-erc32-5$ find . -name linkcmds
> ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/linkcmds
>>> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>>>> On Wed, Jan 17, 2018 at 2:24 AM, Sebastian Huber
>>>> > Hello,
>>>> > the no-preinstall branch is now in a good shape.
>>>> > https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall
>>>> > Please review this work. The next step would be to squash all commits on
>>>> > this branch, write a proper commit message and push it to the master.
>>>> Hello Sebastian,
>>>> I checked it out, built erc32, ran erc32 from the build, installed the
>>>> bsp, and ran it again fine using rtems-tools/tester.
>>>> However, when I try to waf-configure examples-v2, I get a problem that
>>>> rtems/score/cpuopts.h is not found. When I look in my installed tree,
>>>> I do not find the file:
>>>> $ find /opt/rtems-5 -name cpuopts.h
>>>> $ find /opt/rtems-5 -name include
>>>> ./sparc-rtems5/erc32/lib/include
>>>> I do see it in my build tree:
>>>> ~/work/rtems/builds/b-erc32-5$ find . -name cpuopts.h
>>>> ./sparc-rtems5/c/erc32/include/rtems/score/cpuopts.h
>>>> Relatedly, I don't see the bspopts.h file in the installed tree
>>>> either. I do see it in the build tree, in a different location from
>>>> the rest of the includes:
>>>> ~/work/rtems/builds/b-erc32-5$ find . -name bspopts.h
>>>> ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
>>>> I also took a quick look through the commits, and I have a small nit.
>>>> Might I suggest "headers.sh" and "headers.am" instead of "header.sh"
>>>> and "header.am"?
>>>> -Gedare
>>>> > Sebastian Huber, embedded brains GmbH
>>>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>> > Phone   : +49 89 189 47 41-16
>>>> > Fax     : +49 89 189 47 41-09
>>>> > E-Mail  : sebastian.huber at embedded-brains.de
>>>> > PGP     : Public key available on request.
>>>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> > _______________________________________________
>>>> > devel mailing list
>>>> > devel at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/devel
