[PATCH] tools: Remove shgen
Tue Jun 12 05:09:08 UTC 2018
On 11/06/18 16:23, Gedare Bloom wrote:
> On Mon, Jun 11, 2018 at 8:48 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> All tools should be removed from the RTEMS source repository at some
>> point in time. Tools with a BSD-style license will be moved to the RTEMS
>> tools repository. Unfortunately, the shgen tool is GPL licensed.
>> Remove all uses of this tool from the code base. Replace generated files
>> with stub functions. If users of this BSP still exist, they can
>> reimplement the functionality using a BSD-style license.
> Is there a README that needs to be updated, or was the procedure for
> this shgen stuff just integrated in the build process? Probably, it
> should be noted in the (pending) BSP Supplemental:)
The shgen tool was not mentioned in a README or another documentation file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
