RTEMS monitor commands and the shell
Sun Mar 18 21:34:46 UTC 2018
Thomas, Paul and Sebastian, thank you for the feedback.
It seems like it would be nice to have this command controlled somehow and it is
something that should be fixed. I will take a look and see what I can do and
will report back with any issues or a patch.
Again thanks
On 16/03/2018 18:43, Paul Whitfield wrote:
> We have hit this problem with rtems 4.10.
> I think the monitor commands should be treated the same as the other shell commands.
> It should be possible to disable via shellconfig.h - by default all are enabled, but that can be disabled.
> In our application, the monitor 'exit' command was particularly problematic because customers connect to the monitor via telnet then type exit to end the telnet session.
> The exit command would trigger a fatal error exception, resulting in several bug reports that were 'device restarted for no reason'. :-(
> Regards
> Paul Whitfield
> Paul Whitfield
> -----Original Message-----
> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Chris Johns
> Sent: Friday, 16 March 2018 3:01 PM
> To: Development
> Subject: RTEMS monitor commands and the shell
> Hi,
> The monitor commands are registered automatically in `rtems_shell_init_once()` which means an application has no control over these being present, the command mix and naming, for example there is a `config` command in the monitor.
> I am not sure what to do, if it is removed some applications may break assuming these commands are present. A way to disable the command using shellconfig.h would be nice.
> Suggestions?
> Chris
> devel mailing list
> devel at rtems.org
> Scanned by Moncrieff Technology Solutions Secure Mail Appliance
