[PATCH 2/2] sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.h
Tue May 15 14:17:39 UTC 2018
On Tue, May 15, 2018 at 7:59 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I have no problem with it, but it must be tested :) Just a
> compile-only check is fine.
Awesome! I will test the patch. I did this on a machine without sparc64
tools
just to see if I could find an answer.
--joel
> On Mon, May 14, 2018 at 4:33 PM, Joel Sherrill <joel at rtems.org> wrote:
> > I haven't tested this but what do you think of this?
> > -RTEMS_BSPOPTS_SET([US3],[usiii],[1])
> > -RTEMS_BSPOPTS_SET([US3],[*],[])
> > -RTEMS_BSPOPTS_HELP([US3],
> > -[If defined, enable UltraSPARC optons for the USIII BSP.])
> > -RTEMS_BSPOPTS_SET([SUN4U],[usiii],[1])
> > -RTEMS_BSPOPTS_SET([SUN4U],[*],[])
> > -RTEMS_BSPOPTS_HELP([SUN4U],
> > -[If defined, enable SUN model optons for the USIII BSP.])
> > +AC_DEFINE(US3, 1, [UltraSPARC model option])
> > +AC_DEFINE(SUN4U, 1, [SUN model option])
> > On Sun, May 13, 2018 at 11:16 AM, Joel Sherrill <joel at rtems.org> wrote:
> >> On Sun, May 13, 2018, 10:20 AM Gedare Bloom <gedare at rtems.org> wrote:
> >>> On Wed, May 9, 2018 at 4:23 PM, Joel Sherrill <joel at rtems.org> wrote:
> >>> > Updates #3425.
> >>> >  bsps/sparc64/include/arch/arch.h              |  4 ++++
> >>> >  bsps/sparc64/include/arch/mm/frame.h          |  4 ++++
> >>> >  bsps/sparc64/include/arch/mm/mmu.h            |  4 ++++
> >>> >  bsps/sparc64/include/arch/mm/tlb.h            |  3 +++
> >>> >  bsps/sparc64/include/arch/mm/tte.h            |  4 ++++
> >>> >  bsps/sparc64/niagara/config/niagara.cfg       |  2 +-
> >>> >  bsps/sparc64/usiii/config/usiii.cfg           |  2 +-
> >>> >  c/src/lib/libbsp/sparc64/niagara/configure.ac |  4 ++++
> >>> >  c/src/lib/libbsp/sparc64/usiii/configure.ac   | 10 +++++++++-
> >>> >  9 files changed, 34 insertions(+), 3 deletions(-)
> >>> > diff --git a/bsps/sparc64/include/arch/arch.h
> >>> > b/bsps/sparc64/include/arch/arch.h
> >>> > index 5fdd4a2..36aa922 100644
> >>> > --- a/bsps/sparc64/include/arch/arch.h
> >>> > +++ b/bsps/sparc64/include/arch/arch.h
> >>> > @@ -37,10 +37,14 @@
> >>> >  #ifndef KERN_sparc64_ARCH_H_
> >>> >  #define KERN_sparc64_ARCH_H_
> >>> > +#include <bspopts.h>
> >>> >  #if defined (SUN4U)
> >>> >  #include <arch/sun4u/arch.h>
> >>> >  #elif defined (SUN4V)
> >>> >  #include <arch/sun4v/arch.h>
> >>> > +#else
> >>> > +#error "No SUN model defined"
> >>> >  #endif
> >>> >  #define ASI_AIUP               0x10    /** Access to primary context
> >>> > with user privileges. */
> >>> > diff --git a/bsps/sparc64/include/arch/mm/frame.h
> >>> > b/bsps/sparc64/include/arch/mm/frame.h
> >>> > index fb66e54..2fc17cc 100644
> >>> > --- a/bsps/sparc64/include/arch/mm/frame.h
> >>> > +++ b/bsps/sparc64/include/arch/mm/frame.h
> >>> > @@ -35,10 +35,14 @@
> >>> >  #ifndef KERN_sparc64_FRAME_H_
> >>> >  #define KERN_sparc64_FRAME_H_
> >>> >  #if defined (SUN4U)
> >>> >  #include <arch/mm/sun4u/frame.h>
> >>> >  #include <arch/mm/sun4v/frame.h>
> >>> > +#else
> >>> >  #endif
> >>> >  #endif
> >>> > diff --git a/bsps/sparc64/include/arch/mm/mmu.h
> >>> > b/bsps/sparc64/include/arch/mm/mmu.h
> >>> > index 1d445f2..aab143f 100644
> >>> > --- a/bsps/sparc64/include/arch/mm/mmu.h
> >>> > +++ b/bsps/sparc64/include/arch/mm/mmu.h
> >>> > @@ -35,10 +35,14 @@
> >>> >  #ifndef KERN_sparc64_MMU_H_
> >>> >  #define KERN_sparc64_MMU_H_
> >>> >  #if defined (SUN4U)
> >>> >  #include <arch/mm/sun4u/mmu.h>
> >>> >  #include <arch/mm/sun4v/mmu.h>
> >>> > +#else
> >>> >  #endif
> >>> > diff --git a/bsps/sparc64/include/arch/mm/tlb.h
> >>> > b/bsps/sparc64/include/arch/mm/tlb.h
> >>> > index 4adf26c..7a6b85d 100644
> >>> > --- a/bsps/sparc64/include/arch/mm/tlb.h
> >>> > +++ b/bsps/sparc64/include/arch/mm/tlb.h
> >>> > @@ -35,11 +35,14 @@
> >>> >  #ifndef KERN_sparc64_TLB_H_
> >>> >  #define KERN_sparc64_TLB_H_
