sparc/leon3 in git master?
Cudmore, Alan P. (GSFC-5820) alan.p.cudmore at nasa.gov
Tue Sep 11 19:25:03 UTC 2018
Sorry for the false alarm, but I found out why it did not work.
My leon3 BSP configure command had –enable-smp
Once I removed that, it worked on both QEMU and TSIM-LEON3.
The ut699 BSP worked as well.
Does an SMP enabled kernel/bsp only work on a system where there are > 1 cores?
Thanks,
Alan
From: devel <devel-bounces at rtems.org> on behalf of Alan Cudmore <alan.p.cudmore at nasa.gov>
Date: Tuesday, September 11, 2018 at 3:01 PM
To: "rtems-devel at rtems.org" <devel at rtems.org>
Subject: sparc/leon3 in git master?
I use RTEMS 4.11 on several leon3 targets, and I have been starting to work with the git master to get ready for RTEMS 5.
With 4.11, I can run ticker, hello, and other samples on TSIM2-LEON3, QEMU with Jiri’s leon3 patches, or real Leon3 targets.
When I run the ticker or hello for RTEMS 5 (RSB toolchain and RTEMS built today) on QEMU or TSIM2 they immediately return with no output.
I tried ticker for the sparc/erc32 BSP on SIS and it works.
Before I start debugging, has anyone else used the generic Leon3 target on RTEMS 5 lately?
Thanks,
Alan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180911/5ba0887b/attachment-0002.html>
