[PATCH 11/21] score: Statically allocate idle/MPCI stacks
Mon Dec 16 14:28:16 UTC 2019
Place idle and MPCI stacks into extra linker sections.  This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
 cpukit/include/rtems/confdefs.h      | 39 +++++++++++++++---------------------
 cpukit/include/rtems/score/mpci.h    |  7 +++++++
 cpukit/include/rtems/score/thread.h  |  7 +++++++
 cpukit/score/src/mpci.c              |  7 +++----
 cpukit/score/src/mpcidefault.c       |  8 ++++++++
 cpukit/score/src/threadcreateidle.c  | 11 +++++-----
 testsuites/sptests/spstkalloc/init.c |  4 ++--
 7 files changed, 48 insertions(+), 35 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index a5728e9868..05dfc3c91a 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1824,6 +1824,14 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
         CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK, /* MPCI stack > minimum */
         CONFIGURE_MP_MPCI_TABLE_POINTER         /* ptr to MPCI config table */
+      char _MPCI_Receive_server_stack[
+        CONFIGURE_MINIMUM_TASK_STACK_SIZE
+          + CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
+          + CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
+          + CPU_ALL_TASKS_ARE_FP * CONTEXT_FP_SIZE
+      ] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
+      RTEMS_SECTION( ".rtemsstack.mpci" );
     #endif
     #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
@@ -2432,22 +2440,6 @@ struct _reent *__getreent(void)
     (_CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART + \
     _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART)
- * This macro is calculated to specify the memory required for
- * the Idle tasks(s) stack.
-#define _CONFIGURE_IDLE_TASKS_STACK \
-  (_CONFIGURE_IDLE_TASKS_COUNT * \
-    _Configure_From_stackspace( CONFIGURE_IDLE_TASK_STACK_SIZE ) )
- * This macro is calculated to specify the stack memory required for the MPCI
- * task.
-#define _CONFIGURE_MPCI_RECEIVE_SERVER_STACK \
-  (_CONFIGURE_MPCI_RECEIVE_SERVER_COUNT * \
-    _Configure_From_stackspace(CONFIGURE_MINIMUM_TASK_STACK_SIZE))
  * the stacks of all tasks.
@@ -2474,8 +2466,6 @@ struct _reent *__getreent(void)
 #else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
-#define _CONFIGURE_IDLE_TASKS_STACK 0
-#define _CONFIGURE_MPCI_RECEIVE_SERVER_STACK 0
 #define _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS 0
 #define _CONFIGURE_TASKS_STACK 0
 #define _CONFIGURE_POSIX_THREADS_STACK 0
@@ -2497,13 +2487,10 @@ struct _reent *__getreent(void)
 #define _CONFIGURE_STACK_SPACE_SIZE \
-    _CONFIGURE_IDLE_TASKS_STACK + \
-    _CONFIGURE_MPCI_RECEIVE_SERVER_STACK + \
     _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS + \
     _CONFIGURE_TASKS_STACK + \
     _CONFIGURE_POSIX_THREADS_STACK + \
     _CONFIGURE_ADA_TASKS_STACK + \
-    CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK + \
     _CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS + \
     CONFIGURE_EXTRA_TASK_STACKS + \
     _CONFIGURE_HEAP_HANDLER_OVERHEAD \
@@ -2628,8 +2615,7 @@ struct _reent *__getreent(void)
   const uint32_t _Watchdog_Ticks_per_second = _CONFIGURE_TICKS_PER_SECOND;
-  const size_t _Thread_Initial_thread_count = _CONFIGURE_IDLE_TASKS_COUNT +
-    _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT +
+  const size_t _Thread_Initial_thread_count =
     rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) +
     rtems_resource_maximum_per_allocation( _CONFIGURE_POSIX_THREADS );
@@ -2640,6 +2626,13 @@ struct _reent *__getreent(void)
     _CONFIGURE_IDLE_TASKS_COUNT + _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT
+  char _Thread_Idle_stacks[
+    _CONFIGURE_IDLE_TASKS_COUNT
+      * ( CONFIGURE_IDLE_TASK_STACK_SIZE
+        + CPU_IDLE_TASK_IS_FP * CONTEXT_FP_SIZE )
+  RTEMS_SECTION( ".rtemsstack.idle" );
   #if CONFIGURE_MAXIMUM_BARRIERS > 0
     BARRIER_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_BARRIERS );
   #endif
diff --git a/cpukit/include/rtems/score/mpci.h b/cpukit/include/rtems/score/mpci.h
index a72b1f0d5b..0de29739e8 100644
--- a/cpukit/include/rtems/score/mpci.h
+++ b/cpukit/include/rtems/score/mpci.h
@@ -162,6 +162,13 @@ typedef struct {
 extern const MPCI_Configuration _MPCI_Configuration;
+ * @brief The MPCI receive server stack.
