[PATCH 3/3] rtems: Add rtems_scheduler_get_processor_maximum()
Fri Apr 5 07:15:10 UTC 2019
Add rtems_scheduler_get_processor_maximum() as a replacement for
rtems_get_processor_count(). The rtems_get_processor_count() is a bit
orphaned. Adopt it by the Scheduler Manager. The count is also
misleading, since the processor set may have gaps and the actual count
of online processors may be less than the value returned by
Update #3732.
 bsps/riscv/griscv/clock/clockdrv.c              |  2 +-
 bsps/riscv/griscv/irq/irq.c                     |  4 +-
 bsps/shared/irq/irq-server.c                    |  4 +-
 bsps/sparc/leon3/clock/ckinit.c                 |  2 +-
 bsps/sparc/leon3/start/bspclean.c               |  2 +-
 bsps/sparc/leon3/start/eirq.c                   |  4 +-
 cpukit/headers.am                               |  1 -
 cpukit/include/rtems.h                          |  1 -
 cpukit/include/rtems/rtems/smp.h                | 59 -------------------------
 cpukit/include/rtems/rtems/tasks.h              | 33 ++++++++++++++
 cpukit/libmisc/capture/capture.c                |  6 +--
 cpukit/libmisc/capture/capture_support.c        |  2 +-
 cpukit/libmisc/cpuuse/cpuusagereset.c           |  2 +-
 cpukit/libmisc/stackchk/check.c                 |  2 +-
 cpukit/libtest/t-test-rtems-measure.c           |  2 +-
 cpukit/libtest/testparallel.c                   |  6 +--
 cpukit/libtrace/record/record-server.c          |  2 +-
 cpukit/posix/src/sysconf.c                      |  2 +-
 cpukit/rtems/src/getprocessorcount.c            |  4 +-
 cpukit/sapi/src/profilingiterate.c              |  2 +-
 testsuites/psxtests/psxsysconf/init.c           |  3 +-
 testsuites/smptests/smp01/init.c                |  6 +--
 testsuites/smptests/smp02/init.c                |  4 +-
 testsuites/smptests/smp03/init.c                | 12 ++---
 testsuites/smptests/smp05/init.c                |  4 +-
 testsuites/smptests/smp07/init.c                |  2 +-
 testsuites/smptests/smp08/init.c                |  2 +-
 testsuites/smptests/smp09/init.c                |  2 +-
 testsuites/smptests/smpaffinity01/init.c        |  2 +-
 testsuites/smptests/smpcache01/init.c           | 17 ++++---
 testsuites/smptests/smpcapture01/init.c         |  2 +-
 testsuites/smptests/smpcapture02/init.c         |  2 +-
 testsuites/smptests/smpclock01/init.c           |  2 +-
 testsuites/smptests/smpfatal01/init.c           |  8 +++-
 testsuites/smptests/smpfatal02/init.c           |  8 +++-
 testsuites/smptests/smpipi01/init.c             |  4 +-
 testsuites/smptests/smpload01/init.c            |  6 +--
 testsuites/smptests/smpmigration01/init.c       |  2 +-
 testsuites/smptests/smpmigration02/init.c       |  8 ++--
 testsuites/smptests/smpmrsp01/init.c            |  8 ++--
 testsuites/smptests/smpmutex01/init.c           |  4 +-
 testsuites/smptests/smpmutex02/init.c           |  2 +-
 testsuites/smptests/smpopenmp01/init.c          |  2 +-
 testsuites/smptests/smppsxaffinity01/init.c     |  2 +-
 testsuites/smptests/smppsxaffinity02/init.c     |  2 +-
 testsuites/smptests/smppsxmutex01/init.c        |  2 +-
 testsuites/smptests/smppsxsignal01/init.c       |  2 +-
 testsuites/smptests/smpschedaffinity01/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity02/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity03/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity04/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity05/init.c   |  2 +-
 testsuites/smptests/smpschededf02/init.c        |  2 +-
 testsuites/smptests/smpschededf03/init.c        |  2 +-
 testsuites/smptests/smpschededf04/init.c        |  2 +-
 testsuites/smptests/smpscheduler01/init.c       |  2 +-
 testsuites/smptests/smpscheduler02/init.c       |  4 +-
 testsuites/smptests/smpscheduler04/init.c       |  6 +--
 testsuites/smptests/smpsignal01/init.c          |  2 +-
 testsuites/smptests/smpstrongapa01/init.c       |  2 +-
 testsuites/smptests/smpswitchextension01/init.c |  2 +-
 testsuites/smptests/smpthreadlife01/init.c      |  2 +-
 testsuites/smptests/smpthreadpin01/init.c       |  2 +-
 testsuites/smptests/smpwakeafter01/init.c       |  2 +-
 testsuites/sptests/sppercpudata01/init.c        | 18 ++++++--
 testsuites/tmtests/tmcontext01/init.c           |  2 +-
 66 files changed, 161 insertions(+), 161 deletions(-)
 delete mode 100644 cpukit/include/rtems/rtems/smp.h
diff --git a/bsps/riscv/griscv/clock/clockdrv.c b/bsps/riscv/griscv/clock/clockdrv.c
index 47ed6b305d..c94c167fdf 100644
--- a/bsps/riscv/griscv/clock/clockdrv.c
+++ b/bsps/riscv/griscv/clock/clockdrv.c
@@ -80,7 +80,7 @@ static void grlib_tc_tick_irqmp_timestamp_init(void)
   bool done =
     _Atomic_Fetch_add_uint(&counter, 1, ATOMIC_ORDER_RELAXED)
-      == rtems_get_processor_count() - 1;
+      == rtems_scheduler_get_processor_maximum() - 1;
 #else
   bool done = true;
 #endif
diff --git a/bsps/riscv/griscv/irq/irq.c b/bsps/riscv/griscv/irq/irq.c
index 721cd98ffe..e3fc8c310f 100644
--- a/bsps/riscv/griscv/irq/irq.c
+++ b/bsps/riscv/griscv/irq/irq.c
@@ -108,7 +108,7 @@ void bsp_interrupt_get_affinity(
   Processor_mask *affinity
-  uint32_t cpu_count = rtems_get_processor_count();
+  uint32_t cpu_count = rtems_scheduler_get_processor_maximum();
   uint32_t cpu_index;
