[PATCH] libfs/jffs2: Force the inode size to a non-zero value if a directory.
Tue Mar 13 06:50:11 UTC 2018
On 13/03/18 07:47, Chris Johns wrote:
> On 13/03/2018 17:18, Sebastian Huber wrote:
>> On 13/03/18 00:49, Chris Johns wrote:
>>> Set the inode size to 256 to work around a newlib scandir check where a
>>> directory has to have a non-zero size to work. Set the size to greater than
>>> 24 bytes, a small dirent size so the allocator in scandir works.
>>> The newlib scandir code should be updated to a more recent scandir from
>>> FreeBSD where these checks have been removed. This change is a work
>>> around to avoid new tools on the release branch.
>>> With this change scandir works on IMFS, RFS and JFFS2.
>> I cannot find a scandir() test in the fstests for all file systems.
>>> Closes #3332
>>>    cpukit/libfs/src/jffs2/src/fs-rtems.c | 3 +++
>>>    1 file changed, 3 insertions(+)
>>> diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>> b/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>> index ce84d44470..790929d856 100644
>>> --- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>> +++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
>>> @@ -1512,6 +1512,9 @@ static int jffs2_read_inode (struct _inode *inode)
>>>        inode->i_mtime = je32_to_cpu(latest_node.mtime);
>>>        inode->i_ctime = je32_to_cpu(latest_node.ctime);
>>>    +    if (S_ISDIR(inode->i_mode))
>>> +        inode->i_size = 256;
>>>        inode->i_nlink = f->inocache->pino_nlink;
>>>        mutex_unlock(&f->sem);
>> This code is from the original JFFS2 support for eCos. Which side-effects has
>> this i_size change for directories? Why can't you place this hack in
>> rtems_jffs2_fstat()? This would reduce the impact area of this change.
> I did not know the history of the RTEMS wrapper. I just assumed all code in that
> file is specific to RTEMS. The change I have makes things consistent. I still
> think it is OK?
What do you mean with consistent? I thought this is a hack to make the
Newlib scandir() happy? This i_size is used in several places. How do
you know that you didn't accidentally broke something?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
