Doorstop 2.0.post2 release available
Tue Dec 3 06:01:46 UTC 2019
On 03/12/2019 00:06, Chris Johns wrote:
>> The first use of Doorstop is done in the new build system. I will update the
>> documentation to mention this Doorstop release. I will use it to generate the
>> fingerprints of the items.
> Do we need to capture Doorstop in our future releases? If so how? We have a
> requirement our release capture all source code so insulate ourselves against an
> upstream side not existing or restructuring.
On pypi.org you can download packages:
https://pypi.org/project/doorstop/2.0.post2/#files
Should we add a Git mirror to RTEMS?
For what would we need Doorstop after a release? You need it after
changes in specification files to update the fingerprints (e.g. fix of a
typo in a documentation file). In the worst case you could do this also
by hand or just don't update the fingerprint.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