   _Processor_mask_Zero(affinity);
@@ -126,7 +126,7 @@ void bsp_interrupt_set_affinity(
   uint32_t unmasked = 0;
   uint32_t cpu_index;
   for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
diff --git a/bsps/shared/irq/irq-server.c b/bsps/shared/irq/irq-server.c
index 7a2bc55c48..fad0fc661f 100644
--- a/bsps/shared/irq/irq-server.c
+++ b/bsps/shared/irq/irq-server.c
@@ -60,7 +60,7 @@ static bsp_interrupt_server_context *bsp_interrupt_server_get_context(
 #endif
-  if (server_index >= rtems_get_processor_count()) {
+  if (server_index >= rtems_scheduler_get_processor_maximum()) {
     *sc = RTEMS_INVALID_ID;
     return NULL;
@@ -504,7 +504,7 @@ rtems_status_code rtems_interrupt_server_initialize(
     server_count = &dummy;
-  cpu_count = rtems_get_processor_count();
+  cpu_count = rtems_scheduler_get_processor_maximum();
 #if defined(RTEMS_SMP)
   instances = calloc(cpu_count, sizeof(*instances));
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index ad233ddb90..f485123f6b 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -76,7 +76,7 @@ static void leon3_tc_tick_irqmp_timestamp_init(void)
   bool done =
 #else
   bool done = true;
 #endif
diff --git a/bsps/sparc/leon3/start/bspclean.c b/bsps/sparc/leon3/start/bspclean.c
index 6cdc43e4d5..e11ec4b0f3 100644
--- a/bsps/sparc/leon3/start/bspclean.c
+++ b/bsps/sparc/leon3/start/bspclean.c
@@ -49,7 +49,7 @@ void bsp_fatal_extension(
       uint32_t max_wait = 1234567;
       uint32_t self_cpu = rtems_scheduler_get_processor();
       uint32_t halt_mask = 0;
       uint32_t i;
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index 1f7be1ba74..b4cd6d2948 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -31,7 +31,7 @@ void bsp_interrupt_set_affinity(
   uint32_t cpu_index;
@@ -53,7 +53,7 @@ void bsp_interrupt_get_affinity(
   uint32_t cpu_index;
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 69cdb525ef..c9fe38acf3 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -274,7 +274,6 @@ include_rtems_rtems_HEADERS += include/rtems/rtems/semmp.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/signal.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/signalimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/signalmp.h
-include_rtems_rtems_HEADERS += include/rtems/rtems/smp.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/status.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/statusimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/support.h
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index 20a1705dc5..9f6f9cc659 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -55,7 +55,6 @@
 #if defined(RTEMS_MULTIPROCESSING)
 #include <rtems/rtems/mp.h>
 #endif
-#include <rtems/rtems/smp.h>
 #include <rtems/score/stack.h>
diff --git a/cpukit/include/rtems/rtems/smp.h b/cpukit/include/rtems/rtems/smp.h
deleted file mode 100644
index 046c306290..0000000000
--- a/cpukit/include/rtems/rtems/smp.h
+++ /dev/null
@@ -1,59 +0,0 @@
- * @file
- * @ingroup ClassicSMP
- * @brief SMP Services API
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_RTEMS_SMP_H
-#define _RTEMS_RTEMS_SMP_H
-#include <stdint.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup ClassicSMP SMP Services
- * @ingroup RTEMSAPIClassic
- * This encapsulates functionality which is useful for SMP applications.
- * @brief Returns the count of processors in the system.
- * On uni-processor configurations a value of one will be returned.
- * On SMP configurations this returns the value of a global variable set during
- * system initialization to indicate the count of utilized processors.  The
- * processor count depends on the physically or virtually available processors
- * and application configuration.  The value will always be less than or equal
- * to the maximum count of application configured processors.
- * @return The count of processors being utilized.
-uint32_t rtems_get_processor_count(void);
-#ifdef __cplusplus
-#endif
-#endif
-/* end of include file */
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 630a5c5295..307b1b13aa 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -617,6 +617,39 @@ rtems_get_current_processor( void )
   return rtems_scheduler_get_processor();
+ * @brief Returns the processor maximum supported by the system.
+ * In uniprocessor configurations, a value of one will be returned.
+ * In SMP configurations, this function returns the minimum of the processors
+ * (physically or virtually) available by the platform and the configured
+ * processor maximum.  Not all processors in the range from processor index
+ * zero to the last processor index (which is the processor maximum minus one)
+ * may be configured to be used by a scheduler or online (online processors
+ * have a scheduler assigned).
+ * @return The processor maximum supported by the system.
+ * @see rtems_scheduler_add_processor() and rtems_scheduler_remove_processor().
+RTEMS_CONST uint32_t rtems_scheduler_get_processor_maximum( void );
+ * @deprecated
+ * Use rtems_scheduler_get_processor_maximum() instead.
+RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t
+rtems_get_processor_count( void )
+  return rtems_scheduler_get_processor_maximum();
  * @brief Gets the set of processors owned by the specified scheduler instance.
