[PATCH v3] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Jun 6 00:22:18 UTC 2018
On 6 June 2018 at 03:57, Joel Sherrill <joel at rtems.org> wrote:
> I think everything is pushed. Is there any patch outstanding?
> Thank you.
No outstanding patch, everything on my side is squashed into it. :)
> On Mon, Jun 4, 2018 at 3:44 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Add support in tester to run covoar and generate an html report to display
>> the summary of the coverage reports generated from covoar.
>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>> .gitignore | 1 +
>> tester/rt/coverage.py | 385
>> tester/rt/test.py | 34 ++-
>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>> tester/rtems/testing/qemu.cfg | 4 +-
>> 6 files changed, 450 insertions(+), 13 deletions(-)
>> create mode 100644 tester/rt/coverage.py
>> create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>> diff --git a/.gitignore b/.gitignore
>> index 6ab3709..93cb5d2 100644
>> --- a/.gitignore
>> +++ b/.gitignore
>> @@ -9,3 +9,4 @@ waf3-*
>> .lock-waf*
>> build
>> VERSION*
>> +*symbols.ini
>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>> new file mode 100644
>> index 0000000..54933d5
>> --- /dev/null
>> +++ b/tester/rt/coverage.py
>> @@ -0,0 +1,385 @@
>> +# RTEMS Tools Project (http://www.rtems.org/)
>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>> +# All rights reserved.
>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> +# Redistribution and use in source and binary forms, with or without
>> +# modification, are permitted provided that the following conditions are
>> met:
>> +# 1. Redistributions of source code must retain the above copyright
>> notice,
>> +# this list of conditions and the following disclaimer.
>> +# 2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> +# this list of conditions and the following disclaimer in the
>> documentation
>> +# and/or other materials provided with the distribution.
>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> 'AS IS'
>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
>> BE
>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
>> THE
>> +# POSSIBILITY OF SUCH DAMAGE.
>> +from rtemstoolkit import error
>> +from rtemstoolkit import path
>> +from rtemstoolkit import log
>> +from rtemstoolkit import execute
>> +from rtemstoolkit import macros
>> +from datetime import datetime
>> +from . import options
>> +import shutil
>> +import os
>> +try:
>> + import configparser
>> +except:
>> + import ConfigParser as configparser
>> +class summary:
>> + def __init__(self, p_summary_dir):
>> + self.summary_file_path = path.join(p_summary_dir, 'summary.txt')
>> + self.index_file_path = path.join(p_summary_dir, 'index.html')
>> + self.bytes_analyzed = 0
>> + self.bytes_not_executed = 0
>> + self.percentage_executed = 0.0
>> + self.percentage_not_executed = 100.0
>> + self.ranges_uncovered = 0
>> + self.branches_uncovered = 0
>> + self.branches_total = 0
>> + self.branches_always_taken = 0
>> + self.branches_never_taken = 0
>> + self.percentage_branches_covered = 0.0
>> + self.is_failure = False
>> + def parse(self):
>> + if(not path.exists(self.summary_file_path)):
>> + log.notice('summary file %s does not exist!' %
>> + self.is_failure = True
>> + return
>> + with open(self.summary_file_path,'r') as summary_file:
>> + self.bytes_analyzed = self._get_next_with_colon(summary_file)
>> + self.bytes_not_executed = self._get_next_with_colon(summ
>> ary_file)
>> + self.percentage_executed = self._get_next_with_colon(summ
>> ary_file)
>> + self.percentage_not_executed = self._get_next_with_colon(summ
>> ary_file)
>> + self.ranges_uncovered = self._get_next_with_colon(summ
>> ary_file)
>> + self.branches_total = self._get_next_with_colon(summary_file)
>> + self.branches_uncovered = self._get_next_with_colon(summ
>> ary_file)
>> + self.branches_always_taken = self._get_next_without_colon(s
