Errors returned while building a SPARC tool set
Thu May 10 07:28:41 UTC 2018
On 10/5/18 4:47 am, Danxue Huang wrote:
> Hi Dr. Johns,
Hi, please feel free to use Chris. And thanks for the promotion to Dr but Joel
and Gedare are the esteemed doctors :)
> I just got a new laptop (Windows) and I got stuck on building a SPARC tool set
> using Ubuntu in Virtual Box. To build a SPARC tool set, I use the command as below.
> ../source-builder/sb-set-builder --log=1-sparc.txt
> --prefix=$HOME/development/rtems config/5/rtems-sparc64.bset
> Is there anything wrong in it? After I input this command, it kept building for
> an hour but finally returned "Build FAILED", errors returned as follows.
> error: building sparc-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
> I also attached l-sparc.txt which is used to build a SPARC tool set, I would
> appreciate that if you can do me a favor to check it.
I assume this is in a VM because it is Windows. Is that true? Are you sharing
disk space with the Windows host in the VM? This can sometime do weird things
when building the tools.