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 6accd509e7..bba7d91396 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -599,7 +599,7 @@ rtems_capture_open (uint32_t   size, rtems_capture_timestamp timestamp RTEMS_UNU
     return RTEMS_RESOURCE_IN_USE;
-  count = rtems_get_processor_count();
+  count = rtems_scheduler_get_processor_maximum();
   if (capture_per_cpu == NULL) {
     capture_per_cpu = calloc( count, sizeof( *capture_per_cpu ) );
@@ -686,7 +686,7 @@ rtems_capture_close (void)
   capture_controls = NULL;
-  for (cpu=0; cpu < rtems_get_processor_count(); cpu++) {
+  for (cpu=0; cpu < rtems_scheduler_get_processor_maximum(); cpu++) {
     if (capture_records_on_cpu(cpu).buffer)
       rtems_capture_buffer_destroy( &capture_records_on_cpu(cpu) );
@@ -788,7 +788,7 @@ rtems_capture_flush (bool prime)
     else
       capture_flags_global &= ~RTEMS_CAPTURE_OVERFLOW;
       RTEMS_INTERRUPT_LOCK_REFERENCE( lock, &(capture_lock_on_cpu( cpu )) )
       rtems_interrupt_lock_context lock_context_per_cpu;
diff --git a/cpukit/libmisc/capture/capture_support.c b/cpukit/libmisc/capture/capture_support.c
index 60006e7dd8..4af8822c79 100644
--- a/cpukit/libmisc/capture/capture_support.c
+++ b/cpukit/libmisc/capture/capture_support.c
@@ -268,7 +268,7 @@ rtems_capture_print_trace_records (int total, bool csv)
   rtems_capture_time last_time = 0;
   int                i;
-  cpus = rtems_get_processor_count ();
+  cpus = rtems_scheduler_get_processor_maximum ();
   per_cpu = calloc (cpus, sizeof(*per_cpu));
   if (per_cpu == NULL)
diff --git a/cpukit/libmisc/cpuuse/cpuusagereset.c b/cpukit/libmisc/cpuuse/cpuusagereset.c
index 507044a7ee..455651e19f 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereset.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereset.c
@@ -56,7 +56,7 @@ void rtems_cpu_usage_reset( void )
   _TOD_Get_uptime( &CPU_usage_Uptime_at_last_reset );
   for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
     Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index ce7d1a08cb..a3f9a1d21e 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -477,7 +477,7 @@ void rtems_stack_checker_report_usage_with_plugin(
     RTEMS_DECONST( rtems_printer *, printer )
-  cpu_max = rtems_get_processor_count();
+  cpu_max = rtems_scheduler_get_processor_maximum();
   for ( cpu_index = 0; cpu_index < cpu_max; ++cpu_index ) {
     Stack_check_Dump_interrupt_stack_usage(
diff --git a/cpukit/libtest/t-test-rtems-measure.c b/cpukit/libtest/t-test-rtems-measure.c
index 242855f19f..80b404f1ad 100644
--- a/cpukit/libtest/t-test-rtems-measure.c
+++ b/cpukit/libtest/t-test-rtems-measure.c
@@ -200,7 +200,7 @@ T_measure_runtime_create(const T_measure_runtime_config *config)
 	chunk_size *= 2;
-	load_count = rtems_get_processor_count();
+	load_count = rtems_scheduler_get_processor_maximum();
 	load_size = load_count * sizeof(ctx->load_contexts[0]);
 	ctx = malloc(sizeof(*ctx) + sample_size + load_size + chunk_size +
diff --git a/cpukit/libtest/testparallel.c b/cpukit/libtest/testparallel.c
index ea805a3cf4..4ff26650f5 100644
--- a/cpukit/libtest/testparallel.c
+++ b/cpukit/libtest/testparallel.c
@@ -60,8 +60,8 @@ static void run_tests(
   for (i = 0; i < job_count; ++i) {
     const rtems_test_parallel_job *job = &jobs[i];
-    size_t n = rtems_get_processor_count();
-    size_t j = job->cascade ? 0 : rtems_get_processor_count() - 1;
+    size_t n = rtems_scheduler_get_processor_maximum();
+    size_t j = job->cascade ? 0 : rtems_scheduler_get_processor_maximum() - 1;
     while (j < n) {
       size_t active_worker = j + 1;
@@ -133,7 +133,7 @@ void rtems_test_parallel(
   _Atomic_Init_ulong(&ctx->stop, 0);
   _SMP_barrier_Control_initialize(&ctx->barrier);
-  ctx->worker_count = rtems_get_processor_count();
+  ctx->worker_count = rtems_scheduler_get_processor_maximum();
   ctx->worker_ids[0] = rtems_task_self();
   ctx->jobs = jobs;
   ctx->job_count = job_count;
diff --git a/cpukit/libtrace/record/record-server.c b/cpukit/libtrace/record/record-server.c
index da7cf358d3..840924a24a 100644
--- a/cpukit/libtrace/record/record-server.c
+++ b/cpukit/libtrace/record/record-server.c
@@ -147,7 +147,7 @@ void _Record_Stream_header_initialize( Record_Stream_header *header )
   header->Processor_maximum.event =
     RTEMS_RECORD_TIME_EVENT( 0, RTEMS_RECORD_PROCESSOR_MAXIMUM );
-  header->Processor_maximum.data = rtems_get_processor_count() - 1;
+  header->Processor_maximum.data = rtems_scheduler_get_processor_maximum() - 1;
   header->Count.event = RTEMS_RECORD_TIME_EVENT( 0, RTEMS_RECORD_PER_CPU_COUNT );
   header->Count.data = _Record_Item_count;
diff --git a/cpukit/posix/src/sysconf.c b/cpukit/posix/src/sysconf.c
index c5f66f6f46..7227a6d11c 100644
--- a/cpukit/posix/src/sysconf.c
+++ b/cpukit/posix/src/sysconf.c