>> ummary_file)
>> + self.branches_never_taken = self._get_next_without_colon(s
>> ummary_file)
>> + if len(self.branches_uncovered) > 0 and len(self.branches_total)
>> > 0:
>> + self.percentage_branches_covered = \
>> + 1 - (float(self.branches_uncovered) /
>> float(self.branches_total))
>> + else:
>> + return
>> + def _get_next_with_colon(self, summary_file):
>> + line = summary_file.readline()
>> + if ':' in line:
>> + return line.split(':')[1].strip()
>> + else:
>> + return ''
>> + def _get_next_without_colon(self, summary_file):
>> + return line.strip().split(' ')[0]
>> +class report_gen_html:
>> + def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
>> + self.symbol_sets_list = ['score']
>> + self.build_dir = build_dir
>> + self.partial_reports_files = list(["index.html", "summary.txt"])
>> + self.number_of_columns = 1
>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>> + self.bsp = bsp
>> + def _find_partial_reports(self):
>> + partial_reports = {}
>> + for symbol_set in self.symbol_sets_list:
>> + set_summary = summary(path.join(self.build_dir,
>> + self.bsp + "-coverage",
>> + symbol_set))
>> + set_summary.parse()
>> + partial_reports[symbol_set] = set_summary
>> + return partial_reports
>> + def _prepare_head_section(self):
>> + head_section = '''
>> + <head>
>> + <title>RTEMS coverage report</title>
>> + <style type="text/css">
>> + progress[value] {
>> + -webkit-appearance: none;
>> + appearance: none;
>> + width: 150px;
>> + height: 15px;
>> + </style>
>> + </head>'''
>> + return head_section
>> + def _prepare_index_content(self, partial_reports):
>> + header = "<h1> RTEMS coverage analysis report </h1>"
>> + header += "<h3>Coverage reports by symbols sets:</h3>"
>> + table = "<table>"
>> + table += self._header_row()
>> + for symbol_set in partial_reports:
>> + table += self._row(symbol_set, partial_reports[symbol_set])
>> + table += "</table> </br>"
>> + timestamp = "Analysis performed on " + datetime.now().ctime()
>> + return "<body>\n" + header + table + timestamp + "\n</body>"
>> + def _row(self, symbol_set, summary):
>> + row = "<tr>"
>> + row += "<td>" + symbol_set + "</td>"
>> + if summary.is_failure:
>> + row += ' <td colspan="' + str(self.number_of_columns-1) \
>> + + '" style="background-color:red">FAILURE</td>'
>> + else:
>> + row += " <td>" + self._link(summary.index_file_path,"Index")
>> + + "</td>"
>> + row += " <td>" + self._link(summary.summary_file_path,"Summary")
>> + + "</td>"
>> + row += " <td>" + summary.bytes_analyzed + "</td>"
>> + row += " <td>" + summary.bytes_not_executed + "</td>"
>> + row += " <td>" + summary.ranges_uncovered + "</td>"
>> + row += " <td>" + summary.percentage_executed + "%</td>"
>> + row += " <td>" + summary.percentage_not_executed + "%</td>"
>> + row += ' <td><progress value="' +
>> summary.percentage_executed \
>> + + '" max="100"></progress></td>'
>> + row += " <td>" + summary.branches_uncovered + "</td>"
>> + row += " <td>" + summary.branches_total + "</td>"
>> + row += " <td> {:.3%} </td>".format(summary.percenta
>> ge_branches_covered)
>> + row += ' <td><progress value="{:.3}"
>> max="100"></progress></td>'.format(100*summary.percentage_br
>> anches_covered)
>> + row += "</tr>\n"
>> + return row
>> + def _header_row(self):
>> + row = "<tr>"
>> + row += "<th> Symbols set name </th>"
>> + row += "<th> Index file </th>"
>> + row += "<th> Summary file </th>"
>> + row += "<th> Bytes analyzed </th>"
>> + row += "<th> Bytes not executed </th>"
>> + row += "<th> Uncovered ranges </th>"
>> + row += "<th> Percentage covered </th>"
>> + row += "<th> Percentage uncovered </th>"
>> + row += "<th> Instruction coverage </th>"
>> + row += "<th> Branches uncovered </th>"
>> + row += "<th> Branches total </th>"
>> + row += "<th> Branches covered percentage </th>"
>> + row += "<th> Branches coverage </th>"
>> + row += "</tr>\n"
>> + self.number_of_columns = row.count('<th>')
>> + return row
