Not able to run riscv-rv32imac testsuites
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Sun Aug 11 18:31:33 UTC 2019
On Sun, 11 Aug 2019 at 16:11, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> But I am not able to run:
> qemu-system-riscv64 -no-reboot -nographic -machine virt -m 256M -kernel hello.exe
> On Fri, Aug 9, 2019 at 2:53 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> I was able to run rv32imac using
>> qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M -kernel hello.exe
>> When I configured rv32imac BSP with RISCV_ENABLE_HTIF_SUPPORT=1, This
RISCV_ENABLE_HTIF_SUPPORT is only needed if you’re running on Spike. Which
BSP are you building and running on QEMU?
command prevents qemu from quitting properly I guess.
> As after showing output, cursor still blinks and I quit it using 'pkill -9
> qemu'.
>> On Tue, Aug 6, 2019 at 9:04 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> Awesome, thanks!
>>> On Tue, Aug 6, 2019 at 8:50 PM Hesham Almatary <
>>> hesham.almatary at cl.cam.ac.uk> wrote:
>>>> Hi Vaibhav,
>>>> * I recommend you use rv64* because of a potential 32-bit HTIF issue on
>>>> Spike.
>>>> * Make sure you install Spike correctly [1] and it's in your path or
>>>> also qemu-system-riscv* instead.
>>>> * If you're building RTEMS for Spike (i.e., rv*_spike), make sure to
>>>> add RISCV_ENABLE_HTIF_SUPPORT to your configure line [2] when you
>>>> build RTEMS.
>>>> * It might be easier to try rv64* on QEMU (i.e., no Spike) instead.
>>>> [1] https://github.com/riscv/riscv-isa-sim
>>>> [2] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
>>>> On Tue, 6 Aug 2019 at 14:52, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>>> wrote:
>>>> > I am getting following error:
>>>> > $ rtems-test --rtems-bsp=rv32imac_spike
>>>> --rtems-tools=$HOME/development/rtems/5
>>>> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>>> > RTEMS Testing - Tester, 5.0.not_released
>>>> >  Command Line: /home/varodek/development/rtems/5/bin/rtems-test
>>>> --rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>>> >  Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
>>>> 15:00:46 UTC 2019 x86_64
>>>> >  Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
>>>> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
>>>> 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
>>>> > [ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>> riscv32/rv32imac: capture.exe
>>>> > [ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>> riscv32/rv32imac: cdtest.exe
>>>> > [ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>> riscv32/rv32imac: cxx_iostream.exe
>>>> > [ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>> riscv32/rv32imac: base_sp.exe
>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> > warning: switched to dry run due to errors
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> > Result: invalid    Time: 0:00:00.032377 base_sp.exe
>>>> > =>  run: spike --isa=RV32IMAC
>>>> > Result: invalid    Time: 0:00:00.037950 capture.exe
>>>> > Result: invalid    Time: 0:00:00.038061 cdtest.exe
>>>> > Result: invalid    Time: 0:00:00.034353 cxx_iostream.exe
>>>> > [ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>> riscv32/rv32imac: minimum.exe
>>>> > [ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>> riscv32/rv32imac: nsecs.exe
>>>> > [ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>> riscv32/rv32imac: fileio.exe
>>>> > [ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>> riscv32/rv32imac: hello.exe
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe:
>>>> exit-code:2
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> exit-code:2
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> > Result: invalid    Time: 0:00:00.009235 fileio.exe
>>>> > Result: invalid    Time: 0:00:00.005886 hello.exe
>>>> > Result: invalid    Time: 0:00:00.011045 nsecs.exe
>>>> > [ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>>>> riscv32/rv32imac: paranoia.exe
>>>> > [10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>>>> riscv32/rv32imac: ticker.exe
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> > [11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  |
>>>> riscv32/rv32imac: unlimited.exe
>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe:
>>>> exit-code:2
>>>> exit-code:2
>>>> > Result: invalid    Time: 0:00:00.011650 paranoia.exe
>>>> > Result: invalid    Time: 0:00:00.009872 ticker.exe
>>>> > Result: invalid    Time: 0:00:00.002352 unlimited.exe
>>>> > Passed:         1
>>>> > Failed:         0
>>>> > User Input:     0
>>>> > Expected Fail:  0
>>>> > Indeterminate:  0
>>>> > Benchmark:      0
>>>> > Timeout:        0
>>>> > Invalid:       10
>>>> > Wrong Version:  0
>>>> > Wrong Build:    0
>>>> > Wrong Tools:    0
>>>> > Total:         11
>>>> > Invalid:
>>>> >  capture.exe
>>>> >  cdtest.exe
>>>> >  cxx_iostream.exe
>>>> >  base_sp.exe
>>>> >  nsecs.exe
>>>> >  fileio.exe
>>>> >  hello.exe
>>>> >  paranoia.exe
>>>> >  ticker.exe
>>>> >  unlimited.exe
>>>> > Average test time: 0:00:00.093749
>>>> > Testing time     : 0:00:01.031239
>>>> > _______________________________________________
>>>> > devel mailing list
>>>> > devel at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190811/a9433af4/attachment-0002.html>
