[PATCH 6/6] user: Remove nit-picky warnings.
Wed Feb 27 07:51:13 UTC 2019
On 27/02/2019 07:47, Chris Johns wrote:
> On 27/2/19 5:42 pm, Sebastian Huber wrote:
>> On 27/02/2019 07:30, Chris Johns wrote:
>>> diff --git a/README.txt b/README.txt
>>> index e002f60..115d08d 100644
>>> --- a/README.txt
>>> +++ b/README.txt
>>> @@ -415,14 +415,34 @@ existing documentation for an example and if unsure ask.
>>>          5  ^^^^^^ Sub-sub-sub-section
>>>          6  ~~~~~~ Sub-sub-sub-sub-section
>>>    -5. For literal output, such as shell commands and code use '::' at the
>>> trailing
>>> -   edge of the previous paragraph. Use the '.. code-block::' with
>>> -   'c' for C code and 'shell' for shell code and terminal output. If you need
>>> -   line number use:
>>> +5. For literal output, such as shell commands and code do not use '::'
>>> +   at the trailing edge of the previous paragraph as it generates
>>> +   warnings as the autodetect fails to find a suitable format. Use the
>>> +   '.. code-block::' with a suitable lexical label. The lexers are:
>>> +http://pygments.org/docs/lexers/
>>> +   Use the short names. For C code use 'c' code and 'shell' for shell
>>> +   scripts and for terminal output use 'none'.
>> I would not use 'shell' for commands. For example in
>> .. code-block:: shell
>>      ../configure --enable-rtemsbsp=qoriq_e6500_32 \
>>          QORIQ_IS_HYPERVISOR_GUEST=1 \
>>          QORIQ_UART_0_ENABLE=0 \
>>          QORIQ_UART_1_ENABLE=0 \
>>          QORIQ_TLB1_ENTRY_COUNT=16
>> the "variables" QORIQ_IS_HYPERVISOR_GUEST, etc. are highlighted and the numeric
>> "values" 0, etc. are highlighted differently. Is this useful? I don't think so.
>> In real shell scripts with variables, loops, conditions and whatever maybe it
>> makes sense to use syntax highlighting.
> Is this a bug with the pigments tool?
 From my point of view this is a bug. I don't have time to report it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
