GR740-SMP BSP test results (gcc-7.2)
Thu Sep 20 05:32:13 UTC 2018
Hello Daniel,
thanks for your status report. The RSB uses currently GCC 7.3.0 without
patches and the Newlib commit d13c84eb07e35984bf7a974cd786a6cdac29e6b9.
On 19/09/2018 14:46, Daniel Hellstrom wrote:
> Hi,
> I just wanted to share the current test status for the GR740 I have
> today, using the todays master with some additional test fixes which I
> plan to submit shortly. The test have been run both on TSIM and hardware.
> Current test results for the RTEMS test-suite with GCC-7.2 toolchain
> for the GR740 quad-core LEON4 BSP in SMP driver manager configuration:
>   # RTEMS TESTSUITE FAILURE SUMMARY
>   # Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
>   # FAIL: minimum OK N/A 0 5
Ok, known issue, the test has no output.
>   # FAIL: spcpucounter01 OK FAIL 5 0
This was a bug. It should be fixed with this commit:
https://git.rtems.org/rtems/commit/?id=b3cf79b9c472ed8c219f8c9a9d8fb571671f3815
>   # FAIL: spfatal07 FAIL N/A N/A N/A
>   # FAIL: spinternalerror01 OK N/A -559038737 1611526157
This is a known issue. Test exit before the device enumeration.
>   # FAIL: sptimecounter01 OK N/A 5 0
>   # SUMMARY
>   #  Tests failing:    5
>   #  Tests successful: 624
> spfatal07 - problem with the test itself.
> CONFIGURE_INTERRUPT_STACK_SIZE is too small, the boot process fails
> before reaching the check. This is a new behavior since interrupt
> stack is also used by the CPU for initialization/boot process.
Ok, thanks for the pointer. I changed the interrupt/initialization stack
machinery recently. I think that this internal error is superfluous now
or needs to be adjusted. This ticket is related to this topic:
https://devel.rtems.org/ticket/3480
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
