Doorstop 2.0.post2 release available
Chris Johns
chrisj at rtems.org
Mon Dec 2 23:06:58 UTC 2019
On 2/12/19 6:41 pm, Sebastian Huber wrote:
> Doorstop is the requirements management tool intended to be used for the
> technical specification of RTEMS.
> This weekend, Doorstop 2.0.post2 was released:
> https://pypi.org/project/doorstop/2.0.post2/
> I contributed 63 change sets to Doorstop in the last five months. This release
> contains all features we need to get started with the technical specification of
> RTEMS with the help of Doorstop.
Well done and thank you for doing this.
> The first use of Doorstop is done in the new build system. I will update the
> documentation to mention this Doorstop release. I will use it to generate the
> fingerprints of the items.
Do we need to capture Doorstop in our future releases? If so how? We have a
requirement our release capture all source code so insulate ourselves against an
upstream side not existing or restructuring.