@@ -50,7 +50,7 @@ long sysconf(
     case _SC_NPROCESSORS_CONF:
       return (long) rtems_configuration_get_maximum_processors();
     case _SC_NPROCESSORS_ONLN:
-      return (long) rtems_get_processor_count();
+      return (long) rtems_scheduler_get_processor_maximum();
     case _SC_POSIX_26_VERSION:
       return (long) _POSIX_26_VERSION;
 #if defined(__sparc__)
diff --git a/cpukit/rtems/src/getprocessorcount.c b/cpukit/rtems/src/getprocessorcount.c
index 438eec6635..40ab5ef9d9 100644
--- a/cpukit/rtems/src/getprocessorcount.c
+++ b/cpukit/rtems/src/getprocessorcount.c
@@ -16,10 +16,10 @@
   #include "config.h"
 #endif
+#include <rtems/rtems/tasks.h>
 #include <rtems/score/smp.h>
+uint32_t rtems_scheduler_get_processor_maximum(void)
   return _SMP_Get_processor_count();
diff --git a/cpukit/sapi/src/profilingiterate.c b/cpukit/sapi/src/profilingiterate.c
index 9ec46fc97a..79754651f0 100644
--- a/cpukit/sapi/src/profilingiterate.c
+++ b/cpukit/sapi/src/profilingiterate.c
@@ -31,7 +31,7 @@ static void per_cpu_stats_iterate(
 #ifdef RTEMS_PROFILING
-  uint32_t n = rtems_get_processor_count();
+  uint32_t n = rtems_scheduler_get_processor_maximum();
   uint32_t i;
   memset(data, 0, sizeof(*data));
diff --git a/testsuites/psxtests/psxsysconf/init.c b/testsuites/psxtests/psxsysconf/init.c
index 2dd9018722..a008af36bb 100644
--- a/testsuites/psxtests/psxsysconf/init.c
+++ b/testsuites/psxtests/psxsysconf/init.c
@@ -79,7 +79,8 @@ void *POSIX_Init(
   rtems_test_assert(
-    sysconf( _SC_NPROCESSORS_ONLN ) == (long) rtems_get_processor_count()
+    sysconf( _SC_NPROCESSORS_ONLN )
+      == (long) rtems_scheduler_get_processor_maximum()
diff --git a/testsuites/smptests/smp01/init.c b/testsuites/smptests/smp01/init.c
index cf7d5ab9c1..cbfd205010 100644
--- a/testsuites/smptests/smp01/init.c
+++ b/testsuites/smptests/smp01/init.c
@@ -48,12 +48,12 @@ rtems_task Init(
   locked_print_initialize();
   /* Initialize the TaskRan array */
-  for ( i=0; i<rtems_get_processor_count() ; i++ ) {
+  for ( i=0; i<rtems_scheduler_get_processor_maximum() ; i++ ) {
     TaskRan[i] = false;
   /* Create and start tasks for each processor */
-  for ( i=0; i< rtems_get_processor_count() ; i++ ) {
+  for ( i=0; i< rtems_scheduler_get_processor_maximum() ; i++ ) {
     if ( i != cpu_self ) {
       ch = '0' + i;
@@ -78,7 +78,7 @@ rtems_task Init(
   /* Wait on the all tasks to run */
   while (1) {
     allDone = true;
       if ( i != cpu_self && TaskRan[i] == false)
         allDone = false;
diff --git a/testsuites/smptests/smp02/init.c b/testsuites/smptests/smp02/init.c
index fd7c583db8..f7ce857ee3 100644
--- a/testsuites/smptests/smp02/init.c
+++ b/testsuites/smptests/smp02/init.c
@@ -40,7 +40,7 @@ rtems_task Init(
-  if ( rtems_get_processor_count() == 1 ) {
+  if ( rtems_scheduler_get_processor_maximum() == 1 ) {
     success();
@@ -59,7 +59,7 @@ rtems_task Init(
   status = rtems_semaphore_obtain( Semaphore, RTEMS_WAIT, 0);
   directive_failed( status,"rtems_semaphore_obtain of SEM1\n");
-  for ( i=1; i < rtems_get_processor_count(); i++ ){
+  for ( i=1; i < rtems_scheduler_get_processor_maximum(); i++ ){
     /* Create and start tasks for each CPU */
     ch = '0' + i;
diff --git a/testsuites/smptests/smp03/init.c b/testsuites/smptests/smp03/init.c
index 1e9bb69f7a..9f5171128c 100644
--- a/testsuites/smptests/smp03/init.c
+++ b/testsuites/smptests/smp03/init.c
@@ -50,20 +50,22 @@ rtems_task Init(
   char              ch = '0';
   rtems_id          id;
   rtems_status_code status;
+  uint32_t          cpu_max;
   Loop();
   TEST_BEGIN();
+  if ( cpu_max == 1 ) {
     success();
   TaskRan[0] = true;
-  for ( i=1; i<rtems_get_processor_count() ; i++ ) {
+  for ( i=1; i<cpu_max ; i++ ) {
     TaskRan[i] = false;
@@ -71,7 +73,7 @@ rtems_task Init(
   PrintTaskInfo( "Init" );
   /* for each remaining cpu create and start a task */
+  for ( i=1; i < cpu_max; i++ ){
     ch = '0' + i;
@@ -104,13 +106,13 @@ rtems_task Init(
     &id
   directive_failed( status, "rtems_task_create" );
-  status = rtems_task_start(id,Test_task,rtems_get_processor_count());
+  status = rtems_task_start(id,Test_task,cpu_max);
   directive_failed( status, "rtems_task_start" );
   /* Wait on all tasks to run */
   while (1) {
     TestFinished = true;
-    for ( i=1; i < (rtems_get_processor_count()+1) ; i++ ) {
+    for ( i=1; i < (cpu_max+1) ; i++ ) {
       if (TaskRan[i] == false)
         TestFinished = false;
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
index bc2c6cd5ac..75033ff5ae 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
@@ -52,11 +52,11 @@ rtems_task Init(
   TEST_BEGIN();
     success();
     ch = '1' + i;
     status = rtems_task_create(
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
