[PATCH 6/6] score: Improve _SMP_Multicast_action()
Thu Apr 11 13:45:40 UTC 2019
Let it work during system initialization.
 cpukit/include/rtems/score/smpimpl.h      |  3 +-
 cpukit/score/src/percpu.c                 |  1 +
 cpukit/score/src/smpmulticastaction.c     | 20 +++++++----
 testsuites/smptests/smpmulticast01/init.c | 59 ++++++++++---------------------
 4 files changed, 34 insertions(+), 49 deletions(-)
diff --git a/cpukit/include/rtems/score/smpimpl.h b/cpukit/include/rtems/score/smpimpl.h
index a501339176..c0a3ccb610 100644
--- a/cpukit/include/rtems/score/smpimpl.h
+++ b/cpukit/include/rtems/score/smpimpl.h
@@ -78,7 +78,8 @@ typedef enum {
   SMP_FATAL_SHUTDOWN,
   SMP_FATAL_SHUTDOWN_RESPONSE,
   SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED,
-  SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED
+  SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED,
+  SMP_FATAL_INVALID_CPU_STATE_TO_PERFORM_JOBS
 } SMP_Fatal_code;
 static inline void _SMP_Fatal( SMP_Fatal_code code )
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 0e4c0678e7..e4c3b881e5 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -99,6 +99,7 @@ static void _Per_CPU_State_busy_wait(
           && state != PER_CPU_STATE_SHUTDOWN
         _Per_CPU_State_before_multitasking_action( cpu );
+        _Per_CPU_Perform_jobs( cpu );
         _CPU_SMP_Processor_event_receive();
         state = cpu->state;
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 2288dbe939..69bc87d7e0 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -31,7 +31,6 @@
 #include <rtems/score/smpimpl.h>
-#include <rtems/score/sysstate.h>
 typedef struct Per_CPU_Job {
   struct Per_CPU_Job *next;
@@ -138,11 +137,23 @@ static void _SMP_Wait_for_action_jobs(
   for ( cpu_index = 0; cpu_index < cpu_max; ++cpu_index ) {
     if ( _Processor_mask_Is_set( targets, cpu_index ) ) {
       const Per_CPU_Job *job;
+      Per_CPU_Control   *cpu;
       job = &jobs[ cpu_index ];
+      cpu = _Per_CPU_Get_by_index( cpu_index );
       while ( _Atomic_Load_uint( &job->done, ATOMIC_ORDER_ACQUIRE ) == 0 ) {
-        _Per_CPU_Try_perform_jobs( cpu_self );
+        switch ( cpu->state ) {
+          case PER_CPU_STATE_INITIAL:
+          case PER_CPU_STATE_READY_TO_START_MULTITASKING:
+          case PER_CPU_STATE_REQUEST_START_MULTITASKING:
+          case PER_CPU_STATE_UP:
+            _Per_CPU_Try_perform_jobs( cpu_self );
+            break;
+          default:
+            _SMP_Fatal( SMP_FATAL_INVALID_CPU_STATE_TO_PERFORM_JOBS );
+            break;
@@ -161,11 +172,6 @@ void _SMP_Multicast_action(
   cpu_max = _SMP_Get_processor_maximum();
   _Assert( cpu_max <= CPU_MAXIMUM_PROCESSORS );
-  if ( ! _System_state_Is_up( _System_state_Get() ) ) {
-    ( *handler )( arg );
-    return;
   if ( targets == NULL ) {
     targets = _SMP_Get_online_processors();
diff --git a/testsuites/smptests/smpmulticast01/init.c b/testsuites/smptests/smpmulticast01/init.c
index e599a78bde..c421767b1c 100644
--- a/testsuites/smptests/smpmulticast01/init.c
+++ b/testsuites/smptests/smpmulticast01/init.c
@@ -104,18 +104,15 @@ static void action(void *arg)
 static void test_unicast(
   test_context *ctx,
-  void (*multicast_action)(const Processor_mask *, SMP_Action_handler, void *),
