littleVGL now supports FreeBSD framebuffer
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Aug 30 07:53:31 UTC 2019
On Fri, Aug 30, 2019 at 12:08 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 30/08/2019 02:39, Chris Johns wrote:
> > On 30/8/19 1:19 am, Vijay Kumar Banerjee wrote:
> >> I have written the scripts to build littlevgl using rtems_waf. The
> build works fine
> >> and installs the required header and the static library in the prefix
> library path.
> > This is great work. Well done.
> +1
> Thanks!
> >> The repository is pushed here, please have a look:
> >> https://github.com/thelunatic/littlevgl-rsb
> > First a simple question ... why is there an import of runpy in wscript?
It's no more needed, I'll post a patch to remove it.
Also, I'll post patches to add a README and README.waf for the repo.
> > Second, I have moved the repo to the git.rtems.org. :)
> > Could you please check if it is OK?
Looks great!
> > I have sorted out how to manage the repos in cgit so from the previous
> > discussions I have taken the path of separate repos.
> Hello Chris,
> that looks great. Very clear structure.
> Best regards
> Christian
> > Please have a look at
> > https://git.rtems.org/ and the LittleVGL repo I have added under
> Packages.
> > Again, thank you for this and your work in creating the package.
> > Chris
> > devel mailing list
> > devel at rtems.org
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190830/d85a8c10/attachment.html>