>> + def _link(self, address, text):
>> + return '<a href="' + address + '">' + text + '</a>'
>> + def _create_index_file(self, head_section, content):
>> + with open(path.join(self.build_dir,
>> + self.bsp + "-report.html"),'w') as f:
>> + f.write(head_section)
>> + f.write(content)
>> + def generate(self):
>> + partial_reports = self._find_partial_reports()
>> + head_section = self._prepare_head_section()
>> + index_content = self._prepare_index_content(partial_reports)
>> + self._create_index_file(head_section,index_content)
>> + def add_covoar_src_path(self):
>> + table_js_path = path.join(self.covoar_src_path, 'table.js')
>> + covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
>> + symbol_set_dir = path.join(self.build_dir,
>> + self.bsp + '-coverage',
>> symbol_set)
>> + html_files = os.listdir(symbol_set_dir)
>> + for html_file in html_files:
>> + html_file = path.join(symbol_set_dir, html_file)
>> + if path.exists(html_file) and 'html' in html_file:
>> + with open(html_file, 'r') as f:
>> + file_data = f.read()
>> + file_data = file_data.replace('table.js',
>> table_js_path)
>> + file_data = file_data.replace('covoar.css',
>> + covoar_css_path)
>> + with open(html_file, 'w') as f:
>> + f.write(file_data)
>> +class build_path_generator(object):
>> + Generates the build path from the path to executables
>> + def __init__(self, executables, target):
>> + self.executables = executables
>> + self.target = target
>> + def run(self):
>> + build_path = '/'
>> + Path = self.executables[0].split('/')
>> + for P in Path:
>> + if P == self.target:
>> + break;
>> + else:
>> + build_path = path.join(build_path, P)
>> + return build_path
>> +class symbol_parser(object):
>> + Parse the symbol sets ini and create custom ini file for covoar
>> + def __init__(self, symbol_config_path,
>> + symbol_select_path, coverage_arg, build_dir):
>> + self.symbol_select_file = symbol_select_path
>> + self.symbol_file = symbol_config_path
>> + self.symbol_sets = {}
>> + self.cov_arg = coverage_arg
>> + self.ssets = []
>> + def parse(self):
>> + config = configparser.ConfigParser()
>> + try:
>> + config.read(self.symbol_file)
>> + if self.cov_arg:
>> + self.ssets = self.cov_arg.split(',')
>> + else:
>> + self.ssets = config.get('symbol-sets', 'sets').split(',')
>> + self.ssets = [ sset.encode('utf-8') for sset in
>> self.ssets]
>> + for sset in self.ssets:
>> + lib = path.join(self.build_dir,
>> + config.get('libraries', sset))
>> + self.symbol_sets[sset] = lib.encode('utf-8')
>> + except:
>> + raise error.general('Symbol set parsing failed')
>> + def _write_ini(self):
>> + try:
>> + sets = ', '.join(self.symbol_sets.keys())
>> + config.add_section('symbol-sets')
>> + config.set('symbol-sets', 'sets', sets)
>> + for key in self.symbol_sets.keys():
>> + config.add_section(key)
>> + config.set(key, 'libraries', self.symbol_sets[key])
>> + with open(self.symbol_select_file, 'w') as conf:
>> + config.write(conf)
>> + except:
>> + raise error.general('write failed')
>> + def run(self):
>> + self.parse()
>> + self._write_ini()
>> +class covoar(object):
>> + Covoar runner
>> + def __init__(self, base_result_dir, config_dir, executables,
>> explanations_txt):
>> + self.base_result_dir = base_result_dir
>> + self.config_dir = config_dir
>> + self.executables = ' '.join(executables)
>> + self.explanations_txt = explanations_txt
>> + self.project_name = 'RTEMS-5'
>> + def run(self, set_name, symbol_file):
>> + covoar_result_dir = path.join(self.base_result_dir, set_name)
>> + if (not path.exists(covoar_result_dir)):
>> + path.mkdir(covoar_result_dir)
>> + if (not path.exists(symbol_file)):
>> + raise error.general('symbol set file: coverage %s was not
>> created for covoar, skipping %s'% (symbol_file, set_name))
>> + command = ('covoar -S ' + symbol_file
>> + + ' -O ' + covoar_result_dir
>> + + ' -E ' + self.explanations_txt
>> + + ' -p ' + self.project_name + ' ' + self.executables)