index e4ea76183b..c53642054c 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -99,7 +99,7 @@ rtems_task Init(
   TEST_BEGIN();
     success();
diff --git a/testsuites/smptests/smp08/init.c b/testsuites/smptests/smp08/init.c
index de98865735..5c27a6a084 100644
--- a/testsuites/smptests/smp08/init.c
+++ b/testsuites/smptests/smp08/init.c
@@ -76,7 +76,7 @@ rtems_task Init(
   /* Show that the init task is running on this cpu */
   PrintTaskInfo( "Init", &time );
-  for ( i=1; i <= rtems_get_processor_count() *3; i++ ) {
+  for ( i=1; i <= rtems_scheduler_get_processor_maximum() *3; i++ ) {
     sprintf(ch, "%02" PRIu32, i );
diff --git a/testsuites/smptests/smp09/init.c b/testsuites/smptests/smp09/init.c
index f36f8691b7..ce8334bcd4 100644
--- a/testsuites/smptests/smp09/init.c
+++ b/testsuites/smptests/smp09/init.c
@@ -53,7 +53,7 @@ rtems_task Init(
   for ( killtime=0; killtime<1000000; killtime++ )
-  for ( i=0; i<rtems_get_processor_count() -1; i++ ) {
+  for ( i=0; i<rtems_scheduler_get_processor_maximum() -1; i++ ) {
     ch = '1' + i;
diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
index 4c052ae12a..5d79259e9f 100644
--- a/testsuites/smptests/smpaffinity01/init.c
+++ b/testsuites/smptests/smpaffinity01/init.c
@@ -112,7 +112,7 @@ void Validate_affinity(void )
   directive_failed( sc, "Get Affinity of Init Task" );
   /* Get the number of processors that we are using. */
   /* Fill the remaining cpus with med priority tasks */
   puts( "Init - Create Medium priority tasks");
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index a679764d5d..313a3df2e4 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -82,7 +82,11 @@ static void test_cache_invalidate_multiple_instruction_lines(
 static void barrier( SMP_barrier_State *bs )
-  _SMP_barrier_Wait( &ctx.barrier, bs, rtems_get_processor_count() );
+  _SMP_barrier_Wait(
+    &ctx.barrier,
+    bs,
+    rtems_scheduler_get_processor_maximum()
 static void broadcast_test_init( void )
@@ -101,7 +105,8 @@ static void broadcast_test_body(
 static void broadcast_test_fini( void )
   rtems_test_assert(
-    ctx.count[rtems_scheduler_get_processor()] == rtems_get_processor_count()
+    ctx.count[rtems_scheduler_get_processor()]
@@ -175,9 +180,9 @@ static void cmlog(  const char* str )
 static void all_tests( void )
-  size_t set_size = CPU_ALLOC_SIZE( rtems_get_processor_count() );
-  cpu_set_t *cpu_set = CPU_ALLOC( rtems_get_processor_count() );
+  size_t set_size = CPU_ALLOC_SIZE( cpu_count );
+  cpu_set_t *cpu_set = CPU_ALLOC( cpu_count );
   SMP_barrier_State bs = SMP_BARRIER_STATE_INITIALIZER;
   /* Send message to all available CPUs */
@@ -217,7 +222,7 @@ static void test_smp_cache_manager( void )
   rtems_status_code sc;
   size_t worker_index;
   for (worker_index = 1; worker_index < cpu_count; ++worker_index) {
     rtems_id worker_id;
diff --git a/testsuites/smptests/smpcapture01/init.c b/testsuites/smptests/smpcapture01/init.c
index 52f762eda2..1e3e797ca8 100644
--- a/testsuites/smptests/smpcapture01/init.c
+++ b/testsuites/smptests/smpcapture01/init.c
@@ -103,7 +103,7 @@ static void test(void)
   rtems_task_priority priority;
   if (cpu_count != 4) {
     printf("Test requires a minimum of 4 cores\n");
     return;
diff --git a/testsuites/smptests/smpcapture02/init.c b/testsuites/smptests/smpcapture02/init.c
index 9fc820ef6f..fa801218e6 100644
--- a/testsuites/smptests/smpcapture02/init.c
+++ b/testsuites/smptests/smpcapture02/init.c
@@ -301,7 +301,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
   sc = rtems_capture_open(50000, NULL);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
diff --git a/testsuites/smptests/smpclock01/init.c b/testsuites/smptests/smpclock01/init.c
index 4887ec20e7..109d4bae34 100644
--- a/testsuites/smptests/smpclock01/init.c
+++ b/testsuites/smptests/smpclock01/init.c
@@ -161,7 +161,7 @@ static void Init(rtems_task_argument arg)
   rtems_resource_snapshot_take(&snapshot);
-  if (rtems_get_processor_count() == CPU_COUNT) {
+  if (rtems_scheduler_get_processor_maximum() == CPU_COUNT) {
     test();
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index 463f35acbb..e26d66fdc5 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -67,7 +67,11 @@ static void fatal_extension(
-  _SMP_barrier_Wait(&barrier, &barrier_state, rtems_get_processor_count());
+    &barrier,
+    &barrier_state,
 static rtems_status_code test_driver_init(
@@ -77,7 +81,7 @@ static rtems_status_code test_driver_init(
   uint32_t self = rtems_scheduler_get_processor();
   uint32_t cpu;
   TEST_BEGIN();
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index 217c7a1758..640178a84a 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -71,7 +71,11 @@ static void fatal_extension(
     assert(code == SMP_FATAL_SHUTDOWN);
+    &barrier,
+    &barrier_state,
@@ -81,7 +85,7 @@ static rtems_status_code test_driver_init(
