Not able to run riscv-rv32imac testsuites
    Hesham Almatary
    hesham.almatary at cl.cam.ac.uk
    Mon Aug 12 09:30:17 UTC 2019
On Mon, 12 Aug 2019 at 03:55, Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> On Mon, Aug 12, 2019, 12:01 AM Hesham Almatary <hesham.almatary at cl.cam.ac.uk> wrote:
>> On Sun, 11 Aug 2019 at 16:11, Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>> But I am not able to run:
>>> qemu-system-riscv64 -no-reboot -nographic -machine virt -m 256M -kernel hello.exe
>>> On Fri, Aug 9, 2019 at 2:53 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>>> I was able to run rv32imac using
>>>> qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M -kernel hello.exe
>>> When I configured rv32imac BSP with RISCV_ENABLE_HTIF_SUPPORT=1, This
>> RISCV_ENABLE_HTIF_SUPPORT is only needed if you’re running on Spike.
> Yeah, earlier i didn't use this parameter in configure. But when things were not working, I had to rebuilt BSP using it
> And I used 'qemu-system-riscv64 -machine spike_v1.10...' but this too didn't worked.
>> Which BSP are you building and running on QEMU?
> Both rv32imac and rv64imac.
> I am able to run rv32imac but not rv64imac.
QEMU should be able to run "rv64imac_medany" and not "rv64imac". They
have different DRAM_BASE and QEMU, AFAIK, only works with rv64*_medany
which has 0x80000000 as a DRAM_BASE.
> - Vaibhav
>>> command prevents qemu from quitting properly I guess.
>>> As after showing output, cursor still blinks and I quit it using 'pkill -9 qemu'.
>>>> On Tue, Aug 6, 2019 at 9:04 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>>>> Awesome, thanks!
>>>>> On Tue, Aug 6, 2019 at 8:50 PM Hesham Almatary <hesham.almatary at cl.cam.ac.uk> wrote:
>>>>>> Hi Vaibhav,
>>>>>> * I recommend you use rv64* because of a potential 32-bit HTIF issue on Spike.
>>>>>> * Make sure you install Spike correctly [1] and it's in your path or
>>>>>> also qemu-system-riscv* instead.
>>>>>> * If you're building RTEMS for Spike (i.e., rv*_spike), make sure to
>>>>>> add RISCV_ENABLE_HTIF_SUPPORT to your configure line [2] when you
>>>>>> build RTEMS.
>>>>>> * It might be easier to try rv64* on QEMU (i.e., no Spike) instead.
>>>>>> [1] https://github.com/riscv/riscv-isa-sim
>>>>>> [2] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
>>>>>> On Tue, 6 Aug 2019 at 14:52, Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>>>>> > I am getting following error:
>>>>>> > $ rtems-test --rtems-bsp=rv32imac_spike --rtems-tools=$HOME/development/rtems/5 ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>>>>> > RTEMS Testing - Tester, 5.0.not_released
>>>>>> >  Command Line: /home/varodek/development/rtems/5/bin/rtems-test --rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5 /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>>>>> >  Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64
>>>>>> >  Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
>>>>>> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
>>>>>> > [ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac: capture.exe
>>>>>> > [ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac: cdtest.exe
>>>>>> > [ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac: cxx_iostream.exe
>>>>>> > [ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac: base_sp.exe
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe: exit-code:2
>>>>>> > warning: switched to dry run due to errors
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe: exit-code:2
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe: exit-code:2
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe: exit-code:2
>>>>>> > Result: invalid    Time: 0:00:00.032377 base_sp.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe
>>>>>> > Result: invalid    Time: 0:00:00.037950 capture.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe
>>>>>> > Result: invalid    Time: 0:00:00.038061 cdtest.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe
>>>>>> > Result: invalid    Time: 0:00:00.034353 cxx_iostream.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe
>>>>>> > [ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac: minimum.exe
>>>>>> > [ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac: nsecs.exe
>>>>>> > [ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac: fileio.exe
>>>>>> > [ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac: hello.exe
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe: exit-code:2
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe: exit-code:2
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe: exit-code:2
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe: exit-code:2
>>>>>> > Result: invalid    Time: 0:00:00.009235 fileio.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe
>>>>>> > Result: invalid    Time: 0:00:00.005886 hello.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe
>>>>>> > Result: invalid    Time: 0:00:00.011045 nsecs.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe
>>>>>> > [ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  | riscv32/rv32imac: paranoia.exe
>>>>>> > [10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  | riscv32/rv32imac: ticker.exe
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe: exit-code:2
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe: exit-code:2
>>>>>> > [11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  | riscv32/rv32imac: unlimited.exe
>>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe: exit-code:2
>>>>>> > Result: invalid    Time: 0:00:00.011650 paranoia.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe
>>>>>> > Result: invalid    Time: 0:00:00.009872 ticker.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe
>>>>>> > Result: invalid    Time: 0:00:00.002352 unlimited.exe
>>>>>> > =>  run: spike --isa=RV32IMAC /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe
>>>>>> > Passed:         1
>>>>>> > Failed:         0
>>>>>> > User Input:     0
>>>>>> > Expected Fail:  0
>>>>>> > Indeterminate:  0
>>>>>> > Benchmark:      0
>>>>>> > Timeout:        0
>>>>>> > Invalid:       10
>>>>>> > Wrong Version:  0
>>>>>> > Wrong Build:    0
>>>>>> > Wrong Tools:    0
>>>>>> > Total:         11
>>>>>> > Invalid:
>>>>>> >  capture.exe
>>>>>> >  cdtest.exe
>>>>>> >  cxx_iostream.exe
>>>>>> >  base_sp.exe
>>>>>> >  nsecs.exe
>>>>>> >  fileio.exe
>>>>>> >  hello.exe
>>>>>> >  paranoia.exe
>>>>>> >  ticker.exe
>>>>>> >  unlimited.exe
>>>>>> > Average test time: 0:00:00.093749
>>>>>> > Testing time     : 0:00:01.031239
>>>>>> > _______________________________________________
>>>>>> > devel mailing list
>>>>>> > devel at rtems.org
>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
