[PATCH] bsps/riscv: Rename riscv_generic to riscv32_generic and add compiler flags
Mon May 28 11:01:50 UTC 2018
On 28/05/18 12:02, Hesham Almatary wrote:
> On Mon, May 28, 2018 at 10:55 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 28/05/18 11:47, Hesham Almatary wrote:
>>> This makes it explicitly 32-bit. Compiler flags are needed if built with
>>> a non riscv32-* toolchain (e.g. riscv64-* with multilib).
>> I would like to rename the BSPs to use the ISA name, e.g. rv32imac,
>> rv64imafdc, etc. I also would like to add support for Qemu and use the
>> device tree for the driver initialization (clock, console, interrupt
>> controller).
> Sounds good. Are you working on that?
Yes:
https://devel.rtems.org/ticket/3433
We need also floating-point support.
> This should make them a bit more generic. Does the spike
>> simulator provide a device tree?
> Yes it does.
Ok, good. I will try to install this simulator as well.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