   uint32_t cpu;
   TEST_BEGIN();
diff --git a/testsuites/smptests/smpipi01/init.c b/testsuites/smptests/smpipi01/init.c
index 3389e85a11..8f42c574a0 100644
--- a/testsuites/smptests/smpipi01/init.c
+++ b/testsuites/smptests/smpipi01/init.c
@@ -78,7 +78,7 @@ static void test_send_message_while_processing_a_message(
   test_context *ctx
   uint32_t cpu_index_self = rtems_scheduler_get_processor();
   uint32_t cpu_index;
   SMP_barrier_State *bs = &ctx->main_barrier_state;
@@ -131,7 +131,7 @@ static void test_send_message_flood(
   test_context *ctx
   uint32_t cpu_index;
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index da4c91d875..cc08220b60 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -80,7 +80,7 @@ static void inherit_obtain_task(rtems_task_argument arg)
   test_context *ctx = &test_instance;
   SMP_barrier_State barrier_state = SMP_BARRIER_STATE_INITIALIZER;
   rtems_counter_ticks delay = (cpu_count - 1 - arg) * ctx->inherit_obtain_delay;
   while (true) {
@@ -333,7 +333,7 @@ static void test(void)
   sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-  for (i = 0; i < rtems_get_processor_count(); ++i) {
+  for (i = 0; i < rtems_scheduler_get_processor_maximum(); ++i) {
     sc = rtems_task_create(
       rtems_build_name('I', 'N', 'H', 'O'),
       INHERIT_OBTAIN_PRIO_BASE + i,
@@ -368,7 +368,7 @@ static void test(void)
     ctx->inherit_release_counter
     printf(
       "priority inheritance obtain count %2" PRIu32 ": %" PRIu64 "\n",
       i,
diff --git a/testsuites/smptests/smpmigration01/init.c b/testsuites/smptests/smpmigration01/init.c
index 476a12a0cd..6ee263f35c 100644
--- a/testsuites/smptests/smpmigration01/init.c
+++ b/testsuites/smptests/smpmigration01/init.c
@@ -227,7 +227,7 @@ static void Init(rtems_task_argument arg)
   rtems_print_printer_fprintf_putc(&rtems_test_printer);
   TEST_BEGIN();
-  if (rtems_get_processor_count() >= 2) {
+  if (rtems_scheduler_get_processor_maximum() >= 2) {
     test();
diff --git a/testsuites/smptests/smpmigration02/init.c b/testsuites/smptests/smpmigration02/init.c
index e613f5dae9..383dc17eb5 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -56,7 +56,7 @@ static void migration_task(rtems_task_argument arg)
   uint32_t task_index = arg;
   rtems_task_priority prio = migration_task_prio(task_index);
   uint32_t cpu_index = rtems_scheduler_get_processor();
   while (true) {
@@ -80,7 +80,7 @@ static void migration_task(rtems_task_argument arg)
 static void test_migrations(test_context *ctx)
   uint32_t task_count = cpu_count + 1;
   uint32_t task_index;
@@ -146,7 +146,7 @@ static Thread_Control *get_thread_by_id(rtems_id task_id)
 static void test_double_migration(test_context *ctx)
   if (cpu_count >= 2) {
@@ -250,7 +250,7 @@ static void test_double_migration(test_context *ctx)
 static void init_scheduler_ids(test_context *ctx)
   uint32_t cpu_index;
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index a3e955b30c..6f00f688e4 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -250,7 +250,7 @@ static void create_mrsp_sema(
   uint32_t index;
@@ -1547,7 +1547,7 @@ static void migration_task(rtems_task_argument arg)
   uint32_t v = 0xdeadbeef;
   while (true) {
@@ -1565,7 +1565,7 @@ static void migration_task(rtems_task_argument arg)
 static void test_mrsp_load(test_context *ctx)
   uint32_t index;
   puts("test MrsP load");
@@ -1727,7 +1727,7 @@ static void Init(rtems_task_argument arg)
   rtems_resource_snapshot snapshot;
   uint32_t cpu_index;
   TEST_BEGIN();
diff --git a/testsuites/smptests/smpmutex01/init.c b/testsuites/smptests/smpmutex01/init.c
index fa449aacf2..eb90ad72e2 100644
--- a/testsuites/smptests/smpmutex01/init.c
+++ b/testsuites/smptests/smpmutex01/init.c
@@ -516,7 +516,7 @@ static void test_init(test_context *ctx)
   start_task(ctx, A_2_1, worker, 2, SCHED_A);
   start_task(ctx, H_A, helper, 3, SCHED_A);
-  if (rtems_get_processor_count() >= PART_COUNT) {
+  if (rtems_scheduler_get_processor_maximum() >= PART_COUNT) {
     start_task(ctx, B_4, worker, 4, SCHED_B);
     start_task(ctx, B_5_0, worker, 5, SCHED_B);
     start_task(ctx, B_5_1, worker, 5, SCHED_B);
@@ -1065,7 +1065,7 @@ static void test(test_context *ctx)
   test_init(ctx);
     test_task_get_priority_not_defined(ctx);
     test_simple_inheritance(ctx);
     test_dequeue_order_one_scheduler_instance(ctx);
diff --git a/testsuites/smptests/smpmutex02/init.c b/testsuites/smptests/smpmutex02/init.c
index 9591b46217..c0b8e44dc6 100644
--- a/testsuites/smptests/smpmutex02/init.c
+++ b/testsuites/smptests/smpmutex02/init.c
@@ -171,7 +171,7 @@ static void set_up(test_context *ctx)
   uint32_t i;
-  ctx->cpu_count = rtems_get_processor_count();
+  ctx->cpu_count = rtems_scheduler_get_processor_maximum();
   ctx->mtx_count = MTX_PER_CPU * ctx->cpu_count;
