Errors returned while building a SPARC tool set
Aditya Upadhyay aadit0402 at gmail.com
Thu May 10 05:07:28 UTC 2018
Hi Dannie,
Did you check the python version? It should be a development version.
First run this command:
sudo apt-get python2.7-dev
then try
../source-builder/sb-set-builder --log=1-sparc.txt
--prefix=$HOME/development/rtems config/5/rtems-sparc64.bset
Hope, It will solve your problem.
Regards,
aditya
On Thu, May 10, 2018 at 10:21 AM, Danxue Huang <danxue.huang at gmail.com> wrote:
> Hi folks,
> I just got a new laptop (Windows system) and I got stuck on building a SPARC
> tool set using Ubuntu in Virtual Box. To build a SPARC tool set, I use the
> command as below.
> Is there anything wrong in it? After I input this command, it kept building
> for an hour but finally returned "Build FAILED", errors returned as below.
> error: building sparc-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
> I also attached l-sparc.txt which is used to build a SPARC tool set, I would
> appreciate that if any of you can do me a favor to check it.
> Thank you so much!
> Best,
> Dannie
> devel mailing list
> devel at rtems.org
