[PATCH 0/4] Xilinx Zynq UltraScale+ MPSoC BSP
Tue Apr 9 05:48:29 UTC 2019
On 08/04/2019 15:36, Jeff Kubascik wrote:
> On 4/8/2019 1:20 AM, Sebastian Huber wrote:
>> On 06/04/2019 02:53, Jeff Kubascik wrote:
>>> From: Jeff Kubascik <jeff.kubascik at dornerworks.com>
>>> This set of patches creates a new BSP layer for the Xilinx Zynq UltraScale+
>>> MPSoC.
>>> The first two patches move the zynq-uart driver into a common directory, so that
>>> both the xilinx-zynq and xilinx-zynqmp BSPs can use it.
>>> The third patch copies the xilinx-zynq BSP layer to xilinx-zynqmp, to use as a
>>> starting point.
>>> The fourth patch modifies the xilinx-zynqmp BSP layer as needed to work for the
>>> Ultra96 board, which is based on the MPSoC. Only AArch32 mode is currently
>>> supported.
>> The patch set looks good. Should we change the license of the original
>> Zynq BSP to BSD-2-Clause before this change? Currently, the new BSP
>> under the old RTEMS license.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> We would prefer the BSD 2-Clause license. Since the new xilinx-zynqmp BSP is
> derived from the xilinx-zynq BSP, I take it that we have permission to change
> the license clause?
I sent a patch to relicense most of the files to BSD-2-Clause:
https://lists.rtems.org/pipermail/devel/2019-April/025570.html