   sc = rtems_semaphore_create(
diff --git a/testsuites/smptests/smpopenmp01/init.c b/testsuites/smptests/smpopenmp01/init.c
index 5d4ab1243d..802f5bb05c 100644
--- a/testsuites/smptests/smpopenmp01/init.c
+++ b/testsuites/smptests/smpopenmp01/init.c
@@ -239,7 +239,7 @@ static uint32_t find_free_cpu(test_context *ctx)
   uint32_t i;
   uint32_t n;
-  n = rtems_get_processor_count();
+  n = rtems_scheduler_get_processor_maximum();
   pthread_mutex_lock(&ctx->mtx);
diff --git a/testsuites/smptests/smppsxaffinity01/init.c b/testsuites/smptests/smppsxaffinity01/init.c
index 56a0078b77..336fbeba48 100644
--- a/testsuites/smptests/smppsxaffinity01/init.c
+++ b/testsuites/smptests/smppsxaffinity01/init.c
@@ -111,7 +111,7 @@ void Validate_attr(void )
   rtems_test_assert( priority != -1 );
-  cpus = rtems_get_processor_count();
+  cpus = rtems_scheduler_get_processor_maximum();
   puts(
     "Init - Validate pthread_attr_setaffinity_np and "
     "pthread_attr_getaffinity_np"
diff --git a/testsuites/smptests/smppsxaffinity02/init.c b/testsuites/smptests/smppsxaffinity02/init.c
index d196621950..e4d002f21e 100644
--- a/testsuites/smptests/smppsxaffinity02/init.c
+++ b/testsuites/smptests/smppsxaffinity02/init.c
@@ -125,7 +125,7 @@ void Validate_affinity(void )
   rtems_test_assert( !sc );
diff --git a/testsuites/smptests/smppsxmutex01/init.c b/testsuites/smptests/smppsxmutex01/init.c
index a634c76962..04bed7b4f2 100644
--- a/testsuites/smptests/smppsxmutex01/init.c
+++ b/testsuites/smptests/smppsxmutex01/init.c
@@ -95,7 +95,7 @@ static void test(test_context *ctx)
   int prio_ceiling;
   int eno;
   rtems_test_assert(rtems_scheduler_get_processor() == 0);
diff --git a/testsuites/smptests/smppsxsignal01/init.c b/testsuites/smptests/smppsxsignal01/init.c
index 53ecb54932..529e870f0a 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -165,7 +165,7 @@ static void *POSIX_Init(void *arg)
   TEST_BEGIN();
     test();
diff --git a/testsuites/smptests/smpschedaffinity01/init.c b/testsuites/smptests/smpschedaffinity01/init.c
index c5a9ed5098..6134eaf86d 100644
--- a/testsuites/smptests/smpschedaffinity01/init.c
+++ b/testsuites/smptests/smpschedaffinity01/init.c
@@ -84,7 +84,7 @@ static void test(void)
   uint32_t            cpu_count;
   size = sizeof(cpu_set_t);
diff --git a/testsuites/smptests/smpschedaffinity02/init.c b/testsuites/smptests/smpschedaffinity02/init.c
index d8d2c23172..0ebdd14efa 100644
--- a/testsuites/smptests/smpschedaffinity02/init.c
+++ b/testsuites/smptests/smpschedaffinity02/init.c
@@ -128,7 +128,7 @@ static void test(void)
   cpu_set_t           cpuset;
   if (cpu_count < NUM_CPUS) {
     printf("Error: Test requires at least 2 cpus\n");
     return;
diff --git a/testsuites/smptests/smpschedaffinity03/init.c b/testsuites/smptests/smpschedaffinity03/init.c
index 5f63d5ff80..6b3fb5923d 100644
--- a/testsuites/smptests/smpschedaffinity03/init.c
+++ b/testsuites/smptests/smpschedaffinity03/init.c
@@ -43,7 +43,7 @@ static void test(void)
   cpu_set_t           cpuset;
   id = rtems_task_self();
diff --git a/testsuites/smptests/smpschedaffinity04/init.c b/testsuites/smptests/smpschedaffinity04/init.c
index 329b5a78c4..64250b9d63 100644
--- a/testsuites/smptests/smpschedaffinity04/init.c
+++ b/testsuites/smptests/smpschedaffinity04/init.c
@@ -75,7 +75,7 @@ static void test(void)
   cpu_set_t           cpuset;
   if (cpu_count < 2) {
     return;
diff --git a/testsuites/smptests/smpschedaffinity05/init.c b/testsuites/smptests/smpschedaffinity05/init.c
index 822bdddae6..f1249883d6 100644
--- a/testsuites/smptests/smpschedaffinity05/init.c
+++ b/testsuites/smptests/smpschedaffinity05/init.c
@@ -133,7 +133,7 @@ static void test(void)
     return;
diff --git a/testsuites/smptests/smpschededf02/init.c b/testsuites/smptests/smpschededf02/init.c
index c045a860e7..1d29e82b72 100644
--- a/testsuites/smptests/smpschededf02/init.c
+++ b/testsuites/smptests/smpschededf02/init.c
@@ -381,7 +381,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
     test();
   } else {
     puts("warning: wrong processor count to run the test");
diff --git a/testsuites/smptests/smpschededf03/init.c b/testsuites/smptests/smpschededf03/init.c
index 2e46fdb333..f9693f27d2 100644
--- a/testsuites/smptests/smpschededf03/init.c
+++ b/testsuites/smptests/smpschededf03/init.c
@@ -57,7 +57,7 @@ static void affinity_task(rtems_task_argument arg)
   uint32_t n;
   v = (uint32_t) arg;
   while (true) {
diff --git a/testsuites/smptests/smpschededf04/init.c b/testsuites/smptests/smpschededf04/init.c
index 3111374a94..851c1f6211 100644
--- a/testsuites/smptests/smpschededf04/init.c
+++ b/testsuites/smptests/smpschededf04/init.c
@@ -90,7 +90,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
     test();
   } else {