>> + log.notice('Running covoar for %s' % (set_name))
>> + print( 'covoar results directory:\n' + covoar_result_dir )
>> + executor = execute.execute(verbose = True, output =
>> self.output_handler)
>> + exit_code = executor.shell(command, cwd=os.getcwd())
>> + if (exit_code[0] != 0):
>> + raise error.general('covoar failure exit code: %d' %
>> (exit_code[0]))
>> + log.notice('Coverage run for %s finished successfully.' %
>> (set_name))
>> + log.notice('-----------------------------------------------')
>> + def output_handler(self, text):
>> + log.notice('%s' % (text))
>> +class coverage_run(object):
>> + Coverage analysis support for rtems-test
>> + def __init__(self, p_macros, coverage_arg, executables):
>> + Constructor
>> + self.macros = p_macros
>> + self.build_dir = self.macros['_cwd']
>> + self.explanations_txt = self.macros.expand(self.macros
>> ['cov_explanations'])
>> + self.test_dir = path.join(self.build_dir, self.macros['bsp'] +
>> '-coverage')
>> + if (not path.exists(self.test_dir)):
>> + path.mkdir(self.test_dir)
>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>> + self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
>> + self.coverage_config_path = path.join(self.rtscripts, 'coverage')
>> + self.symbol_config_path = path.join(self.coverage_config_path,
>> + 'symbol-sets.ini')
>> + self.symbol_select_path = path.join(self.coverage_config_path,
>> + self.macros['bsp'] +
>> '-symbols.ini')
>> + self.symbol_sets = []
>> + self.no_clean = int(self.macros['_no_clean'])
>> + self.report_format = self.macros['cov_report_format']
>> + self.coverage_arg = coverage_arg
>> + self.target = self.macros['target']
>> + def run(self):
>> + try:
>> + if self.executables is None:
>> + raise error.general('no test executables provided.')
>> + build_dir = build_path_generator(self.executables,
>> self.target).run()
>> + parser = symbol_parser(self.symbol_config_path,
>> + self.symbol_select_path,
>> + self.coverage_arg,
>> + build_dir)
>> + parser.run()
>> + covoar_runner = covoar(self.test_dir,
>> + self.executables,
>> self.explanations_txt)
>> + covoar_runner.run('score', self.symbol_select_path)
>> + self._generate_reports();
>> + self._summarize();
>> + finally:
>> + self._cleanup();
>> + def _generate_reports(self):
>> + log.notice('Generating reports')
>> + if self.report_format == 'html':
>> + report = report_gen_html(self.symbol_sets,
>> + self.build_dir,
>> + self.rtdir,
>> + self.macros['bsp'])
>> + report.generate()
>> + report.add_covoar_src_path()
>> + def _cleanup(self):
>> + if not self.no_clean:
>> + log.notice('***Cleaning tempfiles***')
>> + for exe in self.executables:
>> + trace_file = exe + '.cov'
>> + if path.exists(trace_file):
>> + os.remove(trace_file)
>> + os.remove(self.symbol_select_path)
>> + def _summarize(self):
>> + log.notice('Coverage analysis finished. You can find results in
>> %s' % (self.build_dir))
>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>> index f4d9b5c..0e744cd 100644
>> --- a/tester/rt/test.py
>> +++ b/tester/rt/test.py
>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>> from rtemstoolkit import reraise
>> from rtemstoolkit import stacktraces
>> from rtemstoolkit import version
>> +from rtemstoolkit import check
>> from . import bsps
>> from . import config
>> from . import console
>> from . import report
>> +from . import coverage
>> class log_capture(object):
>> def __init__(self):
>> @@ -147,7 +149,7 @@ class test_run(object):
>> def run(self):
>> self.thread = threading.Thread(target = self.runner,
>> - name = 'test[%s]' %
>> path.basename(self.executable))
>> + name = 'test[%s]' %
>> self.thread.start()
>> def is_alive(self):
>> @@ -221,15 +223,16 @@ def run(command_path = None):
>> opts = None
>> default_exefilter = '*.exe'
>> try:
>> - optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>> - '--rtems-bsp': 'The RTEMS BSP to run the test on',
