Zynq RTEMS 5 SMP Crashing on call to connect in socket.h [Solved]
Tue Jan 15 07:20:28 UTC 2019
Hello Avi,
On 13/01/2019 22:51, Misra, Avinash wrote:
> Hi,
> My issue turned out to be a configuration issue where I was using the
> incorrect scheduler. I was originally using #define
> CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP when in fact I should have
> been using #define CONFIGURE_SCHEDULER_EDF_SMP. This thread
> (https://lists.rtems.org/pipermail/devel/2018-October/023349.html)
> made that very clear to me.
why did you use a custom scheduler configuration?
> However, I do wonder if this is documented as part of the BSD
> documentation and I missed it? Is this already well documented or is
> this something that should be included with the BSD/RTEMS Networking
> documentation?
I think this should be documented in
https://git.rtems.org/rtems-libbsd/tree/libbsd.txt
This file needs an update in general.
> Thanks,
> Avi
> *From:* devel <devel-bounces at rtems.org> *On Behalf Of *Misra, Avinash
> *Sent:* Sunday, January 13, 2019 1:04 PM
> *To:* rtems-devel at rtems.org <devel at rtems.org>
> *Subject:* Zynq RTEMS 5 SMP Crashing on call to connect in socket.h
> Hi,
> I’m having a peculiar issue when running RTEMS in a SMP configuration
> and trying to call connect on a TCP Client Socket which is that RTEMS
> crashes when calling the system connect routine with the following error:
> Fatal source: 10 <RTEMS_FATAL_SOURCE_SMP>
> Fatal Code: 7 <0x00000007>
> RTEMS version: 5.0.0.b3c624d8886db6e791babe5e0d4f8b28992e000a
> RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB
> 9955b1a430677b12c04c77eb6502fae4bb6947b2, Newlib
> 08eab6396f678cf5e5968acaed0bae9fd129983b)
> Executing Thread ID: 0x08a010003
> Executing Thread Name: IRQS
> This only seems to occur when I configure RTEMS to execute on both
> cores of the A9 processor (by setting #define
> CONFIGURE_MAXIMUM_PROCESSORS to 2). When I have #define
> CONFIGURE_MAXIMUM_PROCESSORS set to 1 the program runs as expected,
> connects to my TCP server and sends nominal data.  Also, for what it’s
> worth, the name of my task is not IRQS so I’m not sure why I keep
> getting this exception in the IRQS thread.
> My system.hdf file and MMU setup code look as follow:
> System.hdf:
> MMU Configuration file:
> *#include*<bsp.h>
> *#include*<bsp/start.h>
> *#include*<bsp/arm-gic-irq.h>
> *#include*<bsp/arm-cp15-start.h>
> *#include*<bsp/arm-a9mpcore-start.h>
> BSP_START_DATA_SECTION*static**const*arm_cp15_start_section_config
> zynq_mmu_config_table[] = {
> ARMV7_CP15_START_DEFAULT_SECTIONS,
> .begin = 0xE0000000U,
> .end   = 0xE0300000U,
> .flags = ARMV7_MMU_DEVICE | ARM_MMU_SECT_S
> .begin = 0xF8000000U,
> .end   = 0xF9000000U,
> .begin = 0x00000000U, /*RAM 0 START ADDR*/
> .end   = 0x0002FFFFU, /*RAM 0 END ADDR*/
> .begin = 0xFFFF0000U, /*RAM 1 START ADDR*/
> .end   = 0xFFFFFDFFU, /*RAM 1 END ADDR*/
> .begin = 0x41200000U, /*AXI GPIO*/
> .end   = 0x4120FFFFU, /*AXI GPIO*/
> BSP_START_TEXT_SECTION *void**zynq_setup_mmu_and_cache*(*void*)
> uint32_tctrl = arm_cp15_start_setup_mmu_and_cache(
> ARM_CP15_CTRL_A,
> ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
> arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> ctrl,
> (uint32_t*) bsp_translation_table_base,
> ARM_MMU_DEFAULT_CLIENT_DOMAIN,
> &zynq_mmu_config_table[0],
> RTEMS_ARRAY_SIZE(zynq_mmu_config_table)
> Does anyone have an idea of as to what may be going on here?
> Thanks,
> Avi
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