diff --git a/testsuites/smptests/smpscheduler01/init.c b/testsuites/smptests/smpscheduler01/init.c
index a33805b72a..a987f8c865 100644
--- a/testsuites/smptests/smpscheduler01/init.c
+++ b/testsuites/smptests/smpscheduler01/init.c
@@ -70,7 +70,7 @@ static void task(rtems_task_argument arg)
 static bool is_per_cpu_state_ok(void)
   bool ok = true;
   uint32_t i;
   for (i = 0; i < n; ++i) {
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index 1a88c6e4d4..e6480aa819 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -134,7 +134,7 @@ static void test_scheduler_add_remove_processors(void)
   sc = rtems_scheduler_remove_processor(scheduler_a_id, 0);
   rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
-  if (rtems_get_processor_count() > 1) {
+  if (rtems_scheduler_get_processor_maximum() > 1) {
     rtems_id scheduler_id;
     rtems_id scheduler_b_id;
     rtems_id task_id;
@@ -224,7 +224,7 @@ static void test(void)
   main_task_id = rtems_task_self();
   CPU_ZERO(&first_cpu);
diff --git a/testsuites/smptests/smpscheduler04/init.c b/testsuites/smptests/smpscheduler04/init.c
index d79bcd8775..147fe4c9ea 100644
--- a/testsuites/smptests/smpscheduler04/init.c
+++ b/testsuites/smptests/smpscheduler04/init.c
@@ -46,7 +46,7 @@ static test_context test_instance;
   test_context *ctx = (test_context *) arg;
   while (true) {
@@ -73,7 +73,7 @@ static void migration_task(rtems_task_argument arg)
 static void scheduler_task(rtems_task_argument arg)
   while (true) {
@@ -107,7 +107,7 @@ static void test(test_context *ctx)
   uint32_t i;
     sc = rtems_scheduler_ident(i, &ctx->scheduler_ids[i]);
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index 37c07a69af..dbc06c5b50 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -224,7 +224,7 @@ static void Init(rtems_task_argument arg)
   test_isr_level(ctx);
     test_two_processors(ctx);
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index aae3ffa56e..b4552d520e 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -314,7 +314,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
     test();
   } else {
diff --git a/testsuites/smptests/smpswitchextension01/init.c b/testsuites/smptests/smpswitchextension01/init.c
index 31c64dc49a..c5e962a11a 100644
--- a/testsuites/smptests/smpswitchextension01/init.c
+++ b/testsuites/smptests/smpswitchextension01/init.c
@@ -225,7 +225,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
     test();
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index b47fbe9245..2cfe1627c6 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -486,7 +486,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
-  if (rtems_get_processor_count() >= CPU_COUNT) {
+  if (rtems_scheduler_get_processor_maximum() >= CPU_COUNT) {
     test_restart();
     test_delete();
     test_set_life_protection(0);
diff --git a/testsuites/smptests/smpthreadpin01/init.c b/testsuites/smptests/smpthreadpin01/init.c
index 3b6060adaf..9bcf9149a9 100644
--- a/testsuites/smptests/smpthreadpin01/init.c
+++ b/testsuites/smptests/smpthreadpin01/init.c
@@ -570,7 +570,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
     test(&test_instance);
   } else {
diff --git a/testsuites/smptests/smpwakeafter01/init.c b/testsuites/smptests/smpwakeafter01/init.c
index 07e260e1a6..1545721a6f 100644
--- a/testsuites/smptests/smpwakeafter01/init.c
+++ b/testsuites/smptests/smpwakeafter01/init.c
   uint32_t test_time_in_seconds = 10;
   uint32_t i;
   for (i = 0; i < cpu_count; ++i) {
diff --git a/testsuites/sptests/sppercpudata01/init.c b/testsuites/sptests/sppercpudata01/init.c
index 94f5185d4e..eec4883e92 100644
--- a/testsuites/sptests/sppercpudata01/init.c
+++ b/testsuites/sptests/sppercpudata01/init.c
@@ -68,7 +68,11 @@ static void test_initial_values(void)
   uint32_t cpu_index;
-  for (cpu_index = 0; cpu_index < rtems_get_processor_count(); ++cpu_index) {
+  for (
+    cpu_index = 0;
+    cpu_index < rtems_scheduler_get_processor_maximum();
+    ++cpu_index
     Per_CPU_Control *cpu;
     unsigned char *c;
     unsigned short *s;
@@ -137,7 +141,11 @@ static void set_unique_values(unsigned int v)
   uint32_t cpu_index;
+  for (
+    cpu_index = 0;
+    ++cpu_index
     unsigned char *c;
     unsigned short *s;
@@ -196,7 +204,11 @@ static void test_unique_values(unsigned int v)
   uint32_t cpu_index;
+  for (
+    cpu_index = 0;
+    ++cpu_index
     unsigned char *c;
     unsigned short *s;
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index 849bfba04d..be4c606c07 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -230,7 +230,7 @@ static void Init(rtems_task_argument arg)
   test(false, load);
   test(true, load);
-  for (load = 1; load < rtems_get_processor_count(); ++load) {
+  for (load = 1; load < rtems_scheduler_get_processor_maximum(); ++load) {
     rtems_id id;
     volatile int *load_data = NULL;
2.16.4