>> - '--user-config': 'Path to your local user
>> configuration INI file',
>> - '--report-mode': 'Reporting modes, failures
>> (default),all,none',
>> - '--list-bsps': 'List the supported BSPs',
>> - '--debug-trace': 'Debug trace based on specific
>> flags',
>> - '--filter': 'Glob that executables must match
>> to run (default: ' +
>> + optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>> + '--rtems-bsp': 'The RTEMS BSP to run the test
>> on',
>> + '--user-config': 'Path to your local user
>> + '--report-mode': 'Reporting modes, failures
>> + '--list-bsps': 'List the supported BSPs',
>> + '--debug-trace': 'Debug trace based on specific
>> flags',
>> + '--filter': 'Glob that executables must
>> match to run (default: ' +
>> default_exefilter + ')',
>> - '--stacktrace': 'Dump a stack trace on a user
>> termination (^C)' }
>> + '--stacktrace': 'Dump a stack trace on a user
>> termination (^C)',
>> + '--coverage': 'Perform coverage analysis of
>> test executables.'}
>> mailer.append_options(optargs)
>> opts = options.load(sys.argv,
>> optargs = optargs,
>> @@ -257,6 +260,7 @@ def run(command_path = None):
>> exe_filter = default_exefilter
>> opts.log_info()
>> log.output('Host: ' + host.label(mode = 'all'))
>> + executables = find_executables(opts.params(), exe_filter)
>> debug_trace = opts.find_arg('--debug-trace')
>> if debug_trace:
>> if len(debug_trace) != 1:
>> @@ -279,6 +283,15 @@ def run(command_path = None):
>> raise error.general('RTEMS BSP not provided or an invalid
>> option')
>> bsp = config.load(bsp[1], opts)
>> bsp_config = opts.defaults.expand(opts.defaults['tester'])
>> + coverage_enabled = opts.find_arg('--coverage')
>> + if coverage_enabled:
>> + if len(coverage_enabled) == 2:
>> + coverage_runner = coverage.coverage_run(opts.defaults,
>> + coverage_enabled[1],
>> + executables)
>> + else:
>> 0,
>> + executables)
>> report_mode = opts.find_arg('--report-mode')
>> if report_mode:
>> if report_mode[1] != 'failures' and \
>> @@ -288,7 +301,6 @@ def run(command_path = None):
>> report_mode = report_mode[1]
>> else:
>> report_mode = 'failures'
>> - executables = find_executables(opts.params(), exe_filter)
>> if len(executables) == 0:
>> raise error.general('no executables supplied')
>> start_time = datetime.datetime.now()
>> @@ -365,6 +377,8 @@ def run(command_path = None):
>> reports.failures(),
>> 'Log', '===', ''] + output.get()
>> mail.send(to_addr, subject, os.linesep.join(body))
>> + coverage_runner.run()
>> except error.general as gerr:
>> print(gerr)
>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> index 6b5e7e6..2f89117 100644
>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> @@ -31,9 +31,10 @@
>> # The Leon 3 QEMU BSP
>> -[leon3-qemu]
>> +[leon3-qemu-cov]
>> bsp = leon3-qemu
>> arch = sparc
>> +target = sparc-rtems5
>> tester = %{_rtscripts}/qemu.cfg
>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>> b/tester/rtems/testing/coverage/symbol-sets.ini
>> index 0000000..a2ec7bc
>> --- /dev/null
>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>> @@ -0,0 +1,36 @@
>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>> met:
>> notice,
>> notice,
>> documentation
>> "AS IS"
>> THE
>> PURPOSE
>> BE
>> BUSINESS
>> THE
>> +[symbol-sets]
>> +sets = score,rtems
>> +[libraries]
>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cf
>> g
>> index bfcd2f5..52a3752 100644
>> --- a/tester/rtems/testing/qemu.cfg
>> +++ b/tester/rtems/testing/qemu.cfg
>> @@ -51,8 +51,8 @@
>> # Qemu common option patterns.
>> -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> -nographic
>> -%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> -nographic
>> +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> -nographic
>> +#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> -nographic
>> %define qemu_opts_no_net -net none
>> 2.14.3
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180606/705f00b0/attachment-0001.html>