+ * Provided by the application via <rtems/confdefs.h>
+extern char _MPCI_Receive_server_stack[];
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index c70624f64a..e438549ff8 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -1062,6 +1062,13 @@ Thread_Information name##_Information = { \
+ * @brief The idle thread stacks.
+ * Provided by the application via <rtems/confdefs.h>.
+extern char _Thread_Idle_stacks[];
 #if defined(RTEMS_MULTIPROCESSING)
  * @brief The configured thread control block.
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 1f9b838796..f173eeb588 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -135,11 +135,10 @@ static void _MPCI_Create_server( void )
   config.budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE;
   config.is_fp = CPU_ALL_TASKS_ARE_FP;
   config.stack_size = _Stack_Minimum()
+    + _MPCI_Configuration.extra_mpci_receive_server_stack
-    + _MPCI_Configuration.extra_mpci_receive_server_stack;
-  config.stack_size = _Stack_Extend_size( config.stack_size, config.is_fp );
-  config.stack_area = _Stack_Allocate( config.stack_size );
-  _Assert( config.stack_area != NULL );
+    + CPU_ALL_TASKS_ARE_FP * CONTEXT_FP_SIZE;
+  config.stack_area = _MPCI_Receive_server_stack;
   ok = _Thread_Initialize(
     &_Thread_Information,
diff --git a/cpukit/score/src/mpcidefault.c b/cpukit/score/src/mpcidefault.c
index fad806c5c1..395515759b 100644
--- a/cpukit/score/src/mpcidefault.c
+++ b/cpukit/score/src/mpcidefault.c
@@ -19,6 +19,7 @@
 #endif
 #include <rtems/score/mpci.h>
+#include <rtems/score/context.h>
 #include <rtems/score/objectdata.h>
 #include <rtems/score/stack.h>
@@ -35,3 +36,10 @@ const MPCI_Configuration _MPCI_Configuration = {
   STACK_MINIMUM_SIZE,       /* MPCI receive server stack size */
   NULL                      /* pointer to MPCI address table */
+char _MPCI_Receive_server_stack[
+  STACK_MINIMUM_SIZE
+] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
+RTEMS_SECTION( ".rtemsstack.mpci" );
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index c06f211a6b..dbb2018bf8 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -51,12 +51,11 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
   config.name.name_u32 = _Objects_Build_name( 'I', 'D', 'L', 'E' );
   config.is_fp = CPU_IDLE_TASK_IS_FP;
   config.is_preemptible = true;
-  config.stack_size = _Stack_Ensure_minimum(
-    rtems_configuration_get_idle_task_stack_size()
+  config.stack_size = rtems_configuration_get_idle_task_stack_size()
+    + CPU_IDLE_TASK_IS_FP * CONTEXT_FP_SIZE;
+  config.stack_area = &_Thread_Idle_stacks[
+    _Per_CPU_Get_index( cpu ) * config.stack_size
    *  The entire workspace is zeroed during its initialization.  Thus, all
diff --git a/testsuites/sptests/spstkalloc/init.c b/testsuites/sptests/spstkalloc/init.c
index ab9612c94a..60169435c4 100644
--- a/testsuites/sptests/spstkalloc/init.c
+++ b/testsuites/sptests/spstkalloc/init.c
@@ -18,14 +18,14 @@ const char rtems_test_name[] = "SPSTKALLOC";
 /* forward declarations to avoid warnings */
 rtems_task Init(rtems_task_argument argument);
-#define MAXIMUM_STACKS 3
+#define MAXIMUM_STACKS 2
 typedef struct {
   uint8_t Space[CPU_STACK_MINIMUM_SIZE];
 } StackMemory_t;
 int            stackToAlloc = 0;
-StackMemory_t  Stacks[3];
+StackMemory_t  Stacks[MAXIMUM_STACKS];
 void          *StackDeallocated = NULL;
 static void *StackAllocator(size_t size)
2.16.4