> >>> >  #if defined (SUN4U)
> >>> >  #include <arch/mm/sun4u/tlb.h>
> >>> >  #include <arch/mm/sun4v/tlb.h>
> >>> > +#else
> >>> >  #endif
> >>> >  #endif
> >>> > diff --git a/bsps/sparc64/include/arch/mm/tte.h
> >>> > b/bsps/sparc64/include/arch/mm/tte.h
> >>> > index f0b746e..10a672b 100644
> >>> > --- a/bsps/sparc64/include/arch/mm/tte.h
> >>> > +++ b/bsps/sparc64/include/arch/mm/tte.h
> >>> > @@ -35,10 +35,14 @@
> >>> >  #ifndef KERN_sparc64_TTE_H_
> >>> >  #define KERN_sparc64_TTE_H_
> >>> >  #if defined (SUN4U)
> >>> >  #include <arch/mm/sun4u/tte.h>
> >>> >  #include <arch/mm/sun4v/tte.h>
> >>> > +#else
> >>> >  #endif
> >>> >  #endif
> >>> > diff --git a/bsps/sparc64/niagara/config/niagara.cfg
> >>> > b/bsps/sparc64/niagara/config/niagara.cfg
> >>> > index 2fd8973..bfa73aa 100644
> >>> > --- a/bsps/sparc64/niagara/config/niagara.cfg
> >>> > +++ b/bsps/sparc64/niagara/config/niagara.cfg
> >>> > @@ -7,7 +7,7 @@ RTEMS_CPU=sparc64
> >>> >  #  This contains the compiler options necessary to select the CPU
> >>> > model
> >>> >  #  and (hopefully) optimize for it.
> >>> > -CPU_CFLAGS = -mcpu=niagara -DSUN4V
> >>> > +CPU_CFLAGS = -mcpu=niagara
> >>> >  # optimize flag: typically -g -O2
> >>> >  CFLAGS_OPTIMIZE_V = -g -O2
> >>> > diff --git a/bsps/sparc64/usiii/config/usiii.cfg
> >>> > b/bsps/sparc64/usiii/config/usiii.cfg
> >>> > index b9fad21..ee1c508 100644
> >>> > --- a/bsps/sparc64/usiii/config/usiii.cfg
> >>> > +++ b/bsps/sparc64/usiii/config/usiii.cfg
> >>> > model
> >>> > -CPU_CFLAGS = -mcpu=ultrasparc3 -DUS3 -DSUN4U
> >>> > +CPU_CFLAGS = -mcpu=ultrasparc3
> >>> > diff --git a/c/src/lib/libbsp/sparc64/niagara/configure.ac
> >>> > b/c/src/lib/libbsp/sparc64/niagara/configure.ac
> >>> > index ced7e12..f8e9687 100644
> >>> > --- a/c/src/lib/libbsp/sparc64/niagara/configure.ac
> >>> > +++ b/c/src/lib/libbsp/sparc64/niagara/configure.ac
> >>> > @@ -10,6 +10,10 @@ RTEMS_CANONICAL_TARGET_CPU
> >>> >  AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> >>> >  RTEMS_BSP_CONFIGURE
> >>> > +RTEMS_BSPOPTS_SET([SUN4V],[niagara],[1])
> >>> > +RTEMS_BSPOPTS_SET([SUN4V],[*],[])
> >>> > +RTEMS_BSPOPTS_HELP([SUN4V],
> >>> > +[If defined, enable SUN model optons for the Niagara model.])
> >>> >  RTEMS_BSP_CLEANUP_OPTIONS
> >>> > diff --git a/c/src/lib/libbsp/sparc64/usiii/configure.ac
> >>> > b/c/src/lib/libbsp/sparc64/usiii/configure.ac
> >>> > index 4244055..c99d938 100644
> >>> > --- a/c/src/lib/libbsp/sparc64/usiii/configure.ac
> >>> > +++ b/c/src/lib/libbsp/sparc64/usiii/configure.ac
> >>> > @@ -10,13 +10,21 @@ RTEMS_CANONICAL_TARGET_CPU
> >>> >  RTEMS_BSP_CONFIGURE
> >>> >  RTEMS_BSPOPTS_SET([SIMSPARC_FAST_IDLE],[*],[])
> >>> >  RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
> >>> >  [If defined, speed up the clock ticks while the idle task is running
> >>> > so
> >>> >  time spent in the idle task is minimized.  This significantly
> reduces
> >>> >  the wall time required to execute the RTEMS test suites.])
> >>> > +RTEMS_BSPOPTS_SET([US3],[usiii],[1])
> >>> > +RTEMS_BSPOPTS_SET([US3],[*],[])
> >>> > +RTEMS_BSPOPTS_HELP([US3],
> >>> > +[If defined, enable UltraSPARC optons for the USIII BSP.])
> >>> > +RTEMS_BSPOPTS_SET([SUN4U],[usiii],[1])
> >>> > +RTEMS_BSPOPTS_SET([SUN4U],[*],[])
> >>> > +RTEMS_BSPOPTS_HELP([SUN4U],
> >>> > +[If defined, enable SUN model optons for the USIII BSP.])
> >>> These are not really "optional" defines. It doesn't make sense for
> >>> example to compile an ultrasparc3 BSP without the SUN4U define. I
> >>> don't really know if this matters.
> >> Feel free to change it to whatever autoconf magic forces the setting
> >> without providing an override option.
> >>> > 1.8.3.1
> >>> > _______________________________________________
> >>> > devel mailing list
> >>> > devel at rtems.org
> >>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180515/bc790da1/attachment-0002.html>
