Errors returned while building a SPARC tool set
Danxue Huang danxue.huang at gmail.com
Thu May 10 16:01:13 UTC 2018
Hey Aditya,
Thank you so much for you reminder, the problem is solved! :D
Best,
Dannie
On Thu, May 10, 2018 at 12:07 AM, Aditya Upadhyay <aadit0402 at gmail.com>
wrote:
> Hi Dannie,
> Did you check the python version? It should be a development version.
> First run this command:
> sudo apt-get python2.7-dev
> then try
> ../source-builder/sb-set-builder --log=1-sparc.txt
> --prefix=$HOME/development/rtems config/5/rtems-sparc64.bset
> Hope, It will solve your problem.
> Regards,
> aditya
> On Thu, May 10, 2018 at 10:21 AM, Danxue Huang <danxue.huang at gmail.com>
> wrote:
> > Hi folks,
> > I just got a new laptop (Windows system) and I got stuck on building a
> SPARC
> > tool set using Ubuntu in Virtual Box. To build a SPARC tool set, I use
> the
> > command as below.
> > Is there anything wrong in it? After I input this command, it kept
> building
> > for an hour but finally returned "Build FAILED", errors returned as
> below.
> > error: building sparc-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
> > I also attached l-sparc.txt which is used to build a SPARC tool set, I
> would
> > appreciate that if any of you can do me a favor to check it.
> > Thank you so much!
> > Best,
> > Dannie
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180510/d419cadf/attachment-0001.html>