-  bool before_multitasking
+  void (*multicast_action)(const Processor_mask *, SMP_Action_handler, void *)
   uint32_t step;
   uint32_t i;
   uint32_t n;
-  uint32_t self;
   T_plan(1);
   step = 0;
-  self = rtems_scheduler_get_processor();
   n = rtems_scheduler_get_processor_maximum();
   for (i = 0; i < n; ++i) {
@@ -134,18 +131,10 @@ static void test_unicast(
       ++step;
       id = _Atomic_Load_uint(&ctx->id[j], ATOMIC_ORDER_RELAXED);
-      if (before_multitasking) {
-        if (j == self) {
-          T_quiet_eq_uint(j + 1, id);
-        } else {
-          T_quiet_eq_uint(0, id);
+      if (j == i) {
+        T_quiet_eq_uint(j + 1, id);
       } else {
-        if (j == i) {
-        } else {
+        T_quiet_eq_uint(0, id);
@@ -155,18 +144,15 @@ static void test_unicast(
 static void test_broadcast(
   test_context *ctx,
   uint32_t step;
   uint32_t i;
   uint32_t n;
-  uint32_t self;
   T_plan(1);
   step = 0;
@@ -181,16 +167,7 @@ static void test_broadcast(
       ++step;
-        if (j == self) {
-        } else {
-      } else {
@@ -204,27 +181,27 @@ static void test_before_multitasking(void)
   ctx = &test_instance;
   T_case_begin("UnicastBeforeMultitasking", NULL);
-  test_unicast(ctx, _SMP_Multicast_action, true);
+  test_unicast(ctx, _SMP_Multicast_action);
   T_case_end();
   T_case_begin("UnicastBeforeMultitaskingIRQDisabled", NULL);
-  test_unicast(ctx, multicast_action_irq_disabled, true);
+  test_unicast(ctx, multicast_action_irq_disabled);
   T_case_end();
   T_case_begin("UnicastBeforeMultitaskingDispatchDisabled", NULL);
-  test_unicast(ctx, multicast_action_dispatch_disabled, true);
+  test_unicast(ctx, multicast_action_dispatch_disabled);
   T_case_end();
   T_case_begin("BroadcastBeforeMultitasking", NULL);
-  test_broadcast(ctx, _SMP_Multicast_action, true);
+  test_broadcast(ctx, _SMP_Multicast_action);
   T_case_end();
   T_case_begin("BroadcastBeforeMultitaskingIRQDisabled", NULL);
-  test_broadcast(ctx, multicast_action_irq_disabled, true);
+  test_broadcast(ctx, multicast_action_irq_disabled);
   T_case_end();
   T_case_begin("BroadcastBeforeMultitaskingDispatchDisabled", NULL);
-  test_broadcast(ctx, multicast_action_dispatch_disabled, true);
+  test_broadcast(ctx, multicast_action_dispatch_disabled);
   T_case_end();
@@ -249,27 +226,27 @@ static void Init(rtems_task_argument arg)
   T_case_begin("UnicastDuringMultitasking", NULL);
-  test_unicast(ctx, _SMP_Multicast_action, false);
   T_case_end();
   T_case_begin("UnicastDuringMultitaskingIRQDisabled", NULL);
-  test_unicast(ctx, multicast_action_irq_disabled, false);
   T_case_end();
   T_case_begin("UnicastDuringMultitaskingDispatchDisabled", NULL);
-  test_unicast(ctx, multicast_action_dispatch_disabled, false);
   T_case_end();
   T_case_begin("BroadcastDuringMultitasking", NULL);
-  test_broadcast(ctx, _SMP_Multicast_action, false);
   T_case_end();
   T_case_begin("BroadcastDuringMultitaskingIRQDisabled", NULL);
-  test_broadcast(ctx, multicast_action_irq_disabled, false);
   T_case_end();
   T_case_begin("BroadcastDuringMultitaskingDispatchDisabled", NULL);
-  test_broadcast(ctx, multicast_action_dispatch_disabled, false);
   T_case_end();
   ok = T_run_finalize();
2.16.4
