Not able to run riscv-rv32imac testsuites
Vaibhav Gupta vaibhavgupta40 at gmail.com
Mon Aug 12 02:54:42 UTC 2019
On Mon, Aug 12, 2019, 12:01 AM Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> On Sun, 11 Aug 2019 at 16:11, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> But I am not able to run:
>> qemu-system-riscv64 -no-reboot -nographic -machine virt -m 256M -kernel hello.exe
>> On Fri, Aug 9, 2019 at 2:53 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> I was able to run rv32imac using
>>> qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M -kernel hello.exe
>>> When I configured rv32imac BSP with RISCV_ENABLE_HTIF_SUPPORT=1, This
> RISCV_ENABLE_HTIF_SUPPORT is only needed if you’re running on Spike.
Yeah, earlier i didn't use this parameter in configure. But when things
were not working, I had to rebuilt BSP using it
And I used 'qemu-system-riscv64 -machine spike_v1.10...' but this too
didn't worked.
> Which BSP are you building and running on QEMU?
Both rv32imac and rv64imac.
I am able to run rv32imac but not rv64imac.
- Vaibhav
> command prevents qemu from quitting properly I guess.
>> As after showing output, cursor still blinks and I quit it using 'pkill
>> -9 qemu'.
>>> On Tue, Aug 6, 2019 at 9:04 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>>> Awesome, thanks!
>>>> On Tue, Aug 6, 2019 at 8:50 PM Hesham Almatary <
>>>> hesham.almatary at cl.cam.ac.uk> wrote:
>>>>> Hi Vaibhav,
>>>>> * I recommend you use rv64* because of a potential 32-bit HTIF issue
>>>>> on Spike.
>>>>> * Make sure you install Spike correctly [1] and it's in your path or
>>>>> also qemu-system-riscv* instead.
>>>>> * If you're building RTEMS for Spike (i.e., rv*_spike), make sure to
>>>>> add RISCV_ENABLE_HTIF_SUPPORT to your configure line [2] when you
>>>>> build RTEMS.
>>>>> * It might be easier to try rv64* on QEMU (i.e., no Spike) instead.
>>>>> [1] https://github.com/riscv/riscv-isa-sim
>>>>> [2] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
>>>>> On Tue, 6 Aug 2019 at 14:52, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>>>> wrote:
>>>>> > I am getting following error:
>>>>> > $ rtems-test --rtems-bsp=rv32imac_spike
>>>>> --rtems-tools=$HOME/development/rtems/5
>>>>> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>>>> > RTEMS Testing - Tester, 5.0.not_released
>>>>> >  Command Line: /home/varodek/development/rtems/5/bin/rtems-test
>>>>> --rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>>>> >  Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
>>>>> 15:00:46 UTC 2019 x86_64
>>>>> >  Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
>>>>> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
>>>>> 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
>>>>> > [ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> riscv32/rv32imac: capture.exe
>>>>> > [ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> riscv32/rv32imac: cdtest.exe
>>>>> > [ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> riscv32/rv32imac: cxx_iostream.exe
>>>>> > [ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> riscv32/rv32imac: base_sp.exe
>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> > warning: switched to dry run due to errors
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> > Result: invalid    Time: 0:00:00.032377 base_sp.exe
>>>>> > =>  run: spike --isa=RV32IMAC
>>>>> > Result: invalid    Time: 0:00:00.037950 capture.exe
>>>>> > Result: invalid    Time: 0:00:00.038061 cdtest.exe
>>>>> > Result: invalid    Time: 0:00:00.034353 cxx_iostream.exe
>>>>> > [ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>>> riscv32/rv32imac: minimum.exe
>>>>> > [ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>>> riscv32/rv32imac: nsecs.exe
>>>>> > [ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>>> riscv32/rv32imac: fileio.exe
>>>>> > [ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>>>> riscv32/rv32imac: hello.exe
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe:
>>>>> exit-code:2
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> > Result: invalid    Time: 0:00:00.009235 fileio.exe
>>>>> > Result: invalid    Time: 0:00:00.005886 hello.exe
>>>>> > Result: invalid    Time: 0:00:00.011045 nsecs.exe
>>>>> > [ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>>>>> riscv32/rv32imac: paranoia.exe
>>>>> > [10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>>>>> riscv32/rv32imac: ticker.exe
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> > [11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  |
>>>>> riscv32/rv32imac: unlimited.exe
>>>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe:
>>>>> exit-code:2
>>>>> exit-code:2
>>>>> > Result: invalid    Time: 0:00:00.011650 paranoia.exe
>>>>> > Result: invalid    Time: 0:00:00.009872 ticker.exe
>>>>> > Result: invalid    Time: 0:00:00.002352 unlimited.exe
>>>>> > Passed:         1
>>>>> > Failed:         0
>>>>> > User Input:     0
>>>>> > Expected Fail:  0
>>>>> > Indeterminate:  0
>>>>> > Benchmark:      0
>>>>> > Timeout:        0
>>>>> > Invalid:       10
>>>>> > Wrong Version:  0
>>>>> > Wrong Build:    0
>>>>> > Wrong Tools:    0
>>>>> > Total:         11
>>>>> > Invalid:
>>>>> >  capture.exe
>>>>> >  cdtest.exe
>>>>> >  cxx_iostream.exe
>>>>> >  base_sp.exe
>>>>> >  nsecs.exe
>>>>> >  fileio.exe
>>>>> >  hello.exe
>>>>> >  paranoia.exe
>>>>> >  ticker.exe
>>>>> >  unlimited.exe
>>>>> > Average test time: 0:00:00.093749
>>>>> > Testing time     : 0:00:01.031239
>>>>> > _______________________________________________
>>>>> > devel mailing list
>>>>> > devel at rtems.org
>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190812/9dd803f5/attachment-0002.html>
